hi,we have problem to use ad9388 in VGA 1600X900P60,
the registers config is:
/* :RGB 1600x900 _@ 60 108.000MHz Out 16bit YUV EAV/SAV: */
{I2C_ADV7441_USER_MAP, 0x03, 0x0C}, /* Disable TOD */
{I2C_ADV7441_USER_MAP, 0x05, 0x02}, /* Prim_Mode =0110b for HDMI(GR) */
{I2C_ADV7441_USER_MAP, 0x06, 0x07}, /* vid_std = 01100b */
{I2C_ADV7441_USER_MAP, 0x1D, 0x40}, /* Disable TRI_LLC */
{I2C_ADV7441_USER_MAP, 0x37, 0x01}, /* PCLK Polarity */
{I2C_ADV7441_USER_MAP, 0x3C, 0xA8}, /* SOG Sync level for atenuated sync,*/
{I2C_ADV7441_USER_MAP, 0x47, 0x0A}, /* Enable Autotmatic PLL_Qpump and VCO Range*/
{I2C_ADV7441_USER_MAP, 0x68, 0xF0}, /* Auto CSC ,YUV Out */
{I2C_ADV7441_USER_MAP, 0x6B, 0xD3}, /* Select 422 16 bit YPrPb out from
CP.656 enabled. DE enable*/
{I2C_ADV7441_USER_MAP, 0x7B, 0x0F}, /* TURN ON EAV & SAV CODES */
{I2C_ADV7441_USER_MAP, 0x81, 0xDA}, /* TURN ON AV CODE IN AUTO GR */
{I2C_ADV7441_USER_MAP, 0x87, 0xE7}, /* Enable Manual PLL Divider Ratio
0x708 = 1800 */
{I2C_ADV7441_USER_MAP, 0x88, 0x08}, /* Set PLL Divider */
{I2C_ADV7441_USER_MAP, 0x8F, 0x01}, /* Set Free Run Line Length 0x1DD=477 */
{I2C_ADV7441_USER_MAP, 0x90, 0xDD}, /* Set Free Run Line Length */
{I2C_ADV7441_USER_MAP, 0xAB, 0x3E}, /* Set Line Count Max 0x3E8 = 1000 */
{I2C_ADV7441_USER_MAP, 0xAC, 0x80}, /* Set Line Count Max */
{I2C_ADV7441_USER_MAP, 0xBA, 0xA0}, /* Enable HDMI and Analog in */
{I2C_ADV7441_USER_MAP, 0xF4, 0x2a}, /* Medium High Drive Strength */
{I2C_ADV7441_USER_MAP, 0x91, 0x10}, /* Setup interlacing */
{I2C_ADV7441_USER_MAP, 0xA2, 0x0A}, /* start of SAV(MSB) ,SAV = HsyncTime + H BackPorch + Left Border - 4*/
{I2C_ADV7441_USER_MAP, 0xA3, 0xC6}, /* start of SAV(LSB) and EAV(MSB),EAV = H.total-H.front */
{I2C_ADV7441_USER_MAP, 0xA4, 0xF0}, /* start of EAV(LSB) */
{I2C_ADV7441_USER_MAP, 0xA5, 0x3E}, /* start of VBI(MSB)--ver Sync Time +
v Back Porch + active*/
{I2C_ADV7441_USER_MAP, 0xA6, 0x70}, /* start of VBI(LSB) and end of VBI(MSB) */
{I2C_ADV7441_USER_MAP, 0xA7, 0x63}, /* end of VBI(LSB)-ver Sync Time +
v Back Porch */
{I2C_ADV7441_USER_MAP, 0x86, 0x0B}, /* not invert the order of Cr & Cb o/p */
please help me ,thank you
