About the DAC Clock Input
Product Number: AD9739
Dear Sir,
      About the AD9739 datasheet in Page 5 ,it is said that DAC CLOCK INPUT is 1.2Vpp to 2.0Vpp(type 1.6Vpp),but when use ADCLK914 as a clk buffer ,the DAC CLK input is about 3Vpp,could you help to explain that?
Best Regards!
     Gang
Parents Reply
  • Hi  ,
    Apologies for not getting back to you sooner.
    The output signal from the ADCLK914 becomes acceptable for the AD9739 clock inputs when the losses due to PCB traces and impedance mismatches are accounted for. The high voltage swing from the clock buffer is typically desired as it helps ensure that the DAC's minimum required differential swing of 1.2 Vpp is satisfied.
    Zaeefa
Children
