AD2S1210 Input voltage scaling
Hi all,
I plan to use the AD2S1210 to implement a generic resolver measurement solution.
My customer recommends support of a wide range of transformation ratios and exitation voltages.
Thus, I an in need of an input voltage scaling solution in case the signal from the resolver is larger than the AD2S1210 is capable to deal with.
I found an article that suggests the following solution:
What do you think about using a (dual) digital potentiometer as Ra?
Regards, Niels
Adding tags for internal tracking purposes - SK 7-Oct-19
[edited by: @skowalik at 1:37 PM (GMT 0) on 7 Oct 2019]
Parents Reply Children
No Data
