Does the Eval board for AD9744 work only with the SPD-H1 or am I able to use it on a Xilinx dev board?
AD9744
Production
The AD97441 is a 14-bit resolution, wideband, third generation member of the TxDAC series of high performance, low power CMOS digital-to-analog converters...
Datasheet
AD9744 on Analog.com
Hi mmee ,
The AD9744 evaluation board is an FMC form-factor board with FMC connector compatible to the Vita 57.1 standard. You may use any FPGA board with FMC connector but you will also have to make your own FPGA code. The SDP-H1 board is a compatible board with the AD9744 for using the ACE software.
More details of evaluating the AD9744 using ACE can be found in this link: Evaluating The AD9740/AD9742/AD9744/AD9748 Digital-To-Analog Converters.
Marco
Hi mmee ,
Marco
