Hi Sir,
I am designing the PCB layout for LTC2000. The reference layout design is shown with 8Layer with HDI VIAs(Blind and buried). Is it a must to use 8L with HDI VIAs?
Do you see any challenges/concerns in the below layout design? The objective is to reduce PCB cost by using 6Layer and Through hole VIA.
1. Using 6 Layer PCB stack up
2. 17 Pairs in the Top layer directly connecting to FPGA and 17 Pairs in the bottom layer with through hole VIA to FPGA.
3. Top layer 17 Pairs (No VIA) vs. bottom layer 17 Pairs (2 VIA, Exit near LTC2000 and Entry near FPGA). Do all Pairs need a systematical VIA count?. (Within the Diff pair,# VIA, and routing are symmetrical)
The image is attached for reference (Length match to be done).Right side is no VIA (Top layer) , Left side has VIA (Bottom layer)
N.Raghavan
