ADAS1000 CLK_IO to signal generator?
Hi
Qestion 1
If I configure the CLKEXT register to use the CLK_IO Pin as clock source can I then
simply attach my Signal Generator (DG1032Z) positive to CLK_IO and GND to GND
and select an 8.192 square wave? What signal level / voltage do I have to set? Is it
AVDD-GND?
Question 2
Is it true that the ADAS1000 only needs a clock via XTAL/CLK_IO while doing conversion?
So theoretically I could read/write to registers without any clock attached?
