ADC 4002 simulation problem
hi,
when adding the ad4002 in ltspice i cant find which pins are the ones that appear in the datasheet.
Parents
  • +1
    on Apr 7, 2020 1:41 PM over 1 year ago
    ALB0077,
       The AD4002 LTspice model is a simplified for dynamic simulation purposes (charge kick-back, settling etc.) - there is no 'programmable functionality'.
    There is also some inconsistency between the pin name of the model vs. the datasheet which can be confussing.
    Here is a brief description:
    IN+: Signal input.
    EN_PreChrg: High Z mode. Set to VDD to activate. Set to GND to disable.
    CNV: Convert input signal to sample
    Reset: Return all internal charged nodes to zero.
    GND: GND.
    IN_SlewAlarm: Slew rate monitoring. GND if good. VDD if exceeded.
    Ref: Reference voltage.
    Vout: Quantized voltage output (for observation)
    Hope this helps!
    Jeff
Reply
  • +1
    ALB0077,
    IN+: Signal input.
    GND: GND.
    Hope this helps!
    Jeff
Children
No Data
