Consulting a data aquisition system solution
I am searching for a data aquisition system solution,there are all 64 channels input signal,each signal range is from -5V to 5V,or from 0 to 5V;
Below is the signal chain example:
For all input channels, I want to get 1Msps sampling rate,would you please help to introduce one solution?
Thanks!
Parents
  • Hi Jerrytang,
         That application has many channels. I have no idea on your application, but based from your description I would suggest the AD7616. You can use for of this. The AD7616 is 16 Channel, 16-bit ADC with throughput rate of 1MSPS. Hope this helps. Let us know if you have other questions.
    Jonathan
Reply
  • Hi Jerrytang,
    Jonathan
Children
