I want to use the AD9125 in byte mode and have the minimum possible latency. Is it possible to bypass all the filter/modulation steps? What is the minimum pipeline latency of this chip?
Just to give a little context, I want to use these for the digital to analog outputs for a digital servo system using an FPGA. Currently using MAX5875, but this chip seemed to have similar noise specs, but a smaller bus size (8 bits wide rather than 16). If you've got alternate chip recommendations let me know, please.
Thank you.
