AD9172
I am debugging the AD9172. I use two DDS to generate two ch IQ signals directly, and concat the signals to drive the DAC.  The tx_core_clk is 245MHz, the equivalent data rate is 245*4=980MHz.  The Channel NCO is bypassed and the Main NCO is set to 500MHz.
Observe the signal on the Spectrum analyzer, when the DDS frequency set to 34MHz(output signal is 534MHz),  I can see two spurious at 534+12MHz and 534-12MHz. When I change the frequency ,  I can see signal and spurious below:
Frequency      spurious
533 MHz       ±34 MHz
534 MHz       ±12 MHz
534.5 MHz      ±1 MHz
535 MHz       ±10 MHz
536 MHz       ±32 MHz
537 MHz       ±54MHz
I want to know where these spurious come from and how to remove them.
