Hello ADI Support Team,
We are currently evaluating the AD9177 DAC and are experiencing issues with its Noise Spectral Density (NSD) performance. Our measurements show a noise floor that is much higher than we expected based on the datasheet.
Problem Details:
Problem Details:
Measured NSD: In the DC to 20 MHz frequency range, we are measuring an NSD of approximately -140 dBm.
Datasheet Expectation: While the datasheet for the AD9177 doesn't specify an exact NSD value for this low-frequency range, inferring from the performance plots, we would expect it to be significantly better than -164 dBc/Hz. The discrepancy between our measurement and the expected performance is very large.
Our Test Setup:
Device: AD9177
DAC Mode: JMOD 15C
Output Signal: A single-tone signal.
Sample Rate (Fs): 12 GSPS
Physical Connection: The DAC output is DC-coupled and measured single-endedly directly into a spectrum analyzer.
Instrument: Spectrum Analyzer (Our instrument's noise floor is below -150 dBm).
Analyzer Settings: RBW is set to 1 Hz.
Our Questions:
Is our test methodology—specifically the DC-coupled, single-ended measurement—a valid way to assess the true noise performance of the AD9177?
If our test method is flawed, could you please provide or point us to the recommended test procedure for accurately measuring the NSD?
Could you also help confirm the expected typical NSD performance (in either dBm/Hz or dBc/Hz) for the AD9177 in the low-frequency band (e.g., DC to 20 MHz)?
Any guidance you could provide would be greatly appreciated.
Thank you.
