AD9102: help with Generate waveform use RAM
Hi, All.
I Programing using FPGA.
I entered the trigger after setting the register,
but DAC output dose notthing. i want know wthat is problem in my register setting.
My code is under. (Set in order from45 to 0)
   assign init_addr_table[45] = `SPICONFIG;
   assign init_addr_table[44] = `POWERCONFIG;
   assign init_addr_table[43] = `CLOCKCONFIG;
   assign init_addr_table[42] = `REFADJ;
   assign init_addr_table[41] = `DACAGAIN;
   assign init_addr_table[40] = `DACRANGE;
   assign init_addr_table[39] = `DACRSET;
   assign init_addr_table[38] = `PAT_STATUS;
   assign init_addr_table[37] = `RAMUPDATE;
   assign init_addr_table[36] = `PAT_TYPE;
   assign init_addr_table[35] = `PATTERN_DLY;
   assign init_addr_table[34] = `DACDOF;
   assign init_addr_table[33] = `WAV_CONFIG;
   assign init_addr_table[32] = `PAT_TIMEBASE;
   assign init_addr_table[31] = `PAT_PERIOD;
   assign init_addr_table[30] = `DAC_PAT;
   assign init_addr_table[29] = `DOUT_START;
   assign init_addr_table[28] = `DOUT_CONFIG;
   assign init_addr_table[27] = `DAC_CST;
   assign init_addr_table[26] = `DAC_DGAIN;
   assign init_addr_table[25] = `SAW_CONFIG;
   assign init_addr_table[24] = `DDS_TW32;
   assign init_addr_table[23] = `DDS_TW1;
   assign init_addr_table[22] = `DDS_PW;
   assign init_addr_table[21] = `TRIG_TW_SEL;
   assign init_addr_table[20] = `DDS_CONFIG;
   assign init_addr_table[19] = `TW_RAM_CONFIG;
   assign init_addr_table[18] = `START_DELAY;
   assign init_addr_table[17] = `START_ADDR;
   assign init_addr_table[16] = `STOP_ADDR;
   assign init_addr_table[15] = `DDS_CYC;
   assign init_addr_table[14] = `RAMUPDATE;
   assign init_addr_table[13] = `PAT_STATUS;
   assign init_addr_table[12] = `RAMUPDATE;
   assign init_addr_table[11] = `SRAM_OFFSET;
   assign init_addr_table[10] = `SRAM_OFFSET + 15'd1;
   assign init_addr_table[9] = `SRAM_OFFSET + 15'd2;
   assign init_addr_table[8] = `SRAM_OFFSET + 15'd3;
   assign init_addr_table[7] = `SRAM_OFFSET + 15'd4;
   assign init_addr_table[6] = `SRAM_OFFSET + 15'd5;
   assign init_addr_table[5] = `SRAM_OFFSET + 15'd6;
   assign init_addr_table[4] = `SRAM_OFFSET + 15'd7;
   assign init_addr_table[3] = `PAT_STATUS;
   assign init_addr_table[2] = `RAMUPDATE;
   assign init_addr_table[1] = `PAT_STATUS;
   assign init_addr_table[0] = `RAMUPDATE;
   assign init_data_table[45] = 16'h0000;
   assign init_data_table[44] = 16'h0107;
   assign init_data_table[43] = 16'h0000;
   assign init_data_table[42] = 16'h0000;
   assign init_data_table[41] = 16'h0000;
   assign init_data_table[40] = 16'h000a;
   assign init_data_table[39] = 16'h0000;
   assign init_data_table[38] = 16'h0000;
   assign init_data_table[37] = 16'h0001;
   assign init_data_table[36] = 16'h0001;
   assign init_data_table[35] = 16'h0000;
   assign init_data_table[34] = 16'h8000;
   assign init_data_table[33] = 16'h0000;
   assign init_data_table[32] = 16'h0111;
   assign init_data_table[31] = 16'h000a;
   assign init_data_table[30] = 16'h0001;
   assign init_data_table[29] = 16'h0001;
   assign init_data_table[28] = 16'h0010;
   assign init_data_table[27] = 16'h8000;
   assign init_data_table[26] = 16'h4000;
   assign init_data_table[25] = 16'h0007;
   assign init_data_table[24] = 16'h0100;
   assign init_data_table[23] = 16'h0000;
   assign init_data_table[22] = 16'h0000;
   assign init_data_table[21] = 16'h0002;
   assign init_data_table[20] = 16'h0003;
   assign init_data_table[19] = 16'h0000;
   assign init_data_table[18] = 16'h0000;
   assign init_data_table[17] = 16'h0000;
   assign init_data_table[16] = 16'h0070;
   assign init_data_table[15] = 16'h0001;
   assign init_data_table[14] = 16'h0001;
   assign init_data_table[13] = 16'h0004;
   assign init_data_table[12] = 16'h0001;
   assign init_data_table[11] = 16'h1000;
   assign init_data_table[10] = 16'h0000;
   assign init_data_table[9] = 16'h2000;
   assign init_data_table[8] = 16'h0000;
   assign init_data_table[7] = 16'h3000;
   assign init_data_table[6] = 16'h0000;
   assign init_data_table[5] = 16'h4000;
   assign init_data_table[4] = 16'h0000;
   assign init_data_table[3] = 16'h0000;
   assign init_data_table[2] = 16'h0001;
   assign init_data_table[1] = 16'h0001;
   assign init_data_table[0] = 16'h0001;
thanks!
Parents
    Please compare your register settings to those in the attached file.
    Shine
    * Copyright (c) 2020 Analog Devices, Inc.
    * All rights reserved.
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions are met:
    *   - Redistributions of source code must retain the above copyright notice,
    *     this list of conditions and the following disclaimer.
    *   - Redistributions in binary form must reproduce the above copyright notice,
    *     this list of conditions and the following disclaimer in the documentation
    *     and/or other materials provided with the distribution.
    *   - Modified versions of the software must be conspicuously marked as such.
    *   - This software is licensed solely and exclusively for use with
    *     processors/products manufactured by or for Analog Devices, Inc.
    *   - This software may not be combined or merged with other code in any manner
    *     that would cause the software to become subject to terms and
    *     conditions which differ from those listed here.
    *   - Neither the name of Analog Devices, Inc. nor the names of its
    *     contributors may be used to endorse or promote products derived
    *     from this software without specific prior written permission.
    *   - The use of this software may or may not infringe the patent rights
    *     of one or more patent holders. This license does not release you from
    *     the requirement that you obtain separate licenses from these patent
    *     holders to use this software.
    * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES, INC. AND CONTRIBUTORS "AS IS"
    * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
    * NON-INFRINGEMENT, TITLE, MERCHANTABILITY AND FITNESS FOR A
    * PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL ANALOG DEVICES,
    * INC. OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, PUNITIVE OR CONSEQUENTIAL DAMAGES
    * (INCLUDING, BUT NOT LIMITED TO, DAMAGES ARISING OUT OF CLAIMS OF
    * INTELLECTUAL PROPERTY RIGHTS INFRINGEMENT; PROCUREMENT OF SUBSTITUTE
    * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
    * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
    * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
    * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
    * POSSIBILITY OF SUCH DAMAGE.
    * 20180927-7CBSD SLA
    The following is an example program showing how to initialise and use SDP
    connector peripherals (using SPI and GPIOs as an example) on the SDP-K1 in mbed.
    Informtion on the pin name definitions for the SDP connector on the SDP-K1 can
    be found at https://os.mbed.com/platforms/SDP_K1/.
    The full list of peripherals available on the SDP connector include GPIOs,
    Timers, SPI, I2C, and UART. For further information on how to enable these
    peripherals, consult the mbed documentation https://os.mbed.com/docs/mbed-os/v5.15/apis/drivers.html
    #include "mbed.h"
    #include "platform/mbed_thread.h"
    /********** Initialization **********/
    DigitalOut TRIGGERB( PG_10, 1 ); 	//Set initial value of Trigger pin to 1.
    DigitalOut CSB( PA_15, 1 );			//Set initial value of CS pin to 1.
    DigitalOut RESETB( PA_10, 1 );		//Set initial value of RESET pin to 1.
    Serial pc( USBTX, USBRX );			//Initialization of serial communication with PC
    SPI spi( PA_7, PB_4, PB_3 );		//Initialization of SPI pins (MOSI, MISO, SCLK);
    /********** 12-bit SRAM Data in Arrays **********/
    //For Fout=10MHz, Fdac=156.25MHz
    int16_t SRAM_DATA_10M_156M25[4096]={0, 804, 1478, 1915, 2045, 1846, 1351, 639, -176, -962, -1594, -1970, -2030, -1764, -1214, -470, 350, 1114, 1699, 2011, 2000, 1668, 1068, 297, -522, -1257, -1790, -2036, -1955, -1560, -915, -122, 690, 1391, 1869, 2047, 1896, 1441, 754, -53, -852, -1515, -1934, -2042, -1823, -1311, -588, 229, 1009, 1627, 1984, 2022, 1736, 1171, 418, -402, -1158, -1728, -2020, -1988, -1637, -1023, -244, 573, 1299, 1816, 2041, 1939, 1525, 867, 69, -740, -1430, -1890, -2047, -1875, -1402, -704, 107, 901, 1550, 1950, 2038, 1798, 1269, 537, -282, -1055, -1659, -1997, -2014, -1707, -1127, -365, 455, 1202, 1756, 2028, 1975, 1604, 976, 191, -624, -1339, -1840, -2044, -1921, -1489, -818, -16, 789, 1467, 1910, 2046, 1853, 1363, 654, -160, -948, -1584, -1966, -2032, -1772, -1227, -485, 334, 1100, 1690, 2008, 2003, 1677, 1082, 313, -507, -1244, -1783, -2035, -1960, -1570, -929, -138, 675, 1379, 1862, 2046, 1902, 1452, 769, -38, -838, -1504, -1928, -2043, -1830, -1323, -603, 213, 995, 1618, 1980, 2025, 1744, 1184, 433, -387, -1145, -1719, -2017, -1992, -1646, -1036, -260, 558, 1286, 1808, 2040, 1944, 1536, 881, 85, -725, -1418, -1884, -2047, -1881, -1414, -719, 91, 887, 1540, 1946, 2039, 1805, 1282, 552, -266, -1042, -1650, -1993, -2016, -1716, -1140, -381, 439, 1189, 1748, 2026, 1979, 1614, 990, 207, -609, -1328, -1833, -2044, -1926, -1500, -832, -31, 775, 1456, 1904, 2046, 1860, 1375, 669, -144, -934, -1574, -1962, -2034, -1780, -1239, -500, 319, 1087, 1681, 2005, 2006, 1686, 1095, 328, -491, -1232, -1775, -2033, -1964, -1580, -943, -154, 660, 1368, 1856, 2046, 1908, 1463, 783, -22, -824, -1493, -1923, -2044, -1837, -1335, -618, 198, 982, 1608, 1976, 2027, 1753, 1197, 449, -372, -1132, -1711, -2015, -1995, -1655, -1050, -275, 543, 1274, 1801, 2038, 1949, 1546, 895, 100, -710, -1407, -1878, -2047, -1888, -1425, -734, 75, 872, 1529, 1941, 2040, 1813, 1294, 567, -251, -1028, -1640, -1989, -2019, -1724, -1153, -396, 424, 1176, 1739, 2023, 1983, 1623, 1003, 223, -594, -1316, -1826, -2043, -1932, -1510, -847, -47, 760, 1445, 1898, 2047, 1866, 1386, 684, -129, -920, -1564, -1957, -2036, -1787, -1252, -516, 303, 1074, 1672, 2001, 2009, 1695, 1108, 344, -476, -1219, -1767, -2031, -1969, -1590, -957, -169, 645, 1356, 1849, 2045, 1913, 1474, 798, -6, -809, -1483, -1918, -2045, -1844, -1347, -633, 182, 968, 1598, 1972, 2029, 1761, 1209, 464, -356, -1119, -1702, -2012, -1999, -1665, -1063, -291, 528, 1262, 1793, 2037, 1953, 1556, 909, 116, -696, -1395, -1871, -2047, -1894, -1436, -748, 60, 858, 1519, 1936, 2042, 1820, 1306, 582, -235, -1014, -1631, -1986, -2022, -1733, -1166, -412, 409, 1163, 1731, 2021, 1986, 1633, 1017, 238, -579, -1303, -1818, -2041, -1937, -1521, -861, -63, 745, 1434, 1892, 2047, 1873, 1398, 698, -113, -906, -1554, -1952, -2037, -1795, -1264, -531, 288, 1060, 1663, 1998, 2012, 1704, 1122, 359, -461, -1207, -1759, -2029, -1973, -1600, -970, -185, 630, 1344, 1842, 2045, 1919, 1485, 812, 9, -795, -1472, -1912, -2045, -1850, -1358, -648, 166, 954, 1588, 1968, 2031, 1769, 1222, 479, -341, -1106, -1693, -2009, -2002, -1674, -1077, -307, 513, 1249, 1786, 2035, 1958, 1566, 923, 132, -681, -1384, -1865, -2047, -1899, -1447, -763, 44, 844, 1508, 1930, 2043, 1827, 1318, 597, -219, -1001, -1621, -1982, -2024, -1741, -1179, -427, 393, 1150, 1723, 2018, 1990, 1642, 1031, 254, -564, -1291, -1811, -2040, -1942, -1531, -875, -78, 731, 1423, 1886, 2047, 1879, 1409, 713, -97, -892, -1544, -1948, -2039, -1802, -1277, -546, 272, 1047, 1653, 1994, 2015, 1712, 1135, 375, -445, -1194, -1751, -2027, -1977, -1610, -984, -201, 615, 1332, 1835, 2044, 1924, 1495, 827, 25, -780, -1461, -1906, -2046, -1857, -1370, -663, 151, 940, 1578, 1963, 2033, 1776, 1234, 494, -325, -1092, -1684, -2006, -2005, -1683, -1090, -322, 497, 1237, 1778, 2033, 1962, 1576, 937, 147, -666, -1372, -1858, -2046, -1905, -1459, -778, 28, 830, 1498, 1925, 2044, 1834, 1330, 612, -204, -987, -1612, -1978, -2026, -1749, -1191, -442, 378, 1137, 1714, 2016, 1994, 1652, 1044, 269, -549, -1279, -1804, -2039, -1947, -1542, -889, -94, 716, 1411, 1880, 2047, 1885, 1421, 728, -82, -878, -1533, -1943, -2040, -1810, -1289, -561, 257, 1033, 1644, 1991, 2018, 1721, 1148, 390, -430, -1181, -1743, -2024, -1981, -1620, -998, -216, 600, 1320, 1828, 2043, 1929, 1506, 841, 41, -766, -1450, -1901, -2046, -1864, -1382, -678, 135, 926, 1568, 1959, 2035, 1784, 1247, 510, -310, -1079, -1675, -2003, -2008, -1691, -1103, -338, 482, 1224, 1770, 2032, 1967, 1586, 951, 163, -651, -1361, -1852, -2046, -1911, -1469, -792, 13, 815, 1487, 1920, 2045, 1841, 1342, 627, -188, -973, -1602, -1974, -2028, -1757, -1204, -458, 362, 1124, 1705, 2013, 1997, 1661, 1058, 285, -534, -1267, -1796, -2037, -1951, -1552, -903, -110, 701, 1400, 1874, 2047, 1891, 1432, 743, -66, -864, -1523, -1938, -2041, -1817, -1301, -576, 241, 1020, 1635, 1987, 2021, 1729, 1161, 406, -415, -1168, -1734, -2022, -1985, -1629, -1012, -232, 585, 1308, 1821, 2042, 1935, 1517, 855, 57, -751, -1439, -1895, -2047, -1870, -1393, -693, 119, 912, 1558, 1954, 2037, 1792, 1259, 525, -294, -1066, -1666, -1999, -2011, -1700, -1116, -353, 467, 1212, 1762, 2030, 1971, 1596, 965, 179, -636, -1349, -1845, -2045, -1917, -1480, -807, -3, 801, 1476, 1914, 2045, 1848, 1354, 642, -172, -959, -1592, -1969, -2030, -1765, -1217, -473, 347, 1111, 1697, 2010, 2001, 1670, 1071, 300, -519, -1254, -1789, -2036, -1956, -1562, -918, -126, 687, 1389, 1868, 2047, 1897, 1443, 757, -50, -850, -1513, -1933, -2042, -1824, -1313, -591, 226, 1006, 1625, 1983, 2023, 1738, 1174, 421, -399, -1155, -1726, -2019, -1989, -1639, -1025, -247, 570, 1296, 1814, 2041, 1940, 1527, 870, 72, -737, -1427, -1889, -2047, -1876, -1405, -707, 104, 898, 1548, 1950, 2038, 1799, 1272, 540, -279, -1052, -1657, -1996, -2014, -1709, -1129, -369, 452, 1199, 1754, 2028, 1975, 1606, 979, 194, -621, -1337, -1838, -2044, -1922, -1491, -821, -19, 786, 1465, 1909, 2046, 1854, 1365, 657, -157, -946, -1582, -1965, -2032, -1773, -1229, -488, 331, 1098, 1688, 2007, 2004, 1679, 1085, 316, -503, -1242, -1781, -2034, -1961, -1572, -932, -141, 672, 1377, 1861, 2046, 1903, 1454, 772, -35, -835, -1502, -1927, -2043, -1831, -1325, -606, 210, 993, 1616, 1979, 2025, 1746, 1186, 436, -384, -1142, -1718, -2017, -1992, -1648, -1039, -263, 555, 1284, 1807, 2039, 1945, 1538, 884, 88, -722, -1416, -1883, -2047, -1883, -1416, -722, 88, 884, 1538, 1945, 2039, 1807, 1284, 555, -263, -1039, -1648, -1992, -2017, -1718, -1142, -384, 436, 1186, 1746, 2025, 1979, 1616, 993, 210, -606, -1325, -1831, -2043, -1927, -1502, -835, -35, 772, 1454, 1903, 2046, 1861, 1377, 672, -141, -932, -1572, -1961, -2034, -1781, -1242, -503, 316, 1085, 1679, 2004, 2007, 1688, 1098, 331, -488, -1229, -1773, -2032, -1965, -1582, -946, -157, 657, 1365, 1854, 2046, 1909, 1465, 786, -19, -821, -1491, -1922, -2044, -1838, -1337, -621, 194, 979, 1606, 1975, 2028, 1754, 1199, 452, -369, -1129, -1709, -2014, -1996, -1657, -1052, -279, 540, 1272, 1799, 2038, 1950, 1548, 898, 104, -707, -1405, -1876, -2047, -1889, -1427, -737, 72, 870, 1527, 1940, 2041, 1814, 1296, 570, -247, -1025, -1639, -1989, -2019, -1726, -1155, -399, 421, 1174, 1738, 2023, 1983, 1625, 1006, 226, -591, -1313, -1824, -2042, -1933, -1513, -850, -50, 757, 1443, 1897, 2047, 1868, 1389, 687, -126, -918, -1562, -1956, -2036, -1789, -1254, -519, 300, 1071, 1670, 2001, 2010, 1697, 1111, 347, -473, -1217, -1765, -2030, -1969, -1592, -959, -172, 642, 1354, 1848, 2045, 1914, 1476, 801, -3, -807, -1480, -1917, -2045, -1845, -1349, -636, 179, 965, 1596, 1971, 2030, 1762, 1212, 467, -353, -1116, -1700, -2011, -1999, -1666, -1066, -294, 525, 1259, 1792, 2037, 1954, 1558, 912, 119, -693, -1393, -1870, -2047, -1895, -1439, -751, 57, 855, 1517, 1935, 2042, 1821, 1308, 585, -232, -1012, -1629, -1985, -2022, -1734, -1168, -415, 406, 1161, 1729, 2021, 1987, 1635, 1020, 241, -576, -1301, -1817, -2041, -1938, -1523, -864, -66, 743, 1432, 1891, 2047, 1874, 1400, 701, -110, -903, -1552, -1951, -2037, -1796, -1267, -534, 285, 1058, 1661, 1997, 2013, 1705, 1124, 362, -458, -1204, -1757, -2028, -1974, -1602, -973, -188, 627, 1342, 1841, 2045, 1920, 1487, 815, 13, -792, -1469, -1911, -2046, -1852, -1361, -651, 163, 951, 1586, 1967, 2032, 1770, 1224, 482, -338, -1103, -1691, -2008, -2003, -1675, -1079, -310, 510, 1247, 1784, 2035, 1959, 1568, 926, 135, -678, -1382, -1864, -2046, -1901, -1450, -766, 41, 841, 1506, 1929, 2043, 1828, 1320, 600, -216, -998, -1620, -1981, -2024, -1743, -1181, -430, 390, 1148, 1721, 2018, 1991, 1644, 1033, 257, -561, -1289, -1810, -2040, -1943, -1533, -878, -82, 728, 1421, 1885, 2047, 1880, 1411, 716, -94, -889, -1542, -1947, -2039, -1804, -1279, -549, 269, 1044, 1652, 1994, 2016, 1714, 1137, 378, -442, -1191, -1749, -2026, -1978, -1612, -987, -204, 612, 1330, 1834, 2044, 1925, 1498, 830, 28, -778, -1459, -1905, -2046, -1858, -1372, -666, 147, 937, 1576, 1962, 2033, 1778, 1237, 497, -322, -1090, -1683, -2005, -2006, -1684, -1092, -325, 494, 1234, 1776, 2033, 1963, 1578, 940, 151, -663, -1370, -1857, -2046, -1906, -1461, -780, 25, 827, 1495, 1924, 2044, 1835, 1332, 615, -201, -984, -1610, -1977, -2027, -1751, -1194, -445, 375, 1135, 1712, 2015, 1994, 1653, 1047, 272, -546, -1277, -1802, -2039, -1948, -1544, -892, -97, 713, 1409, 1879, 2047, 1886, 1423, 731, -78, -875, -1531, -1942, -2040, -1811, -1291, -564, 254, 1031, 1642, 1990, 2018, 1723, 1150, 393, -427, -1179, -1741, -2024, -1982, -1621, -1001, -219, 597, 1318, 1827, 2043, 1930, 1508, 844, 44, -763, -1447, -1899, -2047, -1865, -1384, -681, 132, 923, 1566, 1958, 2035, 1786, 1249, 513, -307, -1077, -1674, -2002, -2009, -1693, -1106, -341, 479, 1222, 1769, 2031, 1968, 1588, 954, 166, -648, -1358, -1850, -2045, -1912, -1472, -795, 9, 812, 1485, 1919, 2045, 1842, 1344, 630, -185, -970, -1600, -1973, -2029, -1759, -1207, -461, 359, 1122, 1704, 2012, 1998, 1663, 1060, 288, -531, -1264, -1795, -2037, -1952, -1554, -906, -113, 698, 1398, 1873, 2047, 1892, 1434, 745, -63, -861, -1521, -1937, -2041, -1818, -1303, -579, 238, 1017, 1633, 1986, 2021, 1731, 1163, 409, -412, -1166, -1733, -2022, -1986, -1631, -1014, -235, 582, 1306, 1820, 2042, 1936, 1519, 858, 60, -748, -1436, -1894, -2047, -1871, -1395, -696, 116, 909, 1556, 1953, 2037, 1793, 1262, 528, -291, -1063, -1665, -1999, -2012, -1702, -1119, -356, 464, 1209, 1761, 2029, 1972, 1598, 968, 182, -633, -1347, -1844, -2045, -1918, -1483, -809, -6, 798, 1474, 1913, 2045, 1849, 1356, 645, -169, -957, -1590, -1969, -2031, -1767, -1219, -476, 344, 1108, 1695, 2009, 2001, 1672, 1074, 303, -516, -1252, -1787, -2036, -1957, -1564, -920, -129, 684, 1386, 1866, 2047, 1898, 1445, 760, -47, -847, -1510, -1932, -2043, -1826, -1316, -594, 223, 1003, 1623, 1983, 2023, 1739, 1176, 424, -396, -1153, -1724, -2019, -1989, -1640, -1028, -251, 567, 1294, 1813, 2040, 1941, 1529, 872, 75, -734, -1425, -1888, -2047, -1878, -1407, -710, 100, 895, 1546, 1949, 2038, 1801, 1274, 543, -275, -1050, -1655, -1995, -2015, -1711, -1132, -372, 449, 1197, 1753, 2027, 1976, 1608, 982, 198, -618, -1335, -1837, -2044, -1923, -1493, -824, -22, 783, 1463, 1908, 2046, 1856, 1368, 660, -154, -943, -1580, -1964, -2033, -1775, -1232, -491, 328, 1095, 1686, 2006, 2005, 1681, 1087, 319, -500, -1239, -1780, -2034, -1962, -1574, -934, -144, 669, 1375, 1860, 2046, 1904, 1456, 775, -31, -832, -1500, -1926, -2044, -1833, -1328, -609, 207, 990, 1614, 1979, 2026, 1748, 1189, 439, -381, -1140, -1716, -2016, -1993, -1650, -1042, -266, 552, 1282, 1805, 2039, 1946, 1540, 887, 91, -719, -1414, -1881, -2047, -1884, -1418, -725, 85, 881, 1536, 1944, 2040, 1808, 1286, 558, -260, -1036, -1646, -1992, -2017, -1719, -1145, -387, 433, 1184, 1744, 2025, 1980, 1618, 995, 213, -603, -1323, -1830, -2043, -1928, -1504, -838, -38, 769, 1452, 1902, 2046, 1862, 1379, 675, -138, -929, -1570, -1960, -2035, -1783, -1244, -507, 313, 1082, 1677, 2003, 2008, 1690, 1100, 334, -485, -1227, -1772, -2032, -1966, -1584, -948, -160, 654, 1363, 1853, 2046, 1910, 1467, 789, -16, -818, -1489, -1921, -2044, -1840, -1339, -624, 191, 976, 1604, 1975, 2028, 1756, 1202, 455, -365, -1127, -1707, -2014, -1997, -1659, -1055, -282, 537, 1269, 1798, 2038, 1950, 1550, 901, 107, -704, -1402, -1875, -2047, -1890, -1430, -740, 69, 867, 1525, 1939, 2041, 1816, 1299, 573, -244, -1023, -1637, -1988, -2020, -1728, -1158, -402, 418, 1171, 1736, 2022, 1984, 1627, 1009, 229, -588, -1311, -1823, -2042, -1934, -1515, -852, -53, 754, 1441, 1896, 2047, 1869, 1391, 690, -122, -915, -1560, -1955, -2036, -1790, -1257, -522, 297, 1068, 1668, 2000, 2011, 1699, 1114, 350, -470, -1214, -1764, -2030, -1970, -1594, -962, -176, 639, 1351, 1846, 2045, 1915, 1478, 804, 0, -804, -1478, -1915, -2045, -1846, -1351, -639, 176, 962, 1594, 1970, 2030, 1764, 1214, 470, -350, -1114, -1699, -2011, -2000, -1668, -1068, -297, 522, 1257, 1790, 2036, 1955, 1560, 915, 122, -690, -1391, -1869, -2047, -1896, -1441, -754, 53, 852, 1515, 1934, 2042, 1823, 1311, 588, -229, -1009, -1627, -1984, -2022, -1736, -1171, -418, 402, 1158, 1728, 2020, 1988, 1637, 1023, 244, -573, -1299, -1816, -2041, -1939, -1525, -867, -69, 740, 1430, 1890, 2047, 1875, 1402, 704, -107, -901, -1550, -1950, -2038, -1798, -1269, -537, 282, 1055, 1659, 1997, 2014, 1707, 1127, 365, -455, -1202, -1756, -2028, -1975, -1604, -976, -191, 624, 1339, 1840, 2044, 1921, 1489, 818, 16, -789, -1467, -1910, -2046, -1853, -1363, -654, 160, 948, 1584, 1966, 2032, 1772, 1227, 485, -334, -1100, -1690, -2008, -2003, -1677, -1082, -313, 507, 1244, 1783, 2035, 1960, 1570, 929, 138, -675, -1379, -1862, -2046, -1902, -1452, -769, 38, 838, 1504, 1928, 2043, 1830, 1323, 603, -213, -995, -1618, -1980, -2025, -1744, -1184, -433, 387, 1145, 1719, 2017, 1992, 1646, 1036, 260, -558, -1286, -1808, -2040, -1944, -1536, -881, -85, 725, 1418, 1884, 2047, 1881, 1414, 719, -91, -887, -1540, -1946, -2039, -1805, -1282, -552, 266, 1042, 1650, 1993, 2016, 1716, 1140, 381, -439, -1189, -1748, -2026, -1979, -1614, -990, -207, 609, 1328, 1833, 2044, 1926, 1500, 832, 31, -775, -1456, -1904, -2046, -1860, -1375, -669, 144, 934, 1574, 1962, 2034, 1780, 1239, 500, -319, -1087, -1681, -2005, -2006, -1686, -1095, -328, 491, 1232, 1775, 2033, 1964, 1580, 943, 154, -660, -1368, -1856, -2046, -1908, -1463, -783, 22, 824, 1493, 1923, 2044, 1837, 1335, 618, -198, -982, -1608, -1976, -2027, -1753, -1197, -449, 372, 1132, 1711, 2015, 1995, 1655, 1050, 275, -543, -1274, -1801, -2038, -1949, -1546, -895, -100, 710, 1407, 1878, 2047, 1888, 1425, 734, -75, -872, -1529, -1941, -2040, -1813, -1294, -567, 251, 1028, 1640, 1989, 2019, 1724, 1153, 396, -424, -1176, -1739, -2023, -1983, -1623, -1003, -223, 594, 1316, 1826, 2043, 1932, 1510, 847, 47, -760, -1445, -1898, -2047, -1866, -1386, -684, 129, 920, 1564, 1957, 2036, 1787, 1252, 516, -303, -1074, -1672, -2001, -2009, -1695, -1108, -344, 476, 1219, 1767, 2031, 1969, 1590, 957, 169, -645, -1356, -1849, -2045, -1913, -1474, -798, 6, 809, 1483, 1918, 2045, 1844, 1347, 633, -182, -968, -1598, -1972, -2029, -1761, -1209, -464, 356, 1119, 1702, 2012, 1999, 1665, 1063, 291, -528, -1262, -1793, -2037, -1953, -1556, -909, -116, 696, 1395, 1871, 2047, 1894, 1436, 748, -60, -858, -1519, -1936, -2042, -1820, -1306, -582, 235, 1014, 1631, 1986, 2022, 1733, 1166, 412, -409, -1163, -1731, -2021, -1986, -1633, -1017, -238, 579, 1303, 1818, 2041, 1937, 1521, 861, 63, -745, -1434, -1892, -2047, -1873, -1398, -698, 113, 906, 1554, 1952, 2037, 1795, 1264, 531, -288, -1060, -1663, -1998, -2012, -1704, -1122, -359, 461, 1207, 1759, 2029, 1973, 1600, 970, 185, -630, -1344, -1842, -2045, -1919, -1485, -812, -9, 795, 1472, 1912, 2045, 1850, 1358, 648, -166, -954, -1588, -1968, -2031, -1769, -1222, -479, 341, 1106, 1693, 2009, 2002, 1674, 1077, 307, -513, -1249, -1786, -2035, -1958, -1566, -923, -132, 681, 1384, 1865, 2047, 1899, 1447, 763, -44, -844, -1508, -1930, -2043, -1827, -1318, -597, 219, 1001, 1621, 1982, 2024, 1741, 1179, 427, -393, -1150, -1723, -2018, -1990, -1642, -1031, -254, 564, 1291, 1811, 2040, 1942, 1531, 875, 78, -731, -1423, -1886, -2047, -1879, -1409, -713, 97, 892, 1544, 1948, 2039, 1802, 1277, 546, -272, -1047, -1653, -1994, -2015, -1712, -1135, -375, 445, 1194, 1751, 2027, 1977, 1610, 984, 201, -615, -1332, -1835, -2044, -1924, -1495, -827, -25, 780, 1461, 1906, 2046, 1857, 1370, 663, -151, -940, -1578, -1963, -2033, -1776, -1234, -494, 325, 1092, 1684, 2006, 2005, 1683, 1090, 322, -497, -1237, -1778, -2033, -1962, -1576, -937, -147, 666, 1372, 1858, 2046, 1905, 1459, 778, -28, -830, -1498, -1925, -2044, -1834, -1330, -612, 204, 987, 1612, 1978, 2026, 1749, 1191, 442, -378, -1137, -1714, -2016, -1994, -1652, -1044, -269, 549, 1279, 1804, 2039, 1947, 1542, 889, 94, -716, -1411, -1880, -2047, -1885, -1421, -728, 82, 878, 1533, 1943, 2040, 1810, 1289, 561, -257, -1033, -1644, -1991, -2018, -1721, -1148, -390, 430, 1181, 1743, 2024, 1981, 1620, 998, 216, -600, -1320, -1828, -2043, -1929, -1506, -841, -41, 766, 1450, 1901, 2046, 1864, 1382, 678, -135, -926, -1568, -1959, -2035, -1784, -1247, -510, 310, 1079, 1675, 2003, 2008, 1691, 1103, 338, -482, -1224, -1770, -2032, -1967, -1586, -951, -163, 651, 1361, 1852, 2046, 1911, 1469, 792, -13, -815, -1487, -1920, -2045, -1841, -1342, -627, 188, 973, 1602, 1974, 2028, 1757, 1204, 458, -362, -1124, -1705, -2013, -1997, -1661, -1058, -285, 534, 1267, 1796, 2037, 1951, 1552, 903, 110, -701, -1400, -1874, -2047, -1891, -1432, -743, 66, 864, 1523, 1938, 2041, 1817, 1301, 576, -241, -1020, -1635, -1987, -2021, -1729, -1161, -406, 415, 1168, 1734, 2022, 1985, 1629, 1012, 232, -585, -1308, -1821, -2042, -1935, -1517, -855, -57, 751, 1439, 1895, 2047, 1870, 1393, 693, -119, -912, -1558, -1954, -2037, -1792, -1259, -525, 294, 1066, 1666, 1999, 2011, 1700, 1116, 353, -467, -1212, -1762, -2030, -1971, -1596, -965, -179, 636, 1349, 1845, 2045, 1917, 1480, 807, 3, -801, -1476, -1914, -2045, -1848, -1354, -642, 172, 959, 1592, 1969, 2030, 1765, 1217, 473, -347, -1111, -1697, -2010, -2001, -1670, -1071, -300, 519, 1254, 1789, 2036, 1956, 1562, 918, 126, -687, -1389, -1868, -2047, -1897, -1443, -757, 50, 850, 1513, 1933, 2042, 1824, 1313, 591, -226, -1006, -1625, -1983, -2023, -1738, -1174, -421, 399, 1155, 1726, 2019, 1989, 1639, 1025, 247, -570, -1296, -1814, -2041, -1940, -1527, -870, -72, 737, 1427, 1889, 2047, 1876, 1405, 707, -104, -898, -1548, -1950, -2038, -1799, -1272, -540, 279, 1052, 1657, 1996, 2014, 1709, 1129, 369, -452, -1199, -1754, -2028, -1975, -1606, -979, -194, 621, 1337, 1838, 2044, 1922, 1491, 821, 19, -786, -1465, -1909, -2046, -1854, -1365, -657, 157, 946, 1582, 1965, 2032, 1773, 1229, 488, -331, -1098, -1688, -2007, -2004, -1679, -1085, -316, 503, 1242, 1781, 2034, 1961, 1572, 932, 141, -672, -1377, -1861, -2046, -1903, -1454, -772, 35, 835, 1502, 1927, 2043, 1831, 1325, 606, -210, -993, -1616, -1979, -2025, -1746, -1186, -436, 384, 1142, 1718, 2017, 1992, 1648, 1039, 263, -555, -1284, -1807, -2039, -1945, -1538, -884, -88, 722, 1416, 1883, 2047, 1883, 1416, 722, -88, -884, -1538, -1945, -2039, -1807, -1284, -555, 263, 1039, 1648, 1992, 2017, 1718, 1142, 384, -436, -1186, -1746, -2025, -1979, -1616, -993, -210, 606, 1325, 1831, 2043, 1927, 1502, 835, 35, -772, -1454, -1903, -2046, -1861, -1377, -672, 141, 932, 1572, 1961, 2034, 1781, 1242, 503, -316, -1085, -1679, -2004, -2007, -1688, -1098, -331, 488, 1229, 1773, 2032, 1965, 1582, 946, 157, -657, -1365, -1854, -2046, -1909, -1465, -786, 19, 821, 1491, 1922, 2044, 1838, 1337, 621, -194, -979, -1606, -1975, -2028, -1754, -1199, -452, 369, 1129, 1709, 2014, 1996, 1657, 1052, 279, -540, -1272, -1799, -2038, -1950, -1548, -898, -104, 707, 1405, 1876, 2047, 1889, 1427, 737, -72, -870, -1527, -1940, -2041, -1814, -1296, -570, 247, 1025, 1639, 1989, 2019, 1726, 1155, 399, -421, -1174, -1738, -2023, -1983, -1625, -1006, -226, 591, 1313, 1824, 2042, 1933, 1513, 850, 50, -757, -1443, -1897, -2047, -1868, -1389, -687, 126, 918, 1562, 1956, 2036, 1789, 1254, 519, -300, -1071, -1670, -2001, -2010, -1697, -1111, -347, 473, 1217, 1765, 2030, 1969, 1592, 959, 172, -642, -1354, -1848, -2045, -1914, -1476, -801, 3, 807, 1480, 1917, 2045, 1845, 1349, 636, -179, -965, -1596, -1971, -2030, -1762, -1212, -467, 353, 1116, 1700, 2011, 1999, 1666, 1066, 294, -525, -1259, -1792, -2037, -1954, -1558, -912, -119, 693, 1393, 1870, 2047, 1895, 1439, 751, -57, -855, -1517, -1935, -2042, -1821, -1308, -585, 232, 1012, 1629, 1985, 2022, 1734, 1168, 415, -406, -1161, -1729, -2021, -1987, -1635, -1020, -241, 576, 1301, 1817, 2041, 1938, 1523, 864, 66, -743, -1432, -1891, -2047, -1874, -1400, -701, 110, 903, 1552, 1951, 2037, 1796, 1267, 534, -285, -1058, -1661, -1997, -2013, -1705, -1124, -362, 458, 1204, 1757, 2028, 1974, 1602, 973, 188, -627, -1342, -1841, -2045, -1920, -1487, -815, -13, 792, 1469, 1911, 2046, 1852, 1361, 651, -163, -951, -1586, -1967, -2032, -1770, -1224, -482, 338, 1103, 1691, 2008, 2003, 1675, 1079, 310, -510, -1247, -1784, -2035, -1959, -1568, -926, -135, 678, 1382, 1864, 2046, 1901, 1450, 766, -41, -841, -1506, -1929, -2043, -1828, -1320, -600, 216, 998, 1620, 1981, 2024, 1743, 1181, 430, -390, -1148, -1721, -2018, -1991, -1644, -1033, -257, 561, 1289, 1810, 2040, 1943, 1533, 878, 82, -728, -1421, -1885, -2047, -1880, -1411, -716, 94, 889, 1542, 1947, 2039, 1804, 1279, 549, -269, -1044, -1652, -1994, -2016, -1714, -1137, -378, 442, 1191, 1749, 2026, 1978, 1612, 987, 204, -612, -1330, -1834, -2044, -1925, -1498, -830, -28, 778, 1459, 1905, 2046, 1858, 1372, 666, -147, -937, -1576, -1962, -2033, -1778, -1237, -497, 322, 1090, 1683, 2005, 2006, 1684, 1092, 325, -494, -1234, -1776, -2033, -1963, -1578, -940, -151, 663, 1370, 1857, 2046, 1906, 1461, 780, -25, -827, -1495, -1924, -2044, -1835, -1332, -615, 201, 984, 1610, 1977, 2027, 1751, 1194, 445, -375, -1135, -1712, -2015, -1994, -1653, -1047, -272, 546, 1277, 1802, 2039, 1948, 1544, 892, 97, -713, -1409, -1879, -2047, -1886, -1423, -731, 78, 875, 1531, 1942, 2040, 1811, 1291, 564, -254, -1031, -1642, -1990, -2018, -1723, -1150, -393, 427, 1179, 1741, 2024, 1982, 1621, 1001, 219, -597, -1318, -1827, -2043, -1930, -1508, -844, -44, 763, 1447, 1899, 2047, 1865, 1384, 681, -132, -923, -1566, -1958, -2035, -1786, -1249, -513, 307, 1077, 1674, 2002, 2009, 1693, 1106, 341, -479, -1222, -1769, -2031, -1968, -1588, -954, -166, 648, 1358, 1850, 2045, 1912, 1472, 795, -9, -812, -1485, -1919, -2045, -1842, -1344, -630, 185, 970, 1600, 1973, 2029, 1759, 1207, 461, -359, -1122, -1704, -2012, -1998, -1663, -1060, -288, 531, 1264, 1795, 2037, 1952, 1554, 906, 113, -698, -1398, -1873, -2047, -1892, -1434, -745, 63, 861, 1521, 1937, 2041, 1818, 1303, 579, -238, -1017, -1633, -1986, -2021, -1731, -1163, -409, 412, 1166, 1733, 2022, 1986, 1631, 1014, 235, -582, -1306, -1820, -2042, -1936, -1519, -858, -60, 748, 1436, 1894, 2047, 1871, 1395, 696, -116, -909, -1556, -1953, -2037, -1793, -1262, -528, 291, 1063, 1665, 1999, 2012, 1702, 1119, 356, -464, -1209, -1761, -2029, -1972, -1598, -968, -182, 633, 1347, 1844, 2045, 1918, 1483, 809, 6, -798, -1474, -1913, -2045, -1849, -1356, -645, 169, 957, 1590, 1969, 2031, 1767, 1219, 476, -344, -1108, -1695, -2009, -2001, -1672, -1074, -303, 516, 1252, 1787, 2036, 1957, 1564, 920, 129, -684, -1386, -1866, -2047, -1898, -1445, -760, 47, 847, 1510, 1932, 2043, 1826, 1316, 594, -223, -1003, -1623, -1983, -2023, -1739, -1176, -424, 396, 1153, 1724, 2019, 1989, 1640, 1028, 251, -567, -1294, -1813, -2040, -1941, -1529, -872, -75, 734, 1425, 1888, 2047, 1878, 1407, 710, -100, -895, -1546, -1949, -2038, -1801, -1274, -543, 275, 1050, 1655, 1995, 2015, 1711, 1132, 372, -449, -1197, -1753, -2027, -1976, -1608, -982, -198, 618, 1335, 1837, 2044, 1923, 1493, 824, 22, -783, -1463, -1908, -2046, -1856, -1368, -660, 154, 943, 1580, 1964, 2033, 1775, 1232, 491, -328, -1095, -1686, -2006, -2005, -1681, -1087, -319, 500, 1239, 1780, 2034, 1962, 1574, 934, 144, -669, -1375, -1860, -2046, -1904, -1456, -775, 31, 832, 1500, 1926, 2044, 1833, 1328, 609, -207, -990, -1614, -1979, -2026, -1748, -1189, -439, 381, 1140, 1716, 2016, 1993, 1650, 1042, 266, -552, -1282, -1805, -2039, -1946, -1540, -887, -91, 719, 1414, 1881, 2047, 1884, 1418, 725, -85, -881, -1536, -1944, -2040, -1808, -1286, -558, 260, 1036, 1646, 1992, 2017, 1719, 1145, 387, -433, -1184, -1744, -2025, -1980, -1618, -995, -213, 603, 1323, 1830, 2043, 1928, 1504, 838, 38, -769, -1452, -1902, -2046, -1862, -1379, -675, 138, 929, 1570, 1960, 2035, 1783, 1244, 507, -313, -1082, -1677, -2003, -2008, -1690, -1100, -334, 485, 1227, 1772, 2032, 1966, 1584, 948, 160, -654, -1363, -1853, -2046, -1910, -1467, -789, 16, 818, 1489, 1921, 2044, 1840, 1339, 624, -191, -976, -1604, -1975, -2028, -1756, -1202, -455, 365, 1127, 1707, 2014, 1997, 1659, 1055, 282, -537, -1269, -1798, -2038, -1950, -1550, -901, -107, 704, 1402, 1875, 2047, 1890, 1430, 740, -69, -867, -1525, -1939, -2041, -1816, -1299, -573, 244, 1023, 1637, 1988, 2020, 1728, 1158, 402, -418, -1171, -1736, -2022, -1984, -1627, -1009, -229, 588, 1311, 1823, 2042, 1934, 1515, 852, 53, -754, -1441, -1896, -2047, -1869, -1391, -690, 122, 915, 1560, 1955, 2036, 1790, 1257, 522, -297, -1068, -1668, -2000, -2011, -1699, -1114, -350, 470, 1214, 1764, 2030, 1970, 1594, 962, 176, -639, -1351, -1846, -2045, -1915, -1478, -804};
    //For Fout=10MHz, Fdac=180MHz
    int16_t SRAM_DATA_10M_180M[4096]={0, 698, 1313, 1770, 2015, 2017, 1778, 1325, 713, 16, -684, -1301, -1762, -2012, -2020, -1786, -1337, -728, -31, 669, 1289, 1754, 2009, 2022, 1793, 1349, 743, 47, -654, -1277, -1746, -2006, -2025, -1801, -1361, -757, -63, 639, 1264, 1738, 2003, 2027, 1808, 1372, 772, 78, -624, -1252, -1729, -1999, -2029, -1816, -1384, -786, -94, 609, 1239, 1721, 1996, 2031, 1823, 1395, 801, 110, -594, -1227, -1712, -1992, -2033, -1830, -1407, -815, -126, 579, 1214, 1704, 1989, 2035, 1837, 1418, 830, 141, -564, -1202, -1695, -1985, -2037, -1844, -1430, -844, -157, 549, 1189, 1686, 1981, 2038, 1850, 1441, 858, 172, -534, -1176, -1677, -1977, -2039, -1857, -1452, -872, -188, 519, 1163, 1668, 1973, 2041, 1864, 1463, 887, 204, -503, -1150, -1659, -1969, -2042, -1870, -1474, -901, -219, 488, 1137, 1650, 1964, 2043, 1876, 1485, 915, 235, -473, -1124, -1640, -1960, -2044, -1883, -1495, -929, -251, 458, 1111, 1631, 1955, 2045, 1889, 1506, 943, 266, -442, -1098, -1621, -1950, -2045, -1895, -1517, -957, -282, 427, 1085, 1612, 1946, 2046, 1901, 1527, 970, 297, -412, -1071, -1602, -1941, -2046, -1906, -1538, -984, -313, 396, 1058, 1592, 1936, 2047, 1912, 1548, 998, 328, -381, -1044, -1582, -1930, -2047, -1918, -1558, -1012, -344, 365, 1031, 1572, 1925, 2047, 1923, 1568, 1025, 359, -350, -1017, -1562, -1920, -2047, -1928, -1578, -1039, -375, 334, 1003, 1552, 1914, 2047, 1934, 1588, 1052, 390, -319, -990, -1542, -1909, -2047, -1939, -1598, -1066, -406, 303, 976, 1531, 1903, 2046, 1944, 1608, 1079, 421, -288, -962, -1521, -1897, -2046, -1949, -1618, -1092, -436, 272, 948, 1510, 1891, 2045, 1953, 1627, 1106, 452, -257, -934, -1500, -1885, -2044, -1958, -1637, -1119, -467, 241, 920, 1489, 1879, 2043, 1962, 1646, 1132, 482, -226, -906, -1478, -1873, -2042, -1967, -1655, -1145, -497, 210, 892, 1467, 1866, 2041, 1971, 1665, 1158, 513, -194, -878, -1456, -1860, -2040, -1975, -1674, -1171, -528, 179, 864, 1445, 1853, 2039, 1979, 1683, 1184, 543, -163, -850, -1434, -1846, -2037, -1983, -1691, -1197, -558, 147, 835, 1423, 1840, 2036, 1987, 1700, 1209, 573, -132, -821, -1411, -1833, -2034, -1991, -1709, -1222, -588, 116, 807, 1400, 1826, 2032, 1994, 1718, 1234, 603, -100, -792, -1389, -1818, -2030, -1998, -1726, -1247, -618, 85, 778, 1377, 1811, 2028, 2001, 1734, 1259, 633, -69, -763, -1365, -1804, -2026, -2005, -1743, -1272, -648, 53, 748, 1354, 1796, 2023, 2008, 1751, 1284, 663, -38, -734, -1342, -1789, -2021, -2011, -1759, -1296, -678, 22, 719, 1330, 1781, 2018, 2014, 1767, 1308, 693, -6, -704, -1318, -1773, -2016, -2016, -1775, -1320, -707, -9, 690, 1306, 1765, 2013, 2019, 1783, 1332, 722, 25, -675, -1294, -1757, -2010, -2022, -1790, -1344, -737, -41, 660, 1282, 1749, 2007, 2024, 1798, 1356, 751, 57, -645, -1269, -1741, -2004, -2026, -1805, -1368, -766, -72, 630, 1257, 1733, 2001, 2028, 1813, 1379, 780, 88, -615, -1244, -1724, -1997, -2030, -1820, -1391, -795, -104, 600, 1232, 1716, 1994, 2032, 1827, 1402, 809, 119, -585, -1219, -1707, -1990, -2034, -1834, -1414, -824, -135, 570, 1207, 1699, 1986, 2036, 1841, 1425, 838, 151, -555, -1194, -1690, -1983, -2037, -1848, -1436, -852, -166, 540, 1181, 1681, 1979, 2039, 1854, 1447, 867, 182, -525, -1168, -1672, -1975, -2040, -1861, -1459, -881, -198, 510, 1155, 1663, 1970, 2041, 1868, 1469, 895, 213, -494, -1142, -1653, -1966, -2043, -1874, -1480, -909, -229, 479, 1129, 1644, 1962, 2044, 1880, 1491, 923, 244, -464, -1116, -1635, -1957, -2044, -1886, -1502, -937, -260, 449, 1103, 1625, 1952, 2045, 1892, 1513, 951, 275, -433, -1090, -1616, -1948, -2046, -1898, -1523, -965, -291, 418, 1077, 1606, 1943, 2046, 1904, 1533, 979, 307, -402, -1063, -1596, -1938, -2047, -1910, -1544, -993, -322, 387, 1050, 1586, 1933, 2047, 1915, 1554, 1006, 338, -372, -1036, -1576, -1927, -2047, -1921, -1564, -1020, -353, 356, 1023, 1566, 1922, 2047, 1926, 1574, 1033, 369, -341, -1009, -1556, -1917, -2047, -1932, -1584, -1047, -384, 325, 995, 1546, 1911, 2047, 1937, 1594, 1060, 399, -310, -982, -1536, -1905, -2046, -1942, -1604, -1074, -415, 294, 968, 1525, 1899, 2046, 1947, 1614, 1087, 430, -279, -954, -1515, -1894, -2045, -1951, -1623, -1100, -445, 263, 940, 1504, 1888, 2045, 1956, 1633, 1114, 461, -247, -926, -1493, -1881, -2044, -1961, -1642, -1127, -476, 232, 912, 1483, 1875, 2043, 1965, 1652, 1140, 491, -216, -898, -1472, -1869, -2042, -1969, -1661, -1153, -507, 201, 884, 1461, 1862, 2040, 1974, 1670, 1166, 522, -185, -870, -1450, -1856, -2039, -1978, -1679, -1179, -537, 169, 855, 1439, 1849, 2038, 1982, 1688, 1191, 552, -154, -841, -1427, -1842, -2036, -1986, -1697, -1204, -567, 138, 827, 1416, 1835, 2035, 1989, 1705, 1217, 582, -122, -812, -1405, -1828, -2033, -1993, -1714, -1229, -597, 107, 798, 1393, 1821, 2031, 1997, 1723, 1242, 612, -91, -783, -1382, -1814, -2029, -2000, -1731, -1254, -627, 75, 769, 1370, 1807, 2027, 2003, 1739, 1267, 642, -60, -754, -1358, -1799, -2024, -2006, -1748, -1279, -657, 44, 740, 1347, 1792, 2022, 2009, 1756, 1291, 672, -28, -725, -1335, -1784, -2019, -2012, -1764, -1303, -687, 13, 710, 1323, 1776, 2017, 2015, 1772, 1316, 701, 3, -696, -1311, -1769, -2014, -2018, -1780, -1328, -716, -19, 681, 1299, 1761, 2011, 2021, 1787, 1339, 731, 35, -666, -1286, -1753, -2008, -2023, -1795, -1351, -745, -50, 651, 1274, 1744, 2005, 2025, 1802, 1363, 760, 66, -636, -1262, -1736, -2002, -2028, -1810, -1375, -775, -82, 621, 1249, 1728, 1999, 2030, 1817, 1386, 789, 97, -606, -1237, -1719, -1995, -2032, -1824, -1398, -804, -113, 591, 1224, 1711, 1992, 2033, 1831, 1409, 818, 129, -576, -1212, -1702, -1988, -2035, -1838, -1421, -832, -144, 561, 1199, 1693, 1984, 2037, 1845, 1432, 847, 160, -546, -1186, -1684, -1980, -2038, -1852, -1443, -861, -176, 531, 1174, 1675, 1976, 2040, 1858, 1454, 875, 191, -516, -1161, -1666, -1972, -2041, -1865, -1465, -889, -207, 500, 1148, 1657, 1968, 2042, 1871, 1476, 903, 223, -485, -1135, -1648, -1963, -2043, -1878, -1487, -918, -238, 470, 1122, 1639, 1959, 2044, 1884, 1498, 932, 254, -455, -1108, -1629, -1954, -2045, -1890, -1508, -946, -269, 439, 1095, 1620, 1950, 2045, 1896, 1519, 959, 285, -424, -1082, -1610, -1945, -2046, -1902, -1529, -973, -300, 409, 1068, 1600, 1940, 2046, 1908, 1540, 987, 316, -393, -1055, -1590, -1935, -2047, -1913, -1550, -1001, -331, 378, 1042, 1580, 1929, 2047, 1919, 1560, 1014, 347, -362, -1028, -1570, -1924, -2047, -1924, -1570, -1028, -362, 347, 1014, 1560, 1919, 2047, 1929, 1580, 1042, 378, -331, -1001, -1550, -1913, -2047, -1935, -1590, -1055, -393, 316, 987, 1540, 1908, 2046, 1940, 1600, 1068, 409, -300, -973, -1529, -1902, -2046, -1945, -1610, -1082, -424, 285, 959, 1519, 1896, 2045, 1950, 1620, 1095, 439, -269, -946, -1508, -1890, -2045, -1954, -1629, -1108, -455, 254, 932, 1498, 1884, 2044, 1959, 1639, 1122, 470, -238, -918, -1487, -1878, -2043, -1963, -1648, -1135, -485, 223, 903, 1476, 1871, 2042, 1968, 1657, 1148, 500, -207, -889, -1465, -1865, -2041, -1972, -1666, -1161, -516, 191, 875, 1454, 1858, 2040, 1976, 1675, 1174, 531, -176, -861, -1443, -1852, -2038, -1980, -1684, -1186, -546, 160, 847, 1432, 1845, 2037, 1984, 1693, 1199, 561, -144, -832, -1421, -1838, -2035, -1988, -1702, -1212, -576, 129, 818, 1409, 1831, 2033, 1992, 1711, 1224, 591, -113, -804, -1398, -1824, -2032, -1995, -1719, -1237, -606, 97, 789, 1386, 1817, 2030, 1999, 1728, 1249, 621, -82, -775, -1375, -1810, -2028, -2002, -1736, -1262, -636, 66, 760, 1363, 1802, 2025, 2005, 1744, 1274, 651, -50, -745, -1351, -1795, -2023, -2008, -1753, -1286, -666, 35, 731, 1339, 1787, 2021, 2011, 1761, 1299, 681, -19, -716, -1328, -1780, -2018, -2014, -1769, -1311, -696, 3, 701, 1316, 1772, 2015, 2017, 1776, 1323, 710, 13, -687, -1303, -1764, -2012, -2019, -1784, -1335, -725, -28, 672, 1291, 1756, 2009, 2022, 1792, 1347, 740, 44, -657, -1279, -1748, -2006, -2024, -1799, -1358, -754, -60, 642, 1267, 1739, 2003, 2027, 1807, 1370, 769, 75, -627, -1254, -1731, -2000, -2029, -1814, -1382, -783, -91, 612, 1242, 1723, 1997, 2031, 1821, 1393, 798, 107, -597, -1229, -1714, -1993, -2033, -1828, -1405, -812, -122, 582, 1217, 1705, 1989, 2035, 1835, 1416, 827, 138, -567, -1204, -1697, -1986, -2036, -1842, -1427, -841, -154, 552, 1191, 1688, 1982, 2038, 1849, 1439, 855, 169, -537, -1179, -1679, -1978, -2039, -1856, -1450, -870, -185, 522, 1166, 1670, 1974, 2040, 1862, 1461, 884, 201, -507, -1153, -1661, -1969, -2042, -1869, -1472, -898, -216, 491, 1140, 1652, 1965, 2043, 1875, 1483, 912, 232, -476, -1127, -1642, -1961, -2044, -1881, -1493, -926, -247, 461, 1114, 1633, 1956, 2045, 1888, 1504, 940, 263, -445, -1100, -1623, -1951, -2045, -1894, -1515, -954, -279, 430, 1087, 1614, 1947, 2046, 1899, 1525, 968, 294, -415, -1074, -1604, -1942, -2046, -1905, -1536, -982, -310, 399, 1060, 1594, 1937, 2047, 1911, 1546, 995, 325, -384, -1047, -1584, -1932, -2047, -1917, -1556, -1009, -341, 369, 1033, 1574, 1926, 2047, 1922, 1566, 1023, 356, -353, -1020, -1564, -1921, -2047, -1927, -1576, -1036, -372, 338, 1006, 1554, 1915, 2047, 1933, 1586, 1050, 387, -322, -993, -1544, -1910, -2047, -1938, -1596, -1063, -402, 307, 979, 1533, 1904, 2046, 1943, 1606, 1077, 418, -291, -965, -1523, -1898, -2046, -1948, -1616, -1090, -433, 275, 951, 1513, 1892, 2045, 1952, 1625, 1103, 449, -260, -937, -1502, -1886, -2044, -1957, -1635, -1116, -464, 244, 923, 1491, 1880, 2044, 1962, 1644, 1129, 479, -229, -909, -1480, -1874, -2043, -1966, -1653, -1142, -494, 213, 895, 1469, 1868, 2041, 1970, 1663, 1155, 510, -198, -881, -1459, -1861, -2040, -1975, -1672, -1168, -525, 182, 867, 1447, 1854, 2039, 1979, 1681, 1181, 540, -166, -852, -1436, -1848, -2037, -1983, -1690, -1194, -555, 151, 838, 1425, 1841, 2036, 1986, 1699, 1207, 570, -135, -824, -1414, -1834, -2034, -1990, -1707, -1219, -585, 119, 809, 1402, 1827, 2032, 1994, 1716, 1232, 600, -104, -795, -1391, -1820, -2030, -1997, -1724, -1244, -615, 88, 780, 1379, 1813, 2028, 2001, 1733, 1257, 630, -72, -766, -1368, -1805, -2026, -2004, -1741, -1269, -645, 57, 751, 1356, 1798, 2024, 2007, 1749, 1282, 660, -41, -737, -1344, -1790, -2022, -2010, -1757, -1294, -675, 25, 722, 1332, 1783, 2019, 2013, 1765, 1306, 690, -9, -707, -1320, -1775, -2016, -2016, -1773, -1318, -704, -6, 693, 1308, 1767, 2014, 2018, 1781, 1330, 719, 22, -678, -1296, -1759, -2011, -2021, -1789, -1342, -734, -38, 663, 1284, 1751, 2008, 2023, 1796, 1354, 748, 53, -648, -1272, -1743, -2005, -2026, -1804, -1365, -763, -69, 633, 1259, 1734, 2001, 2028, 1811, 1377, 778, 85, -618, -1247, -1726, -1998, -2030, -1818, -1389, -792, -100, 603, 1234, 1718, 1994, 2032, 1826, 1400, 807, 116, -588, -1222, -1709, -1991, -2034, -1833, -1411, -821, -132, 573, 1209, 1700, 1987, 2036, 1840, 1423, 835, 147, -558, -1197, -1691, -1983, -2037, -1846, -1434, -850, -163, 543, 1184, 1683, 1979, 2039, 1853, 1445, 864, 179, -528, -1171, -1674, -1975, -2040, -1860, -1456, -878, -194, 513, 1158, 1665, 1971, 2041, 1866, 1467, 892, 210, -497, -1145, -1655, -1967, -2042, -1873, -1478, -906, -226, 482, 1132, 1646, 1962, 2043, 1879, 1489, 920, 241, -467, -1119, -1637, -1958, -2044, -1885, -1500, -934, -257, 452, 1106, 1627, 1953, 2045, 1891, 1510, 948, 272, -436, -1092, -1618, -1949, -2046, -1897, -1521, -962, -288, 421, 1079, 1608, 1944, 2046, 1903, 1531, 976, 303, -406, -1066, -1598, -1939, -2047, -1909, -1542, -990, -319, 390, 1052, 1588, 1934, 2047, 1914, 1552, 1003, 334, -375, -1039, -1578, -1928, -2047, -1920, -1562, -1017, -350, 359, 1025, 1568, 1923, 2047, 1925, 1572, 1031, 365, -344, -1012, -1558, -1918, -2047, -1930, -1582, -1044, -381, 328, 998, 1548, 1912, 2047, 1936, 1592, 1058, 396, -313, -984, -1538, -1906, -2046, -1941, -1602, -1071, -412, 297, 970, 1527, 1901, 2046, 1946, 1612, 1085, 427, -282, -957, -1517, -1895, -2045, -1950, -1621, -1098, -442, 266, 943, 1506, 1889, 2045, 1955, 1631, 1111, 458, -251, -929, -1495, -1883, -2044, -1960, -1640, -1124, -473, 235, 915, 1485, 1876, 2043, 1964, 1650, 1137, 488, -219, -901, -1474, -1870, -2042, -1969, -1659, -1150, -503, 204, 887, 1463, 1864, 2041, 1973, 1668, 1163, 519, -188, -872, -1452, -1857, -2039, -1977, -1677, -1176, -534, 172, 858, 1441, 1850, 2038, 1981, 1686, 1189, 549, -157, -844, -1430, -1844, -2037, -1985, -1695, -1202, -564, 141, 830, 1418, 1837, 2035, 1989, 1704, 1214, 579, -126, -815, -1407, -1830, -2033, -1992, -1712, -1227, -594, 110, 801, 1395, 1823, 2031, 1996, 1721, 1239, 609, -94, -786, -1384, -1816, -2029, -1999, -1729, -1252, -624, 78, 772, 1372, 1808, 2027, 2003, 1738, 1264, 639, -63, -757, -1361, -1801, -2025, -2006, -1746, -1277, -654, 47, 743, 1349, 1793, 2022, 2009, 1754, 1289, 669, -31, -728, -1337, -1786, -2020, -2012, -1762, -1301, -684, 16, 713, 1325, 1778, 2017, 2015, 1770, 1313, 698, 0, -698, -1313, -1770, -2015, -2017, -1778, -1325, -713, -16, 684, 1301, 1762, 2012, 2020, 1786, 1337, 728, 31, -669, -1289, -1754, -2009, -2022, -1793, -1349, -743, -47, 654, 1277, 1746, 2006, 2025, 1801, 1361, 757, 63, -639, -1264, -1738, -2003, -2027, -1808, -1372, -772, -78, 624, 1252, 1729, 1999, 2029, 1816, 1384, 786, 94, -609, -1239, -1721, -1996, -2031, -1823, -1395, -801, -110, 594, 1227, 1712, 1992, 2033, 1830, 1407, 815, 126, -579, -1214, -1704, -1989, -2035, -1837, -1418, -830, -141, 564, 1202, 1695, 1985, 2037, 1844, 1430, 844, 157, -549, -1189, -1686, -1981, -2038, -1850, -1441, -858, -172, 534, 1176, 1677, 1977, 2039, 1857, 1452, 872, 188, -519, -1163, -1668, -1973, -2041, -1864, -1463, -887, -204, 503, 1150, 1659, 1969, 2042, 1870, 1474, 901, 219, -488, -1137, -1650, -1964, -2043, -1876, -1485, -915, -235, 473, 1124, 1640, 1960, 2044, 1883, 1495, 929, 251, -458, -1111, -1631, -1955, -2045, -1889, -1506, -943, -266, 442, 1098, 1621, 1950, 2045, 1895, 1517, 957, 282, -427, -1085, -1612, -1946, -2046, -1901, -1527, -970, -297, 412, 1071, 1602, 1941, 2046, 1906, 1538, 984, 313, -396, -1058, -1592, -1936, -2047, -1912, -1548, -998, -328, 381, 1044, 1582, 1930, 2047, 1918, 1558, 1012, 344, -365, -1031, -1572, -1925, -2047, -1923, -1568, -1025, -359, 350, 1017, 1562, 1920, 2047, 1928, 1578, 1039, 375, -334, -1003, -1552, -1914, -2047, -1934, -1588, -1052, -390, 319, 990, 1542, 1909, 2047, 1939, 1598, 1066, 406, -303, -976, -1531, -1903, -2046, -1944, -1608, -1079, -421, 288, 962, 1521, 1897, 2046, 1949, 1618, 1092, 436, -272, -948, -1510, -1891, -2045, -1953, -1627, -1106, -452, 257, 934, 1500, 1885, 2044, 1958, 1637, 1119, 467, -241, -920, -1489, -1879, -2043, -1962, -1646, -1132, -482, 226, 906, 1478, 1873, 2042, 1967, 1655, 1145, 497, -210, -892, -1467, -1866, -2041, -1971, -1665, -1158, -513, 194, 878, 1456, 1860, 2040, 1975, 1674, 1171, 528, -179, -864, -1445, -1853, -2039, -1979, -1683, -1184, -543, 163, 850, 1434, 1846, 2037, 1983, 1691, 1197, 558, -147, -835, -1423, -1840, -2036, -1987, -1700, -1209, -573, 132, 821, 1411, 1833, 2034, 1991, 1709, 1222, 588, -116, -807, -1400, -1826, -2032, -1994, -1718, -1234, -603, 100, 792, 1389, 1818, 2030, 1998, 1726, 1247, 618, -85, -778, -1377, -1811, -2028, -2001, -1734, -1259, -633, 69, 763, 1365, 1804, 2026, 2005, 1743, 1272, 648, -53, -748, -1354, -1796, -2023, -2008, -1751, -1284, -663, 38, 734, 1342, 1789, 2021, 2011, 1759, 1296, 678, -22, -719, -1330, -1781, -2018, -2014, -1767, -1308, -693, 6, 704, 1318, 1773, 2016, 2016, 1775, 1320, 707, 9, -690, -1306, -1765, -2013, -2019, -1783, -1332, -722, -25, 675, 1294, 1757, 2010, 2022, 1790, 1344, 737, 41, -660, -1282, -1749, -2007, -2024, -1798, -1356, -751, -57, 645, 1269, 1741, 2004, 2026, 1805, 1368, 766, 72, -630, -1257, -1733, -2001, -2028, -1813, -1379, -780, -88, 615, 1244, 1724, 1997, 2030, 1820, 1391, 795, 104, -600, -1232, -1716, -1994, -2032, -1827, -1402, -809, -119, 585, 1219, 1707, 1990, 2034, 1834, 1414, 824, 135, -570, -1207, -1699, -1986, -2036, -1841, -1425, -838, -151, 555, 1194, 1690, 1983, 2037, 1848, 1436, 852, 166, -540, -1181, -1681, -1979, -2039, -1854, -1447, -867, -182, 525, 1168, 1672, 1975, 2040, 1861, 1459, 881, 198, -510, -1155, -1663, -1970, -2041, -1868, -1469, -895, -213, 494, 1142, 1653, 1966, 2043, 1874, 1480, 909, 229, -479, -1129, -1644, -1962, -2044, -1880, -1491, -923, -244, 464, 1116, 1635, 1957, 2044, 1886, 1502, 937, 260, -449, -1103, -1625, -1952, -2045, -1892, -1513, -951, -275, 433, 1090, 1616, 1948, 2046, 1898, 1523, 965, 291, -418, -1077, -1606, -1943, -2046, -1904, -1533, -979, -307, 402, 1063, 1596, 1938, 2047, 1910, 1544, 993, 322, -387, -1050, -1586, -1933, -2047, -1915, -1554, -1006, -338, 372, 1036, 1576, 1927, 2047, 1921, 1564, 1020, 353, -356, -1023, -1566, -1922, -2047, -1926, -1574, -1033, -369, 341, 1009, 1556, 1917, 2047, 1932, 1584, 1047, 384, -325, -995, -1546, -1911, -2047, -1937, -1594, -1060, -399, 310, 982, 1536, 1905, 2046, 1942, 1604, 1074, 415, -294, -968, -1525, -1899, -2046, -1947, -1614, -1087, -430, 279, 954, 1515, 1894, 2045, 1951, 1623, 1100, 445, -263, -940, -1504, -1888, -2045, -1956, -1633, -1114, -461, 247, 926, 1493, 1881, 2044, 1961, 1642, 1127, 476, -232, -912, -1483, -1875, -2043, -1965, -1652, -1140, -491, 216, 898, 1472, 1869, 2042, 1969, 1661, 1153, 507, -201, -884, -1461, -1862, -2040, -1974, -1670, -1166, -522, 185, 870, 1450, 1856, 2039, 1978, 1679, 1179, 537, -169, -855, -1439, -1849, -2038, -1982, -1688, -1191, -552, 154, 841, 1427, 1842, 2036, 1986, 1697, 1204, 567, -138, -827, -1416, -1835, -2035, -1989, -1705, -1217, -582, 122, 812, 1405, 1828, 2033, 1993, 1714, 1229, 597, -107, -798, -1393, -1821, -2031, -1997, -1723, -1242, -612, 91, 783, 1382, 1814, 2029, 2000, 1731, 1254, 627, -75, -769, -1370, -1807, -2027, -2003, -1739, -1267, -642, 60, 754, 1358, 1799, 2024, 2006, 1748, 1279, 657, -44, -740, -1347, -1792, -2022, -2009, -1756, -1291, -672, 28, 725, 1335, 1784, 2019, 2012, 1764, 1303, 687, -13, -710, -1323, -1776, -2017, -2015, -1772, -1316, -701, -3, 696, 1311, 1769, 2014, 2018, 1780, 1328, 716, 19, -681, -1299, -1761, -2011, -2021, -1787, -1339, -731, -35, 666, 1286, 1753, 2008, 2023, 1795, 1351, 745, 50, -651, -1274, -1744, -2005, -2025, -1802, -1363, -760, -66, 636, 1262, 1736, 2002, 2028, 1810, 1375, 775, 82, -621, -1249, -1728, -1999, -2030, -1817, -1386, -789, -97, 606, 1237, 1719, 1995, 2032, 1824, 1398, 804, 113, -591, -1224, -1711, -1992, -2033, -1831, -1409, -818, -129, 576, 1212, 1702, 1988, 2035, 1838, 1421, 832, 144, -561, -1199, -1693, -1984, -2037, -1845, -1432, -847, -160, 546, 1186, 1684, 1980, 2038, 1852, 1443, 861, 176, -531, -1174, -1675, -1976, -2040, -1858, -1454, -875, -191, 516, 1161, 1666, 1972, 2041, 1865, 1465, 889, 207, -500, -1148, -1657, -1968, -2042, -1871, -1476, -903, -223, 485, 1135, 1648, 1963, 2043, 1878, 1487, 918, 238, -470, -1122, -1639, -1959, -2044, -1884, -1498, -932, -254, 455, 1108, 1629, 1954, 2045, 1890, 1508, 946, 269, -439, -1095, -1620, -1950, -2045, -1896, -1519, -959, -285, 424, 1082, 1610, 1945, 2046, 1902, 1529, 973, 300, -409, -1068, -1600, -1940, -2046, -1908, -1540, -987, -316, 393, 1055, 1590, 1935, 2047, 1913, 1550, 1001, 331, -378, -1042, -1580, -1929, -2047, -1919, -1560, -1014, -347, 362, 1028, 1570, 1924, 2047, 1924, 1570, 1028, 362, -347, -1014, -1560, -1919, -2047, -1929, -1580, -1042, -378, 331, 1001, 1550, 1913, 2047, 1935, 1590, 1055, 393, -316, -987, -1540, -1908, -2046, -1940, -1600, -1068, -409, 300, 973, 1529, 1902, 2046, 1945, 1610, 1082, 424, -285, -959, -1519, -1896, -2045, -1950, -1620, -1095, -439, 269, 946, 1508, 1890, 2045, 1954, 1629, 1108, 455, -254, -932, -1498, -1884, -2044, -1959, -1639, -1122, -470, 238, 918, 1487, 1878, 2043, 1963, 1648, 1135, 485, -223, -903, -1476, -1871, -2042, -1968, -1657, -1148, -500, 207, 889, 1465, 1865, 2041, 1972, 1666, 1161, 516, -191, -875, -1454, -1858, -2040, -1976, -1675, -1174, -531, 176, 861, 1443, 1852, 2038, 1980, 1684, 1186, 546, -160, -847, -1432, -1845, -2037, -1984, -1693, -1199, -561, 144, 832, 1421, 1838, 2035, 1988, 1702, 1212, 576, -129, -818, -1409, -1831, -2033, -1992, -1711, -1224, -591, 113, 804, 1398, 1824, 2032, 1995, 1719, 1237, 606, -97, -789, -1386, -1817, -2030, -1999, -1728, -1249, -621, 82, 775, 1375, 1810, 2028, 2002, 1736, 1262, 636, -66, -760, -1363, -1802, -2025, -2005, -1744, -1274, -651, 50, 745, 1351, 1795, 2023, 2008, 1753, 1286, 666, -35, -731, -1339, -1787, -2021, -2011, -1761, -1299, -681, 19, 716, 1328, 1780, 2018, 2014, 1769, 1311, 696, -3, -701, -1316, -1772, -2015, -2017, -1776, -1323, -710, -13, 687, 1303, 1764, 2012, 2019, 1784, 1335, 725, 28, -672, -1291, -1756, -2009, -2022, -1792, -1347, -740, -44, 657, 1279, 1748, 2006, 2024, 1799, 1358, 754, 60, -642, -1267, -1739, -2003, -2027, -1807, -1370, -769, -75, 627, 1254, 1731, 2000, 2029, 1814, 1382, 783, 91, -612, -1242, -1723, -1997, -2031, -1821, -1393, -798, -107, 597, 1229, 1714, 1993, 2033, 1828, 1405, 812, 122, -582, -1217, -1705, -1989, -2035, -1835, -1416, -827, -138, 567, 1204, 1697, 1986, 2036, 1842, 1427, 841, 154, -552, -1191, -1688, -1982, -2038, -1849, -1439, -855, -169, 537, 1179, 1679, 1978, 2039, 1856, 1450, 870, 185, -522, -1166, -1670, -1974, -2040, -1862, -1461, -884, -201, 507, 1153, 1661, 1969, 2042, 1869, 1472, 898, 216, -491, -1140, -1652, -1965, -2043, -1875, -1483, -912, -232, 476, 1127, 1642, 1961, 2044, 1881, 1493, 926, 247, -461, -1114, -1633, -1956, -2045, -1888, -1504, -940, -263, 445, 1100, 1623, 1951, 2045, 1894, 1515, 954, 279, -430, -1087, -1614, -1947, -2046, -1899, -1525, -968, -294, 415, 1074, 1604, 1942, 2046, 1905, 1536, 982, 310, -399, -1060, -1594, -1937, -2047, -1911, -1546, -995, -325, 384, 1047, 1584, 1932, 2047, 1917, 1556, 1009, 341, -369, -1033, -1574, -1926, -2047, -1922, -1566, -1023, -356, 353, 1020, 1564, 1921, 2047, 1927, 1576, 1036, 372, -338, -1006, -1554, -1915, -2047, -1933, -1586, -1050, -387, 322, 993, 1544, 1910, 2047, 1938, 1596, 1063, 402, -307, -979, -1533, -1904, -2046, -1943, -1606, -1077, -418, 291, 965, 1523, 1898, 2046, 1948, 1616, 1090, 433, -275, -951, -1513, -1892, -2045, -1952, -1625, -1103, -449, 260, 937, 1502, 1886, 2044, 1957, 1635, 1116, 464, -244, -923, -1491, -1880, -2044, -1962, -1644, -1129, -479, 229, 909, 1480, 1874, 2043, 1966, 1653, 1142, 494, -213, -895, -1469, -1868, -2041, -1970, -1663, -1155, -510, 198, 881, 1459, 1861, 2040, 1975, 1672, 1168, 525, -182, -867, -1447, -1854, -2039, -1979, -1681, -1181, -540, 166, 852, 1436, 1848, 2037, 1983, 1690, 1194, 555, -151, -838, -1425, -1841, -2036, -1986, -1699, -1207, -570, 135, 824, 1414, 1834, 2034, 1990, 1707, 1219, 585, -119, -809, -1402, -1827, -2032, -1994, -1716, -1232, -600, 104, 795, 1391, 1820, 2030, 1997, 1724, 1244, 615, -88, -780, -1379, -1813, -2028, -2001, -1733, -1257, -630, 72, 766, 1368, 1805, 2026, 2004, 1741, 1269, 645, -57, -751, -1356, -1798, -2024, -2007, -1749, -1282, -660, 41, 737, 1344, 1790, 2022, 2010, 1757, 1294, 675, -25, -722, -1332, -1783, -2019, -2013, -1765, -1306, -690, 9, 707, 1320, 1775, 2016, 2016, 1773, 1318, 704, 6, -693, -1308, -1767, -2014, -2018, -1781, -1330, -719, -22, 678, 1296, 1759, 2011, 2021, 1789, 1342, 734, 38, -663, -1284, -1751, -2008, -2023, -1796, -1354, -748, -53, 648, 1272, 1743, 2005, 2026, 1804, 1365, 763, 69, -633, -1259, -1734, -2001, -2028, -1811, -1377, -778, -85, 618, 1247, 1726, 1998, 2030, 1818, 1389, 792, 100, -603, -1234, -1718, -1994, -2032, -1826, -1400, -807, -116, 588, 1222, 1709, 1991, 2034, 1833, 1411, 821, 132, -573, -1209, -1700, -1987, -2036, -1840, -1423, -835, -147, 558, 1197, 1691, 1983, 2037, 1846, 1434, 850, 163, -543, -1184, -1683, -1979, -2039, -1853, -1445, -864, -179, 528, 1171, 1674, 1975, 2040, 1860, 1456, 878, 194, -513, -1158, -1665, -1971, -2041, -1866, -1467, -892, -210, 497, 1145, 1655, 1967, 2042, 1873, 1478, 906, 226, -482, -1132, -1646, -1962, -2043, -1879, -1489, -920, -241, 467, 1119, 1637, 1958, 2044, 1885, 1500, 934, 257, -452, -1106, -1627, -1953, -2045, -1891, -1510, -948, -272, 436, 1092, 1618, 1949, 2046, 1897, 1521, 962, 288, -421, -1079, -1608, -1944, -2046, -1903, -1531, -976, -303, 406, 1066, 1598, 1939, 2047, 1909, 1542, 990, 319, -390, -1052, -1588, -1934, -2047, -1914, -1552, -1003, -334, 375, 1039, 1578, 1928, 2047, 1920, 1562, 1017, 350, -359, -1025, -1568, -1923, -2047, -1925, -1572, -1031, -365, 344, 1012, 1558, 1918, 2047, 1930, 1582, 1044, 381, -328, -998, -1548, -1912, -2047, -1936, -1592, -1058, -396, 313, 984, 1538, 1906, 2046, 1941, 1602, 1071, 412, -297, -970, -1527, -1901, -2046, -1946, -1612, -1085, -427, 282, 957, 1517, 1895, 2045, 1950, 1621, 1098, 442, -266, -943, -1506, -1889, -2045, -1955, -1631, -1111, -458, 251, 929, 1495, 1883, 2044, 1960, 1640, 1124, 473, -235, -915, -1485, -1876, -2043, -1964, -1650, -1137, -488, 219, 901, 1474, 1870, 2042, 1969, 1659, 1150, 503, -204, -887, -1463, -1864, -2041, -1973, -1668, -1163, -519, 188, 872, 1452, 1857, 2039, 1977, 1677, 1176, 534, -172, -858, -1441, -1850, -2038, -1981, -1686, -1189, -549, 157, 844, 1430, 1844, 2037, 1985, 1695, 1202, 564, -141, -830, -1418, -1837, -2035, -1989, -1704, -1214, -579, 126, 815, 1407, 1830, 2033, 1992, 1712, 1227, 594, -110, -801, -1395, -1823, -2031, -1996, -1721, -1239, -609, 94, 786, 1384, 1816, 2029, 1999, 1729, 1252, 624, -78, -772, -1372, -1808, -2027, -2003, -1738, -1264, -639, 63, 757, 1361, 1801, 2025, 2006, 1746, 1277, 654, -47, -743, -1349, -1793, -2022, -2009, -1754, -1289, -669, 31, 728, 1337, 1786, 2020, 2012, 1762, 1301, 684, -16, -713, -1325, -1778, -2017, -2015, -1770, -1313, -698};
    /********** SPI Register Addresses and Values in Arrays **********/
    //Should work for both devices.
    uint16_t REG_ADD[66]={0x0000, 0x0001, 0x0002, 0x0003, 0x0004, 0x0005, 0x0006, 0x0007, 0x0008, 0x0009, 0x000A, 0x000B, 0x000C, 0x000D, 0x000E, 0x001F, 0x0020, 0x0022, 0x0023, 0x0024, 0x0025, 0x0026, 0x0027, 0x0028, 0x0029, 0x002A, 0x002B, 0x002C, 0x002D, 0x002E, 0x002F, 0x0030, 0x0031, 0x0032, 0x0033, 0x0034, 0x0035, 0x0036, 0x0037, 0x003E, 0x003F, 0x0040, 0x0041, 0x0042, 0x0043, 0x0044, 0x0045, 0x0047, 0x0050, 0x0051, 0x0052, 0x0053, 0x0054, 0x0055, 0x0056, 0x0057, 0x0058, 0x0059, 0x005A, 0x005B, 0x005C, 0x005D, 0x005E, 0x005F, 0x001E, 0x001D};
    //If Fout is from SRAM:
    uint16_t REG_VAL_SRAM[66]={0x0000, 0x0E00, 0x0000, 0x0000, 0x4000, 0x4000, 0x4000, 0x4000, 0x0000, 0x1F00, 0x1F00, 0x1F00, 0x1F00, 0x0000, 0x0000, 0x0000, 0x000E, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0111, 0x1000, 0x0101, 0x0101, 0x0003, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x4000, 0x4000, 0x4000, 0x4000, 0x0001, 0x0200, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0001, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0001, 0x0001};
    //If Fout is from DDS (Fout=10MHz, Fdac=180MHz):
    uint16_t REG_VAL_DDS[66]={0x0000, 0x0E00, 0x0000, 0x0000, 0x4000, 0x4000, 0x4000, 0x4000, 0x0000, 0x1F00, 0x1F00, 0x1F00, 0x1F00, 0x0000, 0x0000, 0x0000, 0x000E, 0x0000, 0x0000, 0x0000, 0x0000, 0x3131, 0x3131, 0x0111, 0x1000, 0x0101, 0x0101, 0x0003, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x4000, 0x4000, 0x4000, 0x4000, 0x0001, 0x0200, 0x0E38, 0xE400, 0x0000, 0x0000, 0x0000, 0x0000, 0x0001, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0000, 0x0000, 0xFFF0, 0x0100, 0x0001, 0x0001};
    /********** Functions **********/
    //For initializing SPI communication
    void SPI_INIT(){
    	//Set data length, polarity, and frequency
        spi.format( 16, 0 );
        spi.frequency( 1000000 );
    	//Pulse RESET pin low then high to reset SPI register values
        RESETB = 0;
        wait_us( 10 );
        RESETB = 1;
    //For reading from SPI registers
    int16_t SPI_READ( uint16_t addr ){
        CSB = 0;
        uint16_t read_addr = 0x8000+addr;
        spi.write( read_addr );
        int16_t reg_data = spi.write( 0 );
        CSB = 1;
        wait_us( 1 );
        return reg_data;
    //For writing to SPI registers
    void SPI_WRITE( uint16_t addr, int16_t data ){
        CSB = 0;
        spi.write( addr );
        spi.write( data );
        CSB = 1;
        wait_us( 1 );
    //For writing data to SRAM
    void UPDATE_SRAM( int16_t data[] ){
        SPI_WRITE( 0x001E, 0x0004 );
        int16_t data_shifted = 0;
        uint16_t SRAM_ADD = 0x6000;
        for ( int i=0; i<4096; i++ ){
            data_shifted = data[i] << 4;			//4 bit shifts for AD9106, 2 for AD9102
            SPI_WRITE( SRAM_ADD+i, data_shifted );
        SPI_WRITE( 0x001E, 0x0010 );
    //For printing first 16 SRAM data in terminal
    void READ_SRAM( ){
        SPI_WRITE( 0x001E, 0x000C );
        for ( int i=0; i<16; i++ ){
            data_shifted = SPI_READ( SRAM_ADD+i ) >> 4;
            pc.printf( "0x%04X, %d\n", SRAM_ADD+i, data_shifted);
    //For printing SPI register values in terminal
    void UPDATE_REGVAL( uint16_t data[] ){
        uint16_t data_display = 0;
        for ( int i=0; i<66; i++ ){
            SPI_WRITE( REG_ADD[i], data[i] );
            data_display = SPI_READ( REG_ADD[i]);
            pc.printf( "0x%04X, 0x%04X\n", REG_ADD[i], data_display );
    /********** Main Function **********/
    int main()
        SPI_INIT();
        UPDATE_SRAM( SRAM_DATA_10M_156M25 );	//When generating output from SRAM, write to SRAM registers first.
        //READ_SRAM();
        UPDATE_REGVAL( REG_VAL_SRAM );			//Then write to SPI registers.
        TRIGGERB = 0;							//Start of pattern generation
    	//Generating output from DDS:
    	//UPDATE_REGVAL ( REG_VAL_DDS );
        pc.printf( "Terminate pattern? (If yes, press y.)\n" );
        char STOP = 'N';
        while ( (STOP != 'Y') && (STOP != 'y') ){	//Continue generating pattern until y key is pressed.
            if( pc.readable() ){
                STOP = pc.getc();
        TRIGGERB = 1;							//End of pattern generation
        pc.printf( "Pattern terminated.\n" );
Reply
    Shine
    #include "mbed.h"
    void SPI_INIT(){
        RESETB = 0;
        wait_us( 10 );
        RESETB = 1;
        CSB = 0;
        CSB = 1;
        wait_us( 1 );
        return reg_data;
        CSB = 0;
        spi.write( addr );
        spi.write( data );
        CSB = 1;
        wait_us( 1 );
    void READ_SRAM( ){
    int main()
        SPI_INIT();
        //READ_SRAM();
        char STOP = 'N';
                STOP = pc.getc();
Children
No Data
