AD9786 SPI timing
Category: Datasheet/Specs
Product Number: AD9786
Reference AD9786.pdf datasheet Rev. B, 2005
The data sheet does not include numbers for the setup and hold values for the SPI data lines and chip select.  Only the maximum serial clock frequency is given (20MHz).  Setup and hold times are shown as variables on the timing diagram but no values are provided.
on Sep 7, 2023 12:57 PM
Thanks, Gdms for the question. and very sorry for the delay due to the shutdown.
according to the datasheet on Page 20, CSB must be low during the entire communication cycle.
Since the communication cycle will vary based on how you configured the instruction byte on page 20 ( Like N1 and N0 in Table10 will config the number of bytes to be read or written during every cycle )
Using Fig 39 and 40 the data holding time is based on your SCLK speed (with a period of Tsclk)
Tds =  the time from CSB falling  edge to the next rising clock edge where the Instruction bit 7 will be sampled until the falling edge of the clock ==> Data holding time should be more than Tsclk/2 but less than the next rising clock edge
In other words, make sure to sample the Data lines on every rising edge
I hope that was helpful. please let me know if you still have questions.
Adam
  • I am looking for the minimum value of Tds.  Is it 10nSec, 20nSec, 30nSec?  Other ADI data sheets provide a number in nano seconds for data setup time.
  • FormerMember
    0 FormerMember on Sep 7, 2023 5:22 PM in reply to FormerMember
    The AD9786 uses the same DAC and SPI core at the AD978x products in which the SPI timing is provided in the datasheet.
  • Thank you for the data.  The table brings up a question regarding the maximum frequency of SCLK.
    If the SPI cores are the same in the AD978x devices, why is SCLK max 20MHz in the AD9786 data sheet and 40MHz in the table above?
