DPG + ADS7 + AD9162 Demo met XfetTimeOut error
Hi, All
When I used ADS7-V2 + DPG Downloader + AD9162 demo, I met the XferTimeOut issue, any body can help?
1. I use ACE configure AD9162 Demo into NCO only mode (DC_TEST), it works fine, AD9162 can output the signal which I want;
2. But when I confugre AD9162 into Serdes mode (x4,clock=4.8GSPS, Lane rate=6GSPS), when the DPG Downlaoder download the vector data into ADS7 board, I met the XferTimeOut issue;
Pls see below pic:
And the error Log as below, any one pls help me solve this problem?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Exception: Write error: XferQueueFull
at AnalogDevices.DPG.Hardware.ADS72.Drivers.Driver.ADS7.USB.CSA_USB.Write(Byte[] data)
at AnalogDevices.DPG.Hardware.ADS72.Drivers.Driver.ADS7.USB.CSA_USB.SDPCommand(sdp_Command Command, UInt32 DownByteCount, UInt32 UpByteCount, Boolean ExpectResponse, UInt32 NumParam, UInt32[] ParamArray, Byte[] DownBytes)
at AnalogDevices.DPG.Hardware.ADS72.Drivers.Driver.ADS7.Ads7FpgaRegIoBlackfin.ReadRegister(UInt32 reg)
at AnalogDevices.DPG.Ads7SeriesCommon.Jesd204.Ads7FpgaPagedRegIo.ReadRegister(Int32 framerNum, UInt32 reg)
at AnalogDevices.DPG.Ads7SeriesCommon.Jesd204.TxSubSystemController.get_EnableTx()
at AnalogDevices.DPG.Hardware.ADS72.FmcCores.Jesd204.Ads7SeriesJesd204Tx.get_Enable()
at AnalogDevices.DPG.Hardware.ADS72.Ads7SeriesJesd204.get_EnableTx()
at AnalogDevices.DPG.EvalBoard.AD9162.GenericUserInterfaceDirect.PostVectorDownloadHandling(Boolean isCancel)
at AnalogDevices.DPG.EvalBoard.AD9162.GenericUserInterfaceDirect.<button_download_Click>b__7(Object sender1, RunWorkerCompletedEventArgs e1)
at System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
at System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.9174 (WinRelRS6.050727-9100)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
DPGDownloader
Assembly Version: 1.3.77.0
Win32 Version: 1.3.77.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/DPGDownloader.exe
System.ServiceModel
Assembly Version: 3.0.0.0
Win32 Version: 3.0.4506.9149 (WinRelRS6.030729-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System
Win32 Version: 2.0.50727.9171 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
Win32 Version: 2.0.50727.9149 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SMDiagnostics
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Configuration
Win32 Version: 2.0.50727.9153 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Transactions
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Web
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.IdentityModel
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.IdentityModel/3.0.0.0__b77a5c561934e089/System.IdentityModel.dll
System.WorkflowServices
Assembly Version: 3.5.0.0
Win32 Version: 3.5.594.9141
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.WorkflowServices/3.5.0.0__31bf3856ad364e35/System.WorkflowServices.dll
System.ServiceModel.Web
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel.Web/3.5.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
AnalogDevices.DPG.Interfaces
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Interfaces/1.3.0.0__dae3bdf11808289b/AnalogDevices.DPG.Interfaces.dll
AnalogDevices.Vector.Common
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.Vector.Common/1.1.0.0__dae3bdf11808289b/AnalogDevices.Vector.Common.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Core
Win32 Version: 3.5.30729.9141 built by: WinRelRS6
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Hardware.ADS7/1.0.2.0__dae3bdf11808289b/AnalogDevices.DPG.Hardware.ADS7.dll
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Hardware.ADS72/1.0.0.0__dae3bdf11808289b/AnalogDevices.DPG.Hardware.ADS72.dll
AnalogDevices.DPG.Hardware.DPG2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Hardware.DPG2/1.1.0.0__dae3bdf11808289b/AnalogDevices.DPG.Hardware.DPG2.dll
AnalogDevices.DPG.Hardware.DPG3
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Hardware.DPG3/1.0.2.0__dae3bdf11808289b/AnalogDevices.DPG.Hardware.DPG3.dll
AnalogDevices.DPG.Hardware.DPGIO
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Hardware.DPGIO/1.1.0.0__dae3bdf11808289b/AnalogDevices.DPG.Hardware.DPGIO.dll
AnalogDevices.DPG.Hardware.SDPH1
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Hardware.SDPH1/1.0.2.0__dae3bdf11808289b/AnalogDevices.DPG.Hardware.SDPH1.dll
NationalInstruments.VisaNS
Assembly Version: 8.9.35.108
Win32 Version: 8.9.35.108
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/NationalInstruments.VisaNS/8.9.35.108__18cbae0f9955702a/NationalInstruments.VisaNS.dll
NationalInstruments.Common
Assembly Version: 9.1.35.159
Win32 Version: 9.1.35.159
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/NationalInstruments.Common/9.1.35.159__18cbae0f9955702a/NationalInstruments.Common.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/AnalogDevices.DPG.Ads7SeriesCommon/1.0.0.0__dae3bdf11808289b/AnalogDevices.DPG.Ads7SeriesCommon.dll
AnalogDevices.DPG.EvalBoard.AD9122
Assembly Version: 1.3.17.0
Win32 Version: 1.3.17.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9122.DLL
AnalogDevices.DPG.EvalBoard.AD9129
Assembly Version: 1.3.15.0
Win32 Version: 1.3.15.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9129.DLL
AnalogDevices.DPG.EvalBoard.AD9142
Assembly Version: 1.3.14.0
Win32 Version: 1.3.14.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9142.DLL
AnalogDevices.DPG.EvalBoard.AD9146
Assembly Version: 1.3.13.0
Win32 Version: 1.3.13.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9146.DLL
AnalogDevices.DPG.EvalBoard.AD9148
Assembly Version: 1.3.9.0
Win32 Version: 1.3.9.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9148.DLL
Assembly Version: 1.3.45.0
Win32 Version: 1.3.45.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9162.DLL
AnalogDevices.DPG.EvalBoard.AD9172
Assembly Version: 1.3.40.0
Win32 Version: 1.3.40.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9172.DLL
AnalogDevices.DPG.EvalBoard.AD9707
Assembly Version: 1.3.8.0
Win32 Version: 1.3.8.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9707.DLL
AnalogDevices.DPG.EvalBoard.AD9717
Assembly Version: 1.3.12.0
Win32 Version: 1.3.12.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9717.DLL
AnalogDevices.DPG.EvalBoard.AD9736
Assembly Version: 1.3.10.0
Win32 Version: 1.3.10.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9736.DLL
AnalogDevices.DPG.EvalBoard.AD9739
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9739.DLL
AnalogDevices.DPG.EvalBoard.AD9739A
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9739A.DLL
AnalogDevices.DPG.EvalBoard.AD9747
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9747.DLL
AnalogDevices.DPG.EvalBoard.AD9779A
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9779A.DLL
AnalogDevices.DPG.EvalBoard.AD9783
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9783.DLL
AnalogDevices.DPG.EvalBoard.AD9788
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9788.DLL
AnalogDevices.DPG.EvalBoard.AD9789
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9789.DLL
AnalogDevices.DPG.EvalBoard.AD9963
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9963.DLL
AnalogDevices.DPG.EvalBoard.AD9993
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.AD9993.DLL
AnalogDevices.DPG.EvalBoard.Generic
Assembly Version: 1.0.6697.30503
Win32 Version: 1.0.6697.30503
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.Generic.DLL
AnalogDevices.DPG.EvalBoard.JESD204B1
Assembly Version: 1.3.51.0
Win32 Version: 1.3.51.0
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.DPG.EvalBoard.JESD204B1.DLL
NationalInstruments.UI.WindowsForms
Assembly Version: 9.1.35.204
Win32 Version: 9.1.35.204
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/NationalInstruments.UI.WindowsForms.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/NationalInstruments.UI.DLL
NationalInstruments.Common.default
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/NationalInstruments.Common.default/9.1.35.159__18cbae0f9955702a/NationalInstruments.Common.default.dll
AnalogDevices.Vector.Generator.Chirp
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.Vector.Generator.Chirp.DLL
AnalogDevices.Vector.Generator.CIFR
Assembly Version: 1.0.6628.29109
Win32 Version: 1.0.6628.29109
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.Vector.Generator.CIFR.DLL
AnalogDevices.Vector.AdvancedVectorGenerator
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.Vector.AdvancedVectorGenerator.DLL
AnalogDevices.Vector.Generator.DC
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.Vector.Generator.DC.DLL
AnalogDevices.Vector.Generator.Noise
Assembly Version: 1.0.6628.29110
Win32 Version: 1.0.6628.29110
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.Vector.Generator.Noise.DLL
AnalogDevices.Vector.Generator.Tones
Assembly Version: 1.0.6628.29111
Win32 Version: 1.0.6628.29111
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.Vector.Generator.Tones.DLL
NationalInstruments.Analysis.Enterprise
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/NationalInstruments.Analysis.Enterprise.DLL
AnalogDevices.Vector.Generator.WIFR
CodeBase: file:///C:/Program%20Files%20(x86)/Analog%20Devices/DPG/AnalogDevices.Vector.Generator.WIFR.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thread Notes
