AD7091R-8
Hello
I'm trying to set up communication with AD7091R-8. In setup I send following SPI command: 0X0CFF, 0X08FF, 0XFFFF, 0XFFFF, 0X00FF. Then I periodically send 0X0020 and I'm trying to read channel 5. I'd like to read one channeland them sequential readings. I inserted pictures from the logic analyzer into the attachment. I guess I'm getting bad data. Could you help me.
Thank you
Lukáš Mistr
attachments.zip
    on Mar 16, 2018 3:40 AM over 2 years ago
    Hi Mistr,
       In your sequence, try writing 0x0CFF only , then try pulsing 9 CONVST after the write. The CONVST is a negative pulse width, max of 500ns(10 ns min). Every CONVST pulse a conversion data should be clock out except on the first pulse after the write.
    Jonathan
  • Hi Jonathan,
    it is my mistake 0x0800. Now i sending periodically this data:
    //prepare reading
    0x0DFF //set channel register
    0x01FF //set channel sequencer
    0x0000 // of the reasons for the latency
    //read
    CONVST //pulse width 20 Microseconds
    0x0000 // read data from convert
    When I use this, all works fine. The question is why I need to use the 0x0DFF command instead of 0x0CFF and 0x01FF instead of 0x00FF. If I use only 0x0CFF and 0x00FF I do not read the last channel. The second question is about the pulse width of CONVST. If it decrease from the current 20 microseconds so the result is not correct.
    Mistr
  • Hi Jonathan,
    I tried use your advice but witout success. Next, I joined a 3 AD in the daisy chain modu and the two AD sending data correctly to command (0x0DFF, 0x01FF 0x0000 ... ) but slave C sending only channel 0
    on Aug 2, 2018 4:02 PM over 2 years ago
    Thank you,
    EZ Admin
