Selection of JESD Mode for AD9174 for dual complex channel
The user is configuring the AD9174 in dual DAC mode with a 12 GSPS DAC rate and a 3 GHz input clock, aiming to use one complex channel per DAC core. The final answer directs the user to a parallel thread for detailed configuration of dual link JESD204B setup, which is necessary to keep lane rates within the 15.4 Gbps limit. The user's questions about dual link configuration, including the need for two JESD chains and the division of lanes, are addressed in the linked thread.
Category: Choose a category
Product Number: AD9174
I am using complex dual channel(Dual DAC mode) of AD9174.
I want to operate at >=12GSPS DAC rate. I have input clock of 3G which by using internal DAC PLL ,I'm making it to 12G.
I want to use 1 complex channel per DAC core.(Preferred to bypass channel data path, but due to issue in selecting proper JESD mode, I can go with both channel & main interpolation to get lane rate within the limit).
I wanted to go for single link mode of configuration with M=4(since I am using both complex channels), but with the modes for M=4, except JESD mode 4, I am getting a lane rate which exceeds the limiting boundary of the device , i.e. 15.4 Gbps. Then I found a statement in the feature page of AD9174 datasheet stating, "The AD9174 can be alternatively configured as a dual DAC, with each DAC operating across an independent JESD204B link".
I am confused with that the above statement wants to convey. It raised certain questions to me like:
1. If I use dual link, do I need to have two different JESD chains for DAC in FPGA(meaning every layer(AD IP) would be repeated twice)?
2. If I use dual link with only one JESD chain, how lanes will be divided between the links.
3. With the above statement, what I understood is having one complex (I/Q) channel per DAC core ,i.e. M=2 for each link, correct ? (irrespective of choosing channel/main data path)
4. What is the advantage of having dual link, as per the datasheet we would have the same JESD values for a given mode..so with the above requirements listed, can't I go with single link?
Any suggestions on choosing a proper lane rate with the above required configurations would be of much help.
Thanks
Edit Notes
Can't I use dual DAC operating at single JESD link with M=4?
[edited by: sb0844 at 8:03 AM (GMT -4) on 23 Sep 2022]
