adcs
I require an adc with 40 channel ,16 bit and 300KSPS to 1msps speed and 40 channel can be from 2 or 3 adcs but with 16 bit and 300ksps to 1msps speed and should have synchronization pin to have synchronization operation for all adcs.
    on Feb 13, 2018 12:30 AM over 2 years ago
       Do you have a bandwidth requirement of the ADC? You can check ADAS3023 AD7768 AD7616. The AD7768 has synchronization feature to synchronize all the ADC connected from the same MCLK. You can check details in ADI website http://www.analog.com/en/parametricsearch/10994#/p1746=16.6|10000000&p4369=Simultaneous%20Sampling&p3062=|3|4|5|6|7|8|10|12|16&p193=16|18|24
  • I require an adc with 16 bit with sync pin to synchronize and speed of min
    300ksps and minimum of 8 channel adc
    On Tue, Feb 13, 2018 at 2:01 PM, jcolao <
    on Feb 26, 2018 3:50 AM over 2 years ago
       I can recommend to you the two ADCs. The AD7616 and AD7768. They have different architecture, the AD7616 is a SAR and AD7768 is a Sigma Delta. The AD7616 is a 16bit , 16 channel dual simultaneous sampling ADC and has a throughput rate of 1MSPS. The sampling can be synchronize using the CONVST pins. Another ADC that I would recommend is the AD7768, which I think very close to what you are looking for. The AD7768 is a 24bit , 256ksps output data rate. The AD7768 can sample 8 channels at the same time. The AD7768 has a synchronization pins to allow  multiple AD7768 connected attune from a single master clock. You can refer to the links of the datasheet of these ADCs.
    Jonathan
    on Aug 2, 2018 4:02 PM over 2 years ago
    Thank you,
    EZ Admin
