Hi everyone
When testing the initial phase of the AD9171 output signal over multiple power supply cycles, I found that the initial phase of the AD9171 output signal was different for each power supply cycle.
Based on this phenomenon I don't think I can get deterministic delays using the default startup sequence provided in the AD9171 datasheet.
If I want the AD9171 to get the same signal initial phase every power cycle with the same input baseband signal what factors should I consider?
Any reply will be helpfull ,Thank you.
