Our customer has trouble using ADS7-V2EBZ.
The phenomenon is the following.
Conditions
ADS7-V2EBZ revision : D
Evaluation board : AD9162-FMCC-EBZ
ACE version : 1.26.3240.1417
DPG-Lite version : 1.19.187.0
Phenomenon
- He connected AD9162-FMCC-EBZ to ADS7-V2EBZ.
- Power on ADS7-V2EBZ and he could see the fan, which is mounted on FPGA, start to rotate and stop soon.
- He connected ADS7 and PC with USB cable.
- He started DPG-Lite.
- SDPG-Lite starts and appears the following error dialog
I have attached the error log.
(I transferred some messages from Japanese to English.)
It seems to be not found firmware file.
But I think it is strange.
Revision-D is a newer version, isn't it?
Does the revision-D board need to update the firmware?
I suspect this ADS7-V2EBZ is broken.
Would you advise how to solve it?
The customer needs to use ADS7 as soon as possible.
y_suzuki
Just-In-Time (JIT) �f�o�b�O��Ăяo�����߂̏ڍׂɂ��ẮA �_�C�A���O �{�b�N�X�ł͂Ȃ��A���̃��b�Z�[�W�̍Ō��Q�Ƃ��Ă��������B ************** exception text ************** System.IO.FileNotFoundException: Can't locate FW file: C:\ProgramData\Analog Devices\ACE\Plugins\Support.DPGDownloader.1.19.187\lib\net452\Firmware\ADS7-V2.ldr location AnalogDevices.DPG.Hardware.ADS72.Devices.Device_ADS7.Ads7SeriesDeviceAds7V2.UpdateFirmware(String firmwareFileName, Boolean checkResetFirst, Boolean resetWhenDone) location DPGDownloader.FirmwareUpdateForm.<>c__DisplayClass3_0.<FirmwareUpdateForm_Load>b__0() location System.Threading.Tasks.Task`1.InnerInvoke() location System.Threading.Tasks.Task.Execute() --- End of stack trace from location where exception was thrown immediately before --- location System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) location System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) location DPGDownloader.FirmwareUpdateForm.<FirmwareUpdateForm_Load>d__3.MoveNext() --- End of stack trace from location where exception was thrown immediately before --- location System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_0(Object state) ************** Loaded Assemblies ************** mscorlib assembly version:4.0.0.0 Win32 version:4.8.4515.0 built by: NET48REL1LAST_C code base:file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- DPGDownloader assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.DPGDownloader.1.19.187/lib/net452/DPGDownloader.exe ---------------------------------------- System.Windows.Forms assembly version:4.0.0.0 Win32 version:4.8.4550.0 built by: NET48REL1LAST_C code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System assembly version:4.0.0.0 Win32 version:4.8.4536.0 built by: NET48REL1LAST_C code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing assembly version:4.0.0.0 Win32 version:4.8.4390.0 built by: NET48REL1LAST_C code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Core assembly version:4.0.0.0 Win32 version:4.8.4566.0 built by: NET48REL1LAST_C code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- CrowdStrike.Sensor.ScriptControl assembly version:6.40.15406.0 Win32 version:6.40.15406.0 code base:file:///C:/WINDOWS/SysNative/CrowdStrike.Sensor.ScriptControl15406.dll ---------------------------------------- System.Configuration assembly version:4.0.0.0 Win32 version:4.8.4190.0 built by: NET48REL1LAST_B code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml assembly version:4.0.0.0 Win32 version:4.8.4084.0 built by: NET48REL1 code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- mscorlib.resources assembly version:4.0.0.0 Win32 version:4.8.4084.0 built by: NET48REL1 code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_ja_b77a5c561934e089/mscorlib.resources.dll ---------------------------------------- AnalogDevices.DPG.Interfaces assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.Interfaces.1.19.187/lib/net452/AnalogDevices.DPG.Interfaces.dll ---------------------------------------- AnalogDevices.DPG.PluginFinder assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.PluginFinder.1.19.187/lib/net452/AnalogDevices.DPG.PluginFinder.dll ---------------------------------------- AnalogDevices.Vector.Common assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Common.1.19.187/lib/net452/AnalogDevices.Vector.Common.dll ---------------------------------------- AnalogDevices.Vector.Generator.Chirp assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Generator.Chirp.1.19.187/lib/net452/AnalogDevices.Vector.Generator.Chirp.dll ---------------------------------------- AnalogDevices.Vector.Generator.CIFR assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Generator.CIFR.1.19.187/lib/net452/AnalogDevices.Vector.Generator.CIFR.dll ---------------------------------------- AnalogDevices.Vector.AdvancedVectorGenerator assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.AdvancedVectorGenerator.1.19.187/lib/net452/AnalogDevices.Vector.AdvancedVectorGenerator.dll ---------------------------------------- AnalogDevices.Vector.Generator.DC assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Generator.DC.1.19.187/lib/net452/AnalogDevices.Vector.Generator.DC.dll ---------------------------------------- AnalogDevices.Vector.Generator.Noise assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Generator.Noise.1.19.187/lib/net452/AnalogDevices.Vector.Generator.Noise.dll ---------------------------------------- AnalogDevices.Vector.Generator.PtP assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Generator.PtP.1.19.187/lib/net452/AnalogDevices.Vector.Generator.PtP.dll ---------------------------------------- AnalogDevices.Vector.Generator.Tones assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Generator.Tones.1.19.187/lib/net452/AnalogDevices.Vector.Generator.Tones.dll ---------------------------------------- AnalogDevices.Vector.Generator.WIFR assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.Vector.Generator.WIFR.1.19.187/lib/net452/AnalogDevices.Vector.Generator.WIFR.dll ---------------------------------------- AnalogDevices.VectorFile.Legacy assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.VectorFile.Legacy.1.19.187/lib/net452/AnalogDevices.VectorFile.Legacy.dll ---------------------------------------- AnalogDevices.DPG.HardwareControl assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.HardwareControl.1.19.187/lib/net452/AnalogDevices.DPG.HardwareControl.dll ---------------------------------------- sdpApi1 assembly version:2.2022.22100.75 Win32 version:2.2022.22100.75 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Hardware.SdpSupport.1.2022.22100/lib/sdpApi1.dll ---------------------------------------- System.Management assembly version:4.0.0.0 Win32 version:4.8.4435.0 built by: NET48REL1LAST_C code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- System.Web.Services assembly version:4.0.0.0 Win32 version:4.8.4084.0 built by: NET48REL1 code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.ServiceModel assembly version:4.0.0.0 Win32 version:4.8.4536.0 built by: NET48REL1LAST_C code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll ---------------------------------------- AnalogDevices.DPG.Hardware.ADS72 assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.Hardware.ADS72.1.19.187/lib/net452/AnalogDevices.DPG.Hardware.ADS72.dll ---------------------------------------- AnalogDevices.DPG.Ads7SeriesCommon assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.Hardware.ADS72.1.19.187/lib/net452/AnalogDevices.DPG.Ads7SeriesCommon.DLL ---------------------------------------- AnalogDevices.DPG.Hardware.ADS9 assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.Hardware.ADS9.1.19.187/lib/net452/AnalogDevices.DPG.Hardware.ADS9.dll ---------------------------------------- sdpApi1.Proxies assembly version:0.0.0.0 Win32 version: code base:file:///C:/Users/11122/AppData/Local/Analog%20Devices/sdpApi/Release/sdpApi1_2_2022_22100_75_clr4_2_2022_22100_75.cache ---------------------------------------- AnalogDevices.DPG.Hardware.DPG3 assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.Hardware.DPG3.1.19.187/lib/net452/AnalogDevices.DPG.Hardware.DPG3.dll ---------------------------------------- AnalogDevices.DPG.Hardware.SDPH1 assembly version:1.19.187.0 Win32 version:1.19.187.0 code base:file:///C:/ProgramData/Analog%20Devices/ACE/Plugins/Support.AnalogDevices.DPG.Hardware.SDPH1.1.19.187/lib/net452/AnalogDevices.DPG.Hardware.SDPH1.dll ---------------------------------------- AnalogDevices.Csa assembly version:1.26.3240.0 Win32 version:1.26.3240.0 code base:file:///C:/Program%20Files%20(x86)/Analog%20Devices/ACE/AnalogDevices.Csa.dll ---------------------------------------- System.Windows.Forms.resources assembly version:4.0.0.0 Win32 version:4.8.4084.0 built by: NET48REL1 code base:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_ja_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- ************** JIT Debug ************** Just-In-Time (JIT) �f�o�b�O��L���ɂ���ɂ́A���̃A�v���P�[�V�����A �܂��̓R���s���[�^�[ (machine.config) �̍\���t�@�C���� jitDebugging �l�� system.windows.forms �Z�N�V�����Őݒ肵�Ȃ���Ȃ�܂���B �A�v���P�[�V�����͂܂��A�f�o�b�O��L���ɂ��ăR���p�C������Ȃ���� �Ȃ�܂���B ��: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> JIT �f�o�b�O���L���ȂƂ��́A���̃_�C�A���O �{�b�N�X�ŏ����������A �n���h������Ă��Ȃ���O�͂��ׂăR���s���[�^�[�ɓo�^���ꂽ JIT �f�o�b�K�[�ɐݒ肳��Ȃ���Ȃ�܂���B
