Hi
I have used main nco to generate the frequency of 3.84 G and given chirp iq samples through jesd link. but the chirp waveform band width was not as expected .
What could be the issue?
Thanks
VK19
AD9172
Recommended for New Designs
The AD9172 is a high performance, dual, 16-bit digital-to-analog converter (DAC) that supports DAC sample rates to 12.6 GSPS. The device features an 8...
Datasheet
AD9172 on Analog.com
Hi
Thanks
VK19
Hi VK19,
Can you explain the discrepancy between your observed and expected bandwidths? Are you using ACE/DPG? If so, make sure that your data rate in DPG matches your data rate in ACE, and that you have unchecked "Unsigned data" in DPG.
Best wishes,
KB
Assumed answered. Please let us know if there are further questions.
