We are using the DAC AD9125 in our hardware. In its data sheet a built in test setup named SED is specified. We have tried to use this functionality by configuring the DAC as described in the datasheet. Test data was supplied to the DAC inputs but the DAC is not perfoming the SED test as mentioned in the datasheet. No status flags were set during the test indicating that the test is not being done.
The testing was done as follows
DAC is configured to work in WORD Mode
I and Q data is sent to the DAC inputs as shown in the Figure 88 in the datasheet.
DAC is configured for the SED as described in page 53 of the datasheet but without enabling the DAC interrupt
Do we have to configure any other DAC registers other than those mentioned for SED test?
Expecting your reply soon
Thanks in advance
Shino Samuel
Project Engineer
C-DAC,Trivandrum
Kerala, India
This question is being handled off-line due to the level of detail required.
We found solution to SED issue i mentioned above. We followed the procedure in AD9122 DAC datasheet. I found that the explanation is exact reverse of what analog mentioned in AD9125 DAC datasheet which we are using. Anyone can compare that Page 58(AD9122) and page53(AD9125). The logic example given in AD9122 perfectly works and we just implemented & verified.
