Hello All,
Does anyone know if AD7708 can interface with Arduino using the SPI interface? Looking through the datasheet, other microprocessors are mentioned but the not the Arduino. Thank you!
Hello All,
Yes, you can interface this product on any microcontroller with SPI interface including Arduino. Just make sure that you comply with the timing characteristics of the part to operate properly.
Jellenie
Thank you!
I noticed that the datasheet has instructions for other microcontrollers, specifically requesting that the serial clock rate be limited below 3 MHz. Is that what your referring to?
The timing characteristics can be seen on page 9 of the datasheet. It also includes the maximum SCLK of 5MHz, that is 1/200ns for t6 and t7.
Jellenie
