ED7124 Excitation issues
In testing a circuit which is an exact copy of  your CN-0376 schematics for RTD, I come across an annoying situation.
Note that in CN-376 Ref1 is used. I use Ref2 and different AIN's see software below.
The excitation current drops to 0 after some time. I could set the time with the delay parameter!
I would expect to see a continuous voltage at the IOUT pin of approx 2.5V @ (Rref +Rrtd+Rbias)= 10K Ohm .
Again, if I remove the delay, the circuit does not work because I don't get any excitation.
What is happening here?
Brg Joost
 SPI.transfer(WRITE_OPERATION | CONTROL_REG);
                SPI.transfer(0x01);                              // internal ref enable = 01 ; ref enble  & CS_EN High : 03
                SPI.transfer(0x80);
                SPI.transfer(WRITE_OPERATION | IO_CONTROL1);     //Exitation
                SPI.transfer(0x00);                              //AIN0 Iout0 enable 250 uA; ; Iout 1 off;
                SPI.transfer(0x03);
                SPI.transfer(0x00);
                SPI.transfer(WRITE_OPERATION | CH0);
                SPI.transfer(0x81);                             // 80 = enable
                SPI.transfer(0x6A);                             // AIN11+; AIN10-
                SPI.transfer(WRITE_OPERATION | CONFIG0);        //Ref2; AIN buf on; Ref buf on; bipolair
                SPI.transfer(0x09);                             // 09E8 =Ref2, all buf's on
                SPI.transfer(0xE8);                             //PGA =1
                delay (10000);
