Does AD9166/AD9162/AD9172 FMC Evaluation cards has ZCU102 Motherboard reference designs,
As per my search i am unable to findout. Please give me the link if anyone finds.
Thanks In advance
Thanks In advance
Hi krish,
The JESD204 FPGA reference designs from Analog Devices are outlined on this webpage:
https://wiki.analog.com/resources/fpga/peripherals/jesd204
Fortunately, we do have a reference design for AD9172 FMC card and ZCU102 integration:
https://github.com/analogdevicesinc/hdl/tree/master/projects/dac_fmc_ebz/zcu102
Currently, we do not have any plug-and-play ZCU102 reference designs that utilize the AD9162 or AD9166. However, with some time and effort, you may be able to modify the AD917x example so that it is compatible with the AD916x family.
Let me know if you have any questions!
echaykov
Hi echaykov,
Thanks for your reply which helps to me alot.
I am referring to following FMC board.
https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/eval-ad9172.html#eb-buy
As per your link the mentioned reference design suits for this board... Please confirm me, as we are going to buy this board.
Thanks in advance.
Hi krish,
Yes, the AD9172-FMC-EBZ is the correct board to purchase in this case. Using our reference design, you should be able to integrate the AD9172-FMC-EBZ with the ZCU102.
echaykov
Hi Echaykov,
Thanks for your reply.
we are going to buy this board. I will approach you if i have any issues while integrating this board.
Once again thanks for your response.
Krish
