AD7671 step
Hello
I connected to input 0 V - code from AD7671 is 32463. It is fine.
But when I repeat request the code is
32463 32591 32591 32463 32591  ....
32591 - 32463  = 128  - Where is low signif. bits ??
I checked with serial and parallel data mode.
My parallel code is:
AD7671_CS_1;
AD7671_RD_1;
while(GPIO_ReadPin(28));//wait busy
AD7671_CS_0;
AD7671_RD_0;
AD7671_result = GpioDataRegs.GPBDAT.all;
AD7671_RD_1;
AD7671_CS_1;
//start conversion
AD7671_CNVST_1;
AD7671_CNVST_0;
AD7671_CNVST_1;
My serial code is
AD7671_EXT_1;
AD7671_INVSCLK_0;
AD7671_RD_0;
AD7671_CS_1;
AD7671_SCLK_0;
AD7671_CNVST_1;
AD7671_SCLK_0;
AD7671_SCLK_1;
AD7671_SCLK_0;
AD7671_CS_0;
d = 0;
for(j=0;j<16;j++)
AD7671_SCLK_1;
if(GpioDataRegs.GPBDAT.bit.GPIO56)//SDOUT
d |= (unsigned int)(1<<(15-j));
AD7671_SCLK_0;//D9
AD7671_result = d;
AD7671_CS_1;
//start conversion
AD7671_CNVST_0;
AD7671_CNVST_1;
AD7671_CNVST_0;
  • Hi ruskuw,
       You mean that your output code is not stable and changing only on two results. There are many possible cause when there is a noisy output or not stable output. On the ADC support circuitry, the reference is important that it should be stable. How did you have force 0V on the input. You can also try tying the analog input to ground and check of this will have stable conversion results. If it is okay for you to share the schematics and scope shot so we can better understand the problem.
    Jonathan
  • You mean that your output code is not stable and changing only on two results.
    + "is not stable" - this is not problem for me in this moment.
    'only two result" - yes, this is problem - 32591 - 32463  = 128 - the difference is bit 6
    I expected to see values like this -  32591 32584 32468 32599 - with random component of error  of 1 or 2 LSB
    + I connected ADC input (with AD8021 buffer ) to AGND. 2.50 ref is OK
    + BUSY + MK SCLK
    Busy+ SDOUT
    schem is the same as in documentation. 2.5 V ref
  • additionaly, I connected  DC generator (results via parallel interface)
    U DC
    Dec
    Bin
    0 mV
    31567
    31631
    111101101001111
    111101110001111
    50 mV
    31503
    31631
    111101100001111
    111101110001111
    100 mV
    31695
    31759
    111101111001111
    111110000001111
    150 mV
    31759
    31887
    111110000001111
    111110010001111
    LS bits from 0 to 5 is not working.... and always 001111
  • Hi ruskuw,
       Just a clarification, what was the result when the inputs were connected to ground? It should be all zeros when configured in twos compliment. What is your output coding, by the way, Straight binary or twos complement? Would You be able to try a full scale voltage in the analog input. and please share the data that you see.
    Jonathan
    Thank you,
    EZ Admin
