AD7124-4 SPI read problem
I''m trying to read the device ID at 0x05 on the AD7124-4 using an stm32f4 discover board. Here are my initialization and read routines.
//initialization
SPI_InitStruct.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_256; // This would come to 45/256 Mhz
SPI_InitStruct.SPI_Direction=SPI_Direction_2Lines_FullDuplex;
SPI_InitStruct.SPI_Mode=SPI_Mode_Master;
SPI_InitStruct.SPI_DataSize=SPI_DataSize_8b;
SPI_InitStruct.SPI_FirstBit=SPI_FirstBit_MSB;
SPI_InitStruct.SPI_CPOL=SPI_CPOL_Low; //Clock polarity
SPI_InitStruct.SPI_CPHA=SPI_CPHA_2Edge; //Clock phase
SPI_InitStruct.SPI_NSS=SPI_NSS_Soft;
//read
uint8_t SPI_Rx(uint8_t adress)
   GPIO_ResetBits(GPIOE,GPIO_Pin_4); // This is the chip select
   adress=0x40|adress; // creating the command byte
   while(!SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE));
   SPI_I2S_SendData(SPI2,adress);
   while(!SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_RXNE));
   SPI_I2S_ReceiveData(SPI2);
   SPI_I2S_SendData(SPI2,0x00); //dummy byte
   GPIO_SetBits(GPIOE,GPIO_Pin_4);
   return SPI_I2S_ReceiveData(SPI2);
Here's what my logic analyzer was reading. Data is MOSI and DIO15 is MISO:
    on Nov 12, 2017 8:23 PM over 3 years ago
    Hi, Jay.
    May I know what is your controller digital supply? It is recommended to remove the 0 ohm resistor just to ensure that no other connections are made on your digital interface. If it is not connected anywhere in the circuit it would be fine. Usually when DRDY stops pulsing at any time and it stays high or low this indicates that the serial interface has become asynchronous (incorrect number of SCLK pulses, glitches on the SCLK line) like mentioned above. Do you have SDP-B board with you? Can you try to use the board with SDP board and check if you are seeing the same issue?
    Jellenie
    on Aug 2, 2018 3:58 PM over 2 years ago
    Thank you,
    EZ Admin
