When i feed the DAC with a periodic sequence of DB[11:0] values for the I channel, it generates the AC signal and i can see it in the oscilloscope as expected in the I channel output. All good.
Now, If i put a static value as data for the Q channel, let's say DB[11:0] = 0x638, i expect to this code to be changed to a fix voltage value and see this value in the oscilloscope as a constant DC signal.
Yet that is not the case, the output of this static code value is not shown and all i see is a zero value in the output of the Q channel.
Am i missing some DAC configuration?
Of couse these I and Q values are double data rate interleaved at the DB input port.
Thank you for the help you can provide,
better clarification of the problem
[edited by: stefaniecg at 8:50 AM (GMT -4) on 12 Aug 2024]
