EVAL-AD7292SDZ J5 pinout
I'm using the EVAL-AD7292SDZ board to test a Linux driver. AD7292 has a GPIO6/BUSY pin which the eval board redirects to connector J5-7. However, I found no information about the numbering of the pins on the J5 connector. Could anyone provide me the pinout of this connector?
The evaluation board user guide sais I need to change solder link 6 (SL6) from position A to B for the board to redirect the BUSY signal to J5-7. The soldering points of SL6 are small dots about the same size the tip of my 30W soldering iron. I'm afraid of harming the eval board trying to resolder the contacts. Is there any other way to redirect GPIO6/BUSY pin to the J5 connector?
Marcelo
