We are using the AD9081-FMCA-EBZ to evaluate the AD9177.
We are interested in tone generation with FFH from the AD9081-FMCA-EBZ board and are using a Zedboard to control the AD9081 onboard the AD9081-FMCA-EBZ.
After setting up all 4 main NCOs to different frequencies (3 different channels used by each DAC, to generate a total of 12 tones), we configure the FFH feature for control via GPIO. We wish to FFH on each NCO between two frequencies, at independent modulation frequencies (effectively FM square modulation on each of the 4 main NCOs).
In this example, we DAC0 / NCO0 is set to 2.86 GHz and DAC1 / NCO1 is set to 2.96 GHz. If we observe the DAC0 output, we can see the signal on the spectrum analyser.
We then enable the modulation signal for this DAC, and alternate between the main NCO frequency and the first hop frequency at every rising edge of a 1950 Hz square wave. This is readily observed in the spectrum where the side bands are separated by 1950/2, and seems to work fine.
However, if we then also enable modulation signal (of frequency 2704 Hz) intended for the DAC1/NCO and FFH DAC1 as well as DAC0, we observe the DAC0 output signal is affected/corrupted as shown below.
Now to examine the control signals being fed into the FFH GPIO pins. We have had to separate the example over two traces due to the limitation of 4 channels on our scope. The first trace shows the strobe, paging, and two input modulation signals that trigger the FFH signals. The second trace shows the FTW control signal instead of the paging signal. (Only the LSB of the paging is shown as we are only performing FFH on DAC0 and DAC1, and only the LSB of the FTW select control word is shown as we are only going between the main NCO frequency and the first hop frequency. All unused inputs, DAC_NCO_FFH1,3,4,5,6 are all low.) As seen in the first trace, we only page DAC 0 on every rising edge of the DAC 0 modulation signal.
The trace below is a zoomed, which better shows the timing of the signals.
For completeness, I have also attached below the log with all the register writes before these traces were captured.
To summarise, we want to know why our DAC0 output is being corrupted when performing FFH on both DAC0 and DAC1.
Any help, suggestions or example traces would be greatly appreciated.
Hope to hear from you soon,
Kind Regards
MESSAGE: adi_ad9177_device_reset(...) MESSAGE: adi_ad9177_device_init(...) MESSAGE: api v1.5.0 commit 4d11467 for ad9177 MESSAGE: host is using little endian mode. MESSAGE: adi_ad9177_device_spi_config(...) MESSAGE: ad9177: w@0 = 3C MESSAGE: adi_ad9177_device_reg8_access_check(...) MESSAGE: ad9177: r@801C = FF MESSAGE: ad9177: w@1C = 5A MESSAGE: ad9177: r@801C = 5A MESSAGE: ad9177: w@1C = A5 MESSAGE: ad9177: r@801C = A5 MESSAGE: ad9177: w@1C = FF MESSAGE: adi_ad9177_device_power_status_check(...) MESSAGE: ad9177: r@8210 = 3F MESSAGE: ad9177: r@8211 = F MESSAGE: ad9177: r@8212 = 3F MESSAGE: ad9177: r@8213 = 3F initialiseHMC7044 R1 = 0, N1 = 2, R2 = 0, N2 = 2 hmc_pll_locked = 2HMC7044 Setup Complete MESSAGE: adi_ad9177_device_reset(...) MESSAGE: ad9177: w@0 = 81 MESSAGE: ad9177: w@0 = 0 MESSAGE: adi_ad9177_device_init(...) MESSAGE: api v1.5.0 commit 4d11467 for ad9177 MESSAGE: host is using little endian mode. MESSAGE: adi_ad9177_device_spi_config(...) MESSAGE: ad9177: w@0 = 3C MESSAGE: adi_ad9177_device_reg8_access_check(...) MESSAGE: ad9177: r@801C = FF MESSAGE: ad9177: w@1C = 5A MESSAGE: ad9177: r@801C = 5A MESSAGE: ad9177: w@1C = A5 MESSAGE: ad9177: r@801C = A5 MESSAGE: ad9177: w@1C = FF MESSAGE: adi_ad9177_device_power_status_check(...) MESSAGE: ad9177: r@8210 = 3F MESSAGE: ad9177: r@8211 = F MESSAGE: ad9177: r@8212 = 3F MESSAGE: ad9177: r@8213 = 3F MESSAGE: adi_ad9177_device_clk_config_set(...) MESSAGE: adi_ad9177_device_boot_pre_clock(...) MESSAGE: ad9177: r@B742 = 71 MESSAGE: adi_ad9177_device_chip_id_get(...) MESSAGE: ad9177: r@8003 = F MESSAGE: ad9177: r@8004 = 81 MESSAGE: ad9177: r@8005 = 90 MESSAGE: ad9177: r@8006 = A3 MESSAGE: device is ad9081 r3 MESSAGE: adi_ad9177_device_laminate_id_get(...) MESSAGE: ad9177: r@9E0D = 14 MESSAGE: adi_ad9177_device_die_id_get(...) MESSAGE: ad9177: r@9E0E = 87 MESSAGE: ad9177: r@A1B2 = 0 MESSAGE: ad9177: w@21B2 = 10 MESSAGE: adi_ad9177_device_digital_logic_enable_set(...) MESSAGE: ad9177: r@8201 = 1 MESSAGE: ad9177: w@201 = 0 MESSAGE: ad9177: w@D0 = 1F MESSAGE: adi_ad9177_device_aclk_receiver_enable_set(...) MESSAGE: ad9177: r@8091 = 0 MESSAGE: ad9177: w@91 = 0 MESSAGE: adi_ad9177_device_clk_pll_enable_set(...) MESSAGE: ad9177: r@8094 = 0 MESSAGE: ad9177: w@94 = 1 MESSAGE: ad9177: w@E0 = 9F MESSAGE: ad9177: w@E1 = 1F MESSAGE: adi_ad9177_device_clk_pll_startup(...) MESSAGE: adi_ad9177_device_clk_pll_enable_set(...) MESSAGE: ad9177: r@8094 = 1 MESSAGE: ad9177: w@94 = 0 MESSAGE: ad9177: w@E0 = 0 MESSAGE: ad9177: w@E1 = 0 MESSAGE: adi_ad9177_device_clk_pll_div_set(...) MESSAGE: ad9177: w@FE = FC MESSAGE: ad9177: r@80FF = 5 MESSAGE: ad9177: w@FF = 3 MESSAGE: ad9177: w@FA = CE MESSAGE: ad9177: r@80FB = 2 MESSAGE: ad9177: w@FB = 2 MESSAGE: ad9177: r@80E8 = 0 MESSAGE: ad9177: w@E8 = 1F MESSAGE: ad9177: r@80E7 = 80 MESSAGE: ad9177: w@E7 = A0 MESSAGE: ad9177: r@80E4 = 10 MESSAGE: ad9177: w@E4 = 13 MESSAGE: ad9177: r@80E6 = D0 MESSAGE: ad9177: w@E6 = C0 MESSAGE: ad9177: r@80E3 = 10 MESSAGE: ad9177: w@E3 = 8 MESSAGE: ad9177: w@E2 = 1F MESSAGE: ad9177: w@E2 = 0 MESSAGE: ad9177: r@80E3 = 8 MESSAGE: ad9177: w@E3 = 8 MESSAGE: ad9177: r@8093 = 0 MESSAGE: ad9177: w@93 = 0 MESSAGE: ad9177: r@80E9 = 8 MESSAGE: ad9177: w@E9 = 18 MESSAGE: ad9177: r@80EC = 26 MESSAGE: ad9177: w@EC = 6 MESSAGE: ad9177: r@80EE = 90 MESSAGE: ad9177: w@EE = 90 MESSAGE: ad9177: w@EA = 60 MESSAGE: ad9177: w@EB = 3D MESSAGE: ad9177: r@80E2 = 0 MESSAGE: ad9177: w@E2 = 2 MESSAGE: ad9177: r@80E2 = 2 MESSAGE: ad9177: w@E2 = 0 MESSAGE: adi_ad9177_device_clk_pll_lock_status_get(...) MESSAGE: ad9177: r@A008 = 3 MESSAGE: adi_ad9177_adc_clk_div_set(...) MESSAGE: ad9177: r@8180 = 0 MESSAGE: ad9177: w@180 = 1 MESSAGE: adi_ad9177_device_clk_up_div_set(...) MESSAGE: ad9177: r@80D0 = 1F MESSAGE: ad9177: w@D0 = 1F MESSAGE: ad9177: r@A1B3 = 0 MESSAGE: ad9177: w@21B3 = 3 MESSAGE: ad9177: r@A1B3 = 3 MESSAGE: ad9177: w@21B3 = 83 MESSAGE: ad9177: r@A1B4 = 0 MESSAGE: ad9177: w@21B4 = 2 MESSAGE: ad9177: r@A1B4 = 2 MESSAGE: ad9177: w@21B4 = 22 MESSAGE: ad9177: w@21B5 = F MESSAGE: ad9177: r@A1B3 = 83 MESSAGE: ad9177: w@21B3 = C3 MESSAGE: adi_ad9177_device_boot_post_clock(...) MESSAGE: ad9177: w@3743 = 1 MESSAGE: ad9177: r@BD26 = 0 MESSAGE: ad9177: w@3D26 = 8 MESSAGE: ad9177: r@BD26 = 0 MESSAGE: ad9177: r@B740 = E MESSAGE: ad9177: r@B740 = E MESSAGE: ad9177: r@B740 = E MESSAGE: ad9177: r@B740 = E MESSAGE: ad9177: r@B740 = E MESSAGE: ad9177: r@B740 = E MESSAGE: ad9177: r@B740 = E MESSAGE: ad9177: r@B740 = F MESSAGE: ad9177: r@B742 = FF MESSAGE: ad9177: r@B740 = F MESSAGE: ad9177: w@2112 = 1 MESSAGE: ad9177: r@80D1 = 0 MESSAGE: ad9177: w@D1 = 1 MESSAGE: ad9177: r@80D1 = 1 MESSAGE: ad9177: w@D1 = 11 MESSAGE: ad9177: r@80D1 = 11 MESSAGE: ad9177: w@D1 = 13 MESSAGE: ad9177: r@80D1 = 13 MESSAGE: ad9177: w@D1 = 33 MESSAGE: ad9177: w@1400 = D4 MESSAGE: ad9177: r@80D1 = 33 MESSAGE: ad9177: w@D1 = 32 MESSAGE: ad9177: r@80D1 = 32 MESSAGE: ad9177: w@D1 = 22 MESSAGE: ad9177: r@80D1 = 22 MESSAGE: ad9177: w@D1 = 20 MESSAGE: ad9177: r@80D1 = 20 MESSAGE: ad9177: w@D1 = 0 MESSAGE: ad9177: w@2112 = 0 MESSAGE: ad9177: r@80D1 = 0 MESSAGE: ad9177: w@D1 = 1 MESSAGE: ad9177: r@80D1 = 22 MESSAGE: ad9177: w@D1 = 32 MESSAGE: ad9177: r@9729 = 0 MESSAGE: ad9177: w@1729 = 0 MESSAGE: ad9177: r@80D1 = 11 MESSAGE: ad9177: w@D1 = 10 MESSAGE: ad9177: r@80D1 = 22 MESSAGE: ad9177: w@D1 = 22 MESSAGE: ad9177: r@80D1 = 11 MESSAGE: ad9177: w@D1 = 13 MESSAGE: ad9177: r@80D1 = 11 MESSAGE: ad9177: w@D1 = 31 MESSAGE: ad9177: r@9729 = 25 MESSAGE: ad9177: w@1729 = 24 MESSAGE: ad9177: r@80D1 = 0 MESSAGE: ad9177: w@D1 = 0 MESSAGE: ad9177: r@80D1 = 11 MESSAGE: ad9177: w@D1 = 11 MESSAGE: ad9177: w@D0 = 1F MESSAGE: adi_ad9177_adc_clk_enable_set(...) MESSAGE: ad9177: r@8180 = 5 MESSAGE: ad9177: w@180 = 5 MESSAGE: adi_ad9177_device_clk_pll_lock_status_get(...) MESSAGE: ad9177: r@A008 = 3 ad9177 PLL LOCKED MESSAGE: adi_ad9177_device_startup_nco_test(...) MESSAGE: adi_ad9177_device_startup_tx_or_nco_test(...) MESSAGE: adi_ad9177_dac_tx_enable_set(...) MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_power_up_set(...) MESSAGE: ad9177: r@8090 = 0 MESSAGE: ad9177: w@90 = 0 MESSAGE: adi_ad9177_dac_dll_startup(...) MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1F MESSAGE: ad9177: w@D0 = 1F MESSAGE: ad9177: r@8185 = 2 MESSAGE: ad9177: w@185 = 2 MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1F MESSAGE: ad9177: w@D0 = 1D MESSAGE: ad9177: r@8183 = 2A MESSAGE: ad9177: w@183 = 2A MESSAGE: ad9177: r@8184 = 2A MESSAGE: ad9177: w@184 = 2A MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1D MESSAGE: ad9177: w@D0 = 1E MESSAGE: ad9177: r@8183 = 2A MESSAGE: ad9177: w@183 = 2A MESSAGE: ad9177: r@8184 = 2A MESSAGE: ad9177: w@184 = 2A MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1E MESSAGE: ad9177: w@D0 = 1D MESSAGE: ad9177: r@8181 = 0 MESSAGE: ad9177: w@181 = 0 MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1D MESSAGE: ad9177: w@D0 = 1E MESSAGE: ad9177: r@8181 = 0 MESSAGE: ad9177: w@181 = 0 MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1E MESSAGE: ad9177: w@D0 = 1F MESSAGE: ad9177: r@8192 = 80 MESSAGE: ad9177: w@192 = 80 MESSAGE: adi_ad9177_dac_tx_enable_set(...) MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_fsc_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 41 MESSAGE: ad9177: w@118 = CA MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 41 MESSAGE: ad9177: w@118 = CA MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 41 MESSAGE: ad9177: w@118 = CA MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 40 MESSAGE: ad9177: r@8117 = 40 MESSAGE: ad9177: w@117 = 41 MESSAGE: ad9177: w@118 = CA MESSAGE: adi_ad9177_dac_run_startup_cal(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = F MESSAGE: ad9177: r@8199 = F MESSAGE: ad9177: w@199 = F MESSAGE: ad9177: r@810E = 28 MESSAGE: ad9177: w@10E = 28 MESSAGE: ad9177: r@8195 = 2 MESSAGE: ad9177: w@195 = 2 MESSAGE: ad9177: r@819C = 10 MESSAGE: ad9177: w@19C = FF MESSAGE: ad9177: r@810F = 82 MESSAGE: ad9177: w@10F = 2 MESSAGE: ad9177: r@810F = 2 MESSAGE: ad9177: w@10F = 82 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 6F MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 6F MESSAGE: ad9177: r@810F = 82 MESSAGE: ad9177: w@10F = 82 MESSAGE: ad9177: w@11D = 22 MESSAGE: ad9177: r@8127 = 68 MESSAGE: ad9177: w@127 = 69 MESSAGE: ad9177: w@128 = 11 MESSAGE: ad9177: w@129 = 11 MESSAGE: ad9177: w@12A = 11 MESSAGE: ad9177: w@12B = 11 MESSAGE: ad9177: w@12C = 11 MESSAGE: ad9177: w@12D = 11 MESSAGE: ad9177: w@12E = 11 MESSAGE: ad9177: w@12F = 1 MESSAGE: ad9177: r@810F = 82 MESSAGE: ad9177: w@10F = 83 MESSAGE: adi_ad9177_dac_r2r_cal_config_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@8111 = 1E MESSAGE: ad9177: w@111 = 17 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 17 MESSAGE: ad9177: w@111 = 18 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 18 MESSAGE: ad9177: w@111 = 19 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 19 MESSAGE: ad9177: w@111 = 1A MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1A MESSAGE: ad9177: w@111 = 1B MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1B MESSAGE: ad9177: w@111 = 1C MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1C MESSAGE: ad9177: w@111 = 1D MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1D MESSAGE: ad9177: w@111 = 1E MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 6F MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 6B MESSAGE: adi_ad9177_dac_r2r_cal_config_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@8111 = 1E MESSAGE: ad9177: w@111 = 17 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 17 MESSAGE: ad9177: w@111 = 18 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 18 MESSAGE: ad9177: w@111 = 19 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 19 MESSAGE: ad9177: w@111 = 1A MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1A MESSAGE: ad9177: w@111 = 1B MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1B MESSAGE: ad9177: w@111 = 1C MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1C MESSAGE: ad9177: w@111 = 1D MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1D MESSAGE: ad9177: w@111 = 1E MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 6F MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 6B MESSAGE: adi_ad9177_dac_r2r_cal_config_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@8111 = 1E MESSAGE: ad9177: w@111 = 17 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 17 MESSAGE: ad9177: w@111 = 18 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 18 MESSAGE: ad9177: w@111 = 19 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 19 MESSAGE: ad9177: w@111 = 1A MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1A MESSAGE: ad9177: w@111 = 1B MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1B MESSAGE: ad9177: w@111 = 1C MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1C MESSAGE: ad9177: w@111 = 1D MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1D MESSAGE: ad9177: w@111 = 1E MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 6F MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 6B MESSAGE: adi_ad9177_dac_r2r_cal_config_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 67 MESSAGE: ad9177: r@8111 = 1E MESSAGE: ad9177: w@111 = 17 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 17 MESSAGE: ad9177: w@111 = 18 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 18 MESSAGE: ad9177: w@111 = 19 MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 19 MESSAGE: ad9177: w@111 = 1A MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1A MESSAGE: ad9177: w@111 = 1B MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1B MESSAGE: ad9177: w@111 = 1C MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1C MESSAGE: ad9177: w@111 = 1D MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@8111 = 1D MESSAGE: ad9177: w@111 = 1E MESSAGE: ad9177: r@8112 = 4F MESSAGE: ad9177: w@112 = 4F MESSAGE: ad9177: r@810F = 83 MESSAGE: ad9177: w@10F = 8B MESSAGE: ad9177: r@810F = 8B MESSAGE: ad9177: w@10F = 83 MESSAGE: ad9177: r@811F = 67 MESSAGE: ad9177: w@11F = 6F MESSAGE: ad9177: r@811F = 6F MESSAGE: ad9177: w@11F = 6B MESSAGE: adi_ad9177_dac_interpolation_set(...) MESSAGE: ad9177: w@1FF = 82 MESSAGE: ad9177: r@81C8 = 0 MESSAGE: ad9177: w@1C8 = 0 MESSAGE: adi_ad9177_dac_xbar_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@81FF = 82 MESSAGE: ad9177: w@1BA = 7 MESSAGE: adi_ad9177_dac_xbar_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@81FF = 82 MESSAGE: ad9177: w@1BA = 7 MESSAGE: adi_ad9177_dac_xbar_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@81FF = 82 MESSAGE: ad9177: w@1BA = 7 MESSAGE: adi_ad9177_dac_xbar_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@81FF = 82 MESSAGE: ad9177: w@1BA = 7 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@81C9 = 0 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81C9 = 8 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: w@1CB = 64 MESSAGE: ad9177: w@1CC = 1D MESSAGE: ad9177: w@1CD = 2D MESSAGE: ad9177: w@1CE = 54 MESSAGE: ad9177: w@1CF = 1 MESSAGE: ad9177: w@1D0 = 3D MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 1 MESSAGE: ad9177: r@81CA = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@81C9 = 0 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81C9 = 8 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: w@1CB = 86 MESSAGE: ad9177: w@1CC = 3F MESSAGE: ad9177: w@1CD = 4F MESSAGE: ad9177: w@1CE = 76 MESSAGE: ad9177: w@1CF = 23 MESSAGE: ad9177: w@1D0 = 3F MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 1 MESSAGE: ad9177: r@81CA = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@81C9 = 0 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81C9 = 8 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: w@1CB = 37 MESSAGE: ad9177: w@1CC = 24 MESSAGE: ad9177: w@1CD = 67 MESSAGE: ad9177: w@1CE = C1 MESSAGE: ad9177: w@1CF = A1 MESSAGE: ad9177: w@1D0 = 40 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 1 MESSAGE: ad9177: r@81CA = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@81C9 = 0 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81C9 = 8 MESSAGE: ad9177: w@1C9 = 8 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: w@1CB = 78 MESSAGE: ad9177: w@1CC = CB MESSAGE: ad9177: w@1CD = 74 MESSAGE: ad9177: w@1CE = 35 MESSAGE: ad9177: w@1CF = 7C MESSAGE: ad9177: w@1D0 = 41 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 0 MESSAGE: ad9177: r@81CA = 0 MESSAGE: ad9177: w@1CA = 1 MESSAGE: ad9177: r@81CA = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 1 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 1 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 1 MESSAGE: ad9177: w@1A2 = 82 MESSAGE: ad9177: w@1A3 = B7 MESSAGE: ad9177: w@1A4 = 2D MESSAGE: ad9177: w@1A5 = B7 MESSAGE: ad9177: w@1A6 = A1 MESSAGE: ad9177: w@1A7 = FF MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 2 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 2 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 2 MESSAGE: ad9177: w@1A2 = 0 MESSAGE: ad9177: w@1A3 = 0 MESSAGE: ad9177: w@1A4 = 0 MESSAGE: ad9177: w@1A5 = 0 MESSAGE: ad9177: w@1A6 = 0 MESSAGE: ad9177: w@1A7 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 4 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 4 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 4 MESSAGE: ad9177: w@1A2 = 7E MESSAGE: ad9177: w@1A3 = 48 MESSAGE: ad9177: w@1A4 = D2 MESSAGE: ad9177: w@1A5 = 48 MESSAGE: ad9177: w@1A6 = 5E MESSAGE: ad9177: w@1A7 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 8 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 8 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 8 MESSAGE: ad9177: w@1A2 = 0 MESSAGE: ad9177: w@1A3 = 0 MESSAGE: ad9177: w@1A4 = 0 MESSAGE: ad9177: w@1A5 = 0 MESSAGE: ad9177: w@1A6 = 0 MESSAGE: ad9177: w@1A7 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 10 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 10 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 10 MESSAGE: ad9177: w@1A2 = 0 MESSAGE: ad9177: w@1A3 = 0 MESSAGE: ad9177: w@1A4 = 0 MESSAGE: ad9177: w@1A5 = 0 MESSAGE: ad9177: w@1A6 = 0 MESSAGE: ad9177: w@1A7 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 20 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 20 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 20 MESSAGE: ad9177: w@1A2 = 0 MESSAGE: ad9177: w@1A3 = 0 MESSAGE: ad9177: w@1A4 = 0 MESSAGE: ad9177: w@1A5 = 0 MESSAGE: ad9177: w@1A6 = 0 MESSAGE: ad9177: w@1A7 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 40 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 40 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 40 MESSAGE: ad9177: w@1A2 = 0 MESSAGE: ad9177: w@1A3 = 0 MESSAGE: ad9177: w@1A4 = 0 MESSAGE: ad9177: w@1A5 = 0 MESSAGE: ad9177: w@1A6 = 0 MESSAGE: ad9177: w@1A7 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_duc_nco_set(...) MESSAGE: ad9177: r@81FF = 82 MESSAGE: adi_ad9177_dac_duc_nco_enable_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 80 MESSAGE: ad9177: r@81A0 = 0 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw(...) MESSAGE: adi_ad9177_dac_duc_nco_ftw_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 80 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 40 MESSAGE: adi_ad9177_dac_duc_nco_ftw0_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 80 MESSAGE: ad9177: w@1A2 = 0 MESSAGE: ad9177: w@1A3 = 0 MESSAGE: ad9177: w@1A4 = 0 MESSAGE: ad9177: w@1A5 = 0 MESSAGE: ad9177: w@1A6 = 0 MESSAGE: ad9177: w@1A7 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 0 MESSAGE: ad9177: r@81A1 = 0 MESSAGE: ad9177: w@1A1 = 1 MESSAGE: ad9177: r@81A1 = 3 MESSAGE: adi_ad9177_dac_soft_off_gain_enable_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8300 = 8 MESSAGE: ad9177: w@300 = 8 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8300 = 8 MESSAGE: ad9177: w@300 = 8 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8300 = 8 MESSAGE: ad9177: w@300 = 8 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8300 = 8 MESSAGE: ad9177: w@300 = 8 MESSAGE: adi_ad9177_dac_tx_enable_set(...) MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_spi_as_tx_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8321 = C MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = 4 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8321 = 4 MESSAGE: ad9177: w@321 = C MESSAGE: adi_ad9177_dac_shuffle_enable_set(...) MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1F MESSAGE: ad9177: w@D0 = 1F MESSAGE: ad9177: r@8140 = 0 MESSAGE: ad9177: w@140 = 11 MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1F MESSAGE: ad9177: w@D0 = 1F MESSAGE: adi_ad9177_dac_data_xor_set(...) MESSAGE: ad9177: r@80C3 = 0 MESSAGE: ad9177: w@C3 = F0 MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1F MESSAGE: ad9177: w@D0 = 1D MESSAGE: ad9177: r@8187 = 0 MESSAGE: ad9177: w@187 = 44 MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1D MESSAGE: ad9177: w@D0 = 1E MESSAGE: ad9177: r@8187 = 0 MESSAGE: ad9177: w@187 = 44 MESSAGE: adi_ad9177_dac_d2a_dual_spi_enable_set(...) MESSAGE: ad9177: r@80D0 = 1E MESSAGE: ad9177: w@D0 = 1F MESSAGE: adi_ad9177_dac_irqs_enable_set(...) MESSAGE: ad9177: w@20 = 0 MESSAGE: ad9177: w@21 = CC MESSAGE: ad9177: w@22 = CC MESSAGE: ad9177: w@23 = 30 MESSAGE: ad9177: w@24 = 0 MESSAGE: ad9177: r@81FE = 80 MESSAGE: ad9177: w@1FE = 90 MESSAGE: ad9177: r@855E = 0 MESSAGE: ad9177: w@55E = 80 MESSAGE: adi_ad9177_dac_duc_main_dc_test_tone_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@81E9 = 0 MESSAGE: ad9177: w@1E9 = 0 MESSAGE: adi_ad9177_dac_duc_main_dc_test_tone_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@81E9 = 0 MESSAGE: ad9177: w@1E9 = 0 MESSAGE: adi_ad9177_dac_duc_main_dc_test_tone_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@81E9 = 0 MESSAGE: ad9177: w@1E9 = 0 MESSAGE: adi_ad9177_dac_duc_main_dc_test_tone_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@81E9 = 0 MESSAGE: ad9177: w@1E9 = 0 MESSAGE: adi_ad9177_dac_dc_test_tone_en_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 1 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 41 MESSAGE: adi_ad9177_dac_dc_test_tone_offset_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 1 MESSAGE: ad9177: w@1B6 = A0 MESSAGE: ad9177: w@1B7 = 16 MESSAGE: adi_ad9177_dac_dc_test_tone_en_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 2 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 41 MESSAGE: adi_ad9177_dac_dc_test_tone_offset_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 2 MESSAGE: ad9177: w@1B6 = A0 MESSAGE: ad9177: w@1B7 = 16 MESSAGE: adi_ad9177_dac_dc_test_tone_en_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 4 MESSAGE: ad9177: r@81A0 = 40 MESSAGE: ad9177: w@1A0 = 41 MESSAGE: adi_ad9177_dac_dc_test_tone_offset_set(...) MESSAGE: adi_ad9177_dac_chan_select_set(...) MESSAGE: ad9177: w@1C = 4 MESSAGE: ad9177: w@1B6 = A0 MESSAGE: ad9177: w@1B7 = 16 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw32(...) MESSAGE: adi_ad9177_dac_duc_main_nco_hopf_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: w@806 = A8 MESSAGE: ad9177: w@807 = B2 MESSAGE: ad9177: w@808 = 5 MESSAGE: ad9177: w@809 = 3D MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw32(...) MESSAGE: adi_ad9177_dac_duc_main_nco_hopf_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: w@806 = CA MESSAGE: ad9177: w@807 = D4 MESSAGE: ad9177: w@808 = 27 MESSAGE: ad9177: w@809 = 3F MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw32(...) MESSAGE: adi_ad9177_dac_duc_main_nco_hopf_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: w@806 = E2 MESSAGE: ad9177: w@807 = 1F MESSAGE: ad9177: w@808 = A6 MESSAGE: ad9177: w@809 = 40 MESSAGE: adi_ad9177_hal_calc_tx_nco_ftw32(...) MESSAGE: adi_ad9177_dac_duc_main_nco_hopf_ftw_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: w@806 = EF MESSAGE: ad9177: w@807 = 93 MESSAGE: ad9177: w@808 = 80 MESSAGE: ad9177: w@809 = 41 MESSAGE: adi_ad9177_jesd_rx_syncb_mode_set(...) MESSAGE: ad9177: r@842A = 0 MESSAGE: ad9177: w@42A = 0 MESSAGE: adi_ad9177_dac_duc_main_nco_hopf_gpio_as_hop_en_set(...) MESSAGE: ad9177: w@38 = 13 MESSAGE: ad9177: w@35 = 3 MESSAGE: ad9177: w@36 = 33 MESSAGE: ad9177: w@37 = 22 MESSAGE: ad9177: r@8801 = 0 MESSAGE: ad9177: w@801 = 1 MESSAGE: adi_ad9177_dac_duc_main_nco_hopf_gpio_no_glitch_en_set(...) MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 1 MESSAGE: ad9177: r@8800 = 0 MESSAGE: ad9177: w@800 = 20 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 2 MESSAGE: ad9177: r@8800 = 0 MESSAGE: ad9177: w@800 = 20 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 4 MESSAGE: ad9177: r@8800 = 0 MESSAGE: ad9177: w@800 = 20 MESSAGE: adi_ad9177_dac_select_set(...) MESSAGE: ad9177: w@1B = 8 MESSAGE: ad9177: r@8800 = 0 MESSAGE: ad9177: w@800 = 20 MESSAGE: adi_ad9177_jesd_rx_syncb_driver_powerdown_set(...) MESSAGE: ad9177: r@8402 = 1 MESSAGE: ad9177: w@402 = 0 MESSAGE: ad9177: w@44B = 0
