ADAS1000
Recommended for New Designs
The ADAS1000 measures electro
cardiac (ECG) signals, thoracic impedance, pacing artifacts,
and lead-on/lead-off status and output this information in the...
Datasheet
ADAS1000 on Analog.com
I'm trying to interface the ADAS1000 eval board with the SAM E54 Xplained Pro Eval board.
I took the below No OS driver code and added its functions and program flow into my project.
https://wiki.analog.com/_media/resources/tools-software/uc-drivers/renesas/adas1000_rx62n.zip
In the Init part I'm setting the SPI parameters. doing software reset, Setting Inactive Frame Words as 0 and setting the frame rate.
Then I'm trying to read the CMREFCTL register using the "ADAS1000_GetRegisterValue" function. The register value always returns as 0.
MCU Eval Board: SAM E54 Xplained Pro
AFE Eval board: ADAS1000SDZ
SPI Configurations:
Framerate set is 2KHz.
Kindly, help me sort this issue. Thanks
Hi RoshanAmal ,
Thank you for sharing the solution. This will greatly help the community with similar issues.
JC
