I have an application for the AD9152 that needs only one of its DACs. The data sheet describes how to shut one down, but I can't find the expected reduction in power consumption that would result.
Strong EMC design
AD9152
Recommended for New Designs
The AD9152 is a dual, 16-bit, high dynamic range digital-to-analog converter (DAC) that provides a maximum sample rate of 2.25 GSPS, permitting a multicarrier...
Datasheet
AD9152 on Analog.com
Hi S2K ,
Thank you for using AD9152.
The AD9152 supports single-DAC operation by powering down the unused DAC and its clock using PdDACs and PdClocks. However, we do not have the expected power reduction for this configuration, so the actual savings would need to be measured under the intended operating conditions.
We should not assume that shutting down one DAC reduces the total device power by 50%, since shared circuitry such as the JESD204B interface, clocking, PLL, and other digital functions can remain active. For an accurate single-DAC power value, the consumption would need to be determined experimentally under your specific clock rate, JESD configuration, interpolation mode, and output-current setting.
Thanks and kind regards,
Alex
