SPI Communication Issue with AD7264
Good morning.
We are using AD7264 in our design.
AD7264 is interfaced with iMX6 NXP Processor.
We would be grateful to have any insight on the queries detailed.
Scenario:
Validating SPI Communication with AD7264
Queries
  1. Is there a specific initialisation sequence for AD7264?
  2. Does there exist a reference code for initialisation?
  3. Can internal registers be read from / written to without doing any calibration?
  4. Data is transferred to AD7264 in a packet of 8 bits. An idle period of 4.5 uSec is observed between two byte transfers. Will it affect SPI communication? (Please refer image AD7264_SCLK_TimeDelay.BMP)
  5. Is there a max. time delay acceptable between transfer of successive bytes?
  6. How critical are DIN setup time (3 nSec min.) and DIN hold time (3 nSec min.)? In our case, setup time is 0 and hold time is one SCLK cycle.
Steps carried out & observations:
  1. Read contents of ADC A Internal Offset Register after power-on.
    (All "0" as suggested in datasheet Page # 23)
  2. WRITE a known value (NOT CALIBRATION VALUE).
  3. Read contents of ADC A Internal Offset Register.
    All "0". Expected is the written known value.
  4. Carry-out (1) to (3) for
    1. ADC B Internal Offset Register
    2. ADC A External Gain Register
    3. ADC B External Gain Register
      Results are the same as in case of ADC A Internal Offset Register.
Checks Performed
Checks Performed Observations
Chip select polarity
Idle high
Active low during transmission
SCLK polarity
Idle high
Chip select to SCLK setup time
12 uSec
Required is 10 nSec min. (Datasheet Page # 29)
SCLK frequency
1 MHz
MOSI Data stream on AD7264 PD0/DIN pin
Expected data stream as per the WRITE / READ scenarios
MOSI data transfer w.r.t SCLK
Bits are transferred on "falling edge" of SCLK
AVcc
5 V
Vdrive 5 V
Vref 2.5 external
Bit Streams used
Requirement Bit stream
ADC A Internal Offset Reg. Read
(MSB) 0001 0010 0001 0001 0000 0000 0000 0000 (LSB)
Last 20 LSBs are to generate SCLK for data receiving
ADC A Internal Offset Reg. Write
(MSB) 0010 0101 0101 0101 0000 (LSB)
b15-b4 : dummy data 0x55 to validate read operation
-- Utpal
    I moved this message to the precision converter space, hopefully someone here can help.
    David
       I am checking this. I'll get back to you.
    Jonathan
  • Hi UtpalT,
       Please see responses below.
    1. Is there a specific initialisation sequence for AD7264? To power up the AD7264 you can refer to the power up condition section of the datasheet (Page 22). The AD7264 can be powered up through pin driven mode or control register mode. When applying power to the AD7264, please refer to the abs max rating. Make sure that, when powering up the supply values are followed. For example on tale 3, The AVcc should be applied first before the Vdrive and VrefA and VrefB.
    2. Does there exist a reference code for initialisation?  The available code that I can refer to is in the wiki page of AD7262 (co family of AD7264).
    3. Can internal registers be read from / written to without doing any calibration? Register data can be read or write to without performing calibration. But to have an accurate measurement by removing offset and gain errors, I recommend to do calibration.
    4. Data is transferred to AD7264 in a packet of 8 bits. An idle period of 4.5 uSec is observed between two byte transfers. Will it affect SPI communication? (Please refer image AD7264_SCLK_TimeDelay.BMP) Can you please give details on what you are trying to do here.
    5. Is there a max. time delay acceptable between transfer of successive bytes? Can you please give details on what you are trying to do here.
    6. How critical are DIN setup time (3 nSec min.) and DIN hold time (3 nSec min.)? In our case, setup time is 0 and hold time is one SCLK cycle. The DIN set up time and DIN hold time is critical because this help you set up the time that the microcontroller will read the data. To make sure that data bits is read correctly, need to consider these times.
    Jonathan
  • Many thanks Jonathan.
    Your reply does help us. Few bits from my side:
    What we observed on DSO is that the SPI transfers data in packet of 8 bits (a byte).
    There is a gap of 4 uSec observed between transfer of two bytes (even though both the bytes are transferred during "same" transaction).
    However, I must admit that we have overcome the issue.
    There does not seem any issue with ADC even if two bytes of same transaction are transmitted with a delay of 4 uSec.
    All in all, the ADC is up and running right now.
    We could read data from both the channels.
    Variations are large compared to our requirement after internal calibration.
    I would mark this response as "Answered" but I might need your support on:
    1. Reference code integration (if need be)
    2. ADC Offset and Gain calibration.
    I would tart a new thread for the same.
    best regards,
    --Utpal
