How many is LTC2000 dac output COMMON MODE VOLTAGE?
Thanks!
LTC2000
Production
The LTC2000 is a family of 16-/14-/11-bit 2.5Gsps current steering DACs with exceptional spectral purity.
The single (1.25Gsps mode) or dual (2.5Gsps mode...
Datasheet
LTC2000 on Analog.com
Thanks!
Hi applo168 ,
Thank you for your patience.
The output common-mode voltage of the LTC2000 can be estimated by taking half of IOUTFS [i.e., ICM = (IOUTFS/2) + IOUTCM] and multiplying the resulting value with RLOAD. Kindly refer to p. 25 of the datasheet for the related formulas. Note that IOUTCM is a small value (0.2% of full-scale) added on top of both IOUTP and IOUTN and is different from ICM. Moreover, the output compliance range of the LTC2000 is -1 V to +1 V, which means the common-mode voltage plus/minus the peak signal swing should be within this range.
Zaeefa
Hi applo168 ,
Zaeefa
