KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
AD9705
Production
The AD9704/AD9705/AD9706/AD9707 are the fourth-generation family in the TxDAC series of high performance, CMOS digital-to-analog converters (DACs). This...
Datasheet
AD9705 on Analog.com
AD9705's datasheet defines the Output Compliance Range as shown below,
And in the Table it is mentioned that the Output compliance range is of 0.8V for 2mA Ioutfs. I have attached the image below for reference. As per the definition provided for the Output
However, again in the Theory of Operation, it is written as, 1V for 2mA and it gets degraded to 0.8V for 1mA. I have attached the text below.
With this context, I am confused with the choice of Rload. My desired operation requires +-1V output swing. I choose 16K Ohm as FSADJ to achieve 2mA current and 500Ohm as the shunt resistors from IoutA and IoutB to ground to get +-1V (2mA * 500Ohm). I have attached the schematic below for reference.
Will this choice of resistances, give me the desired +-1V swing (I would use a differential OpAmp to make it single ended which I have not shown.)? Or 0.8V as per the datasheet table?
If the OTCM pin is connected to ground, those resistor values should give you a +/- 1-V swing at the differential output which would still be within the compliance range. However, since the negative swing is already at the AD9705's absolute maximum, we recommend using a safer load resistance at each of the complementary outputs such that the output is well within compliance.
Zaeefa
