DDS Phase offset registers AD9106
Product Number: AD9106
AD9106 datasheet indicates registers from 0x40 to 0x043 allow phase control for each DDS output available, but when changing values on those registers phase is not changing at all (I compared with other output withput phase offset). I'm able to configure all other features on the evaluation board, even the cosine version of the DDS, but when trying to configures phase offset registers is not working. In the other hand, if I need to reprogram those phase shift offset registers, can I do it with the pattern enable bit on and trigger enabled? or whats is the correct procedure for changing phase for each DDS outputs?. Thanks
edited part number for clarity
[edited by: emassa at 4:44 PM (GMT -4) on 20 Jul 2022]
Parents Reply Children
No Data
