My customer use multi-AD9173s on their system.
Their system has 16 boards and each board has 4 AD9173s.
During the Power On/Off test with their system, occasionally 3 specific AD9173s among total 64 AD9173s have issues.
( No output at DACOUT / No ack on SPI )
Because of no ack on SPI, they can't debug using a changing Reg. and setting values on SPI.
Actually after finding issues, they checked Power and SPI communications.
They don't find any issues about Power.
And also they found SPI doesn't operated at FPGA side.
But they check that SPIs of other AD9173s on same board are operated normally.
So they need your help about a debugging methods.
Q1) If SPI isn't operated, which points of AD9173 they can check ?
They use same SPI on same board.
Each board has 4 AD9173s and so SPI of some AD9173s are operated normally.
Please share your experience or advices about SPI of AD9173.
Q2) Which points of AD9173 they can check without using SPI?
Because they can't use SPI with issued AD9173, they can't control DAC in AD9173 and they don't know inner values of registers in issued AD9173.
Please share your experience or advices about debugging points of AD9173 without using SPI.
Q3) If DAC can't be controlled using SPI, how to debug AD9173 or control DAC without SPI?
Without using SPI, which points of AD9173 should they checked first?
Please share your experience or advices.
Q4) Would you suggest any opinions and advices to them about using Multiple AD9173s?
If you have any idea or problems that you met before when you use Multiple AD9173s,
Se-woong
Modified questions.
[edited by: Se-woong at 1:33 AM (GMT -4) on 3 Jul 2021]
