STM32H7B3I-DK SPI (SPI2) ISSUES with AD9102EVK
Interesting note.  Wonder if anyone else has experienced this.  I can read or write just fine to the EVK, but only one to five addresses at a time. The datasheet says that if csb is kept low, the address counters in the DAC will be incremented automatically.  However That is now what I am experiencing.  No data seems to be shifted out (or on successive writes)  beyond 5-10 successive reads.   Going through the provided Evkit code, which runs fine, I realized they do not use multi-word writes or reads. I thought this strange.  My goal was to use DMA, but it suffers the same issue.  Has anyone else encountered this? Another interesting note is it will not begin a read from register 0x00.  Only 0x01 or higher?  Trying to read from Reg 0x00 yields no data at all.
Here is are my SPI Settings:
Ful-Duplex Master, NSS Disabled., MOTO FRAME, 16bit data size, MODE: 0 (CPOL=0, CPHA=0),  1Mbps freq (64Mhz I/O clock with 64 prescaler).I dropped in two clock cycle spacing between words, but that made no difference.
                                startaddr=k+0x8001;        // 9102 Reg Addr 0x00, MSB set to Write
HAL_GPIO_WritePin(GPIOI, GPIO_PIN_0, GPIO_PIN_RESET);                           // csb low.  Verified on O'scope.
HAL_SPI_Transmit(&hspi2, (uint8_t *) &startaddr , 1,100 );                             // 0x0000+0x8001 (AD9102 Addr 0x1
HAL_SPI_Receive(&hspi2, (uint8_t *) &ReadData[1], 15, 100);                          //  Array of 96, zero's out first.
HAL_GPIO_WritePin(GPIOI, GPIO_PIN_0, GPIO_PIN_SET);                              //   csb high.  Chip Select off.
                     HAL_Delay(1);
                                // I see the clock bursts for all 15 reads, but only some of the data.  It seems that after more than 5-10 reads it stops reading.
                               //  If I change startaddr in a loop, I can sequentially read one address at a time just fine as long as I keep the read length below 5.
Picture below shows write address, then first word, (register 0x1)  then nothing thereafter.   Note: not all words have data. Many are zero. So I'm really looking at points where I know data exists.  The second word should have data.
For Comparison sake, CMSIS library implementation of AD910x Class .
A working read defined on the provided EVKIT software using the CMSIS library is as follows: Note single read/writes only.
 * @brief Read 16-bit data from AD910x SPI/SRAM register
 * @param addr - SPI/SRAM address
 * @return reg_data - data returned by AD910x
int16_t AD910x::spi_read( uint16_t addr )
   csb = 0;
    uint16_t read_addr;
    int16_t reg_data;
    read_addr = 0x8000+addr;   // I notice they also had to set the write bit.  That is a must for setting up a read.
    spi.write( read_addr );
    reg_data = spi.write( 0 );      // Then read from address 0.  I assume this keeps MOSI quiet in full duplex mode.
    csb = 1;
    wait_us( 1 );
    return reg_data;
Top Replies
    Sep 1, 2021 +1 verified
    Hello ,
    We did not use the auto-increment feature, only single SPI reads and writes because in config.h we defined only the register addresses accessible to the user.
    Instead of incrementing the register…
Parents
    on Sep 1, 2021 4:10 AM
    Hello ,
    Instead of incrementing the register address, have you tried decrementing?
    In the read function, setting the MSB of the instruction byte to 1 is correct. There is an error in Figure 33 of the AD9102 datasheet which is addressed in several threads here in EZ. Please see the correct figure below:
    Sorry for the confusion. We are in the process of revising datasheets for several legacy high-speed DACs.
    Shine
Reply
    Hello ,
    Shine
Children
No Data
