Does anyone know what limits the file size for a custom vector file for the ACE software and AD9736? I want to generate a data stream creating FSK modulated RF signal.
AD9736
Production
The AD9736, AD9735, and AD9734 are high performance, high frequency DACs that provide sample rates of up to 1200 MSPS, permitting multicarrier generation...
Datasheet
AD9736 on Analog.com
JNewman - Moved from RF and Microwave to High-Speed DACs. Post date updated from Wednesday, January 3, 2024 9:07 PM UTC to Wednesday, January 3, 2024 9:08 PM UTC to reflect the move.
Hi JNewman ,
Thank you for your interest in AD9736.
Your query is acknowledged and will be provided with a response soon.
Zaeefa
Hi JNewman ,
The EVAL-AD9736 supported SDP-H1 and ADS7-V2EBZ as data pattern generator. The file size limit depends on the memory size of data pattern generator board used. For the SDP-H1 that's 64MB and the ADS7-V2 about 4GB x 2 DDR3. For limitation, .NET has an upper limit on the size of objects which is 2 GB (1GB I/Q).
For data pattern generation guide, you can refer to here: DPGDownloader [Analog Devices Wiki]
Best Regards,
Def
