AD9154-FMC-EBZ: digital sample code to output voltage?
Product Number: AD9154
Hi, I am using AD9154-FMC-EBZ board, driven by FPGA (ZCU102) logic.
Could you please let me know the relationship between the 16-bit input sample to DAC and the voltage measured at the analog output connector?
AD9154 is a current-output DAC
full-scale current & DAC digital gain are set to maximum values.
Thanks
  • Hi  ,
    Thank you for using AD9154.
    The 16-bit input sample controls the differential output current, not the output voltage directly. With maximum DAC gain, the full-scale output current is approximately 20 mA.
    The AD9154 itself produces current, so the voltage measured at the AD9154-FMC-EBZ connector is determined by the board's output termination/transformer network:
    where DACCODE = 0 to 2N − 1 and is the digital signal input to a DAC core consisting of a stream of 16-bit samples.
    Therefore, the digital-code-to-current relationship comes directly from the DAC, while the current-to-voltage relationship must include the AD9154-FMC-EBZ output circuit.
    Thanks and kind regards,
    Alex
  • Hi
    Thank you for your reply
    Could you please let me know "the current-to-voltage relationship must include the AD9154-FMC-EBZ output circuit."?
    Thanks
