Hello.
Evaluation board AD9736-DPG2-EBZ has SMA connector J3. It's connected via solder jumper to transformer T1. Please tell what is purpose of this connector if spectrum analyzer connects to other SMA Connector J2? Thanks.
AD9736
Production
The AD9736, AD9735, and AD9734 are high performance, high frequency DACs that provide sample rates of up to 1200 MSPS, permitting multicarrier generation...
Datasheet
AD9736 on Analog.com
Hello.
Hi ValentinB ,
Thank you for your interest in AD9736. We'll look into this and get back to you as soon as possible.
Zaeefa
The highlighted JP1 connection provides a ground connection for T1 so output observed at J2 is single-ended.
If jumper JP1 position is switched (1-2) than the DAC output signal is provided as differential output with both J2 and J3 connectors.
