I just received an evaluation board for the AD9735-DPG2-EBZ and i'm trying to perform a BIST test.I installed all the software needed to download vectors into the DPG2 and the AD9735_SPI.exe to control the DAC's register from SPI.
My question is, how can i write in the register 17 (BIST register)? The software provided is able to change almost every register of the DAC but not this one? This register needs to be changed in the BIST procedure.
Or maybe it can't be done from a PC?
Thanks!
Typically, the BIST test is done with your own software, not the eval software. I'll need to look at it and see if there is a way to do it in the eval software.
I have checked and there is no way to do BIST tests with the eval software. This is normally done with your own software on your own board.
Ok thank you!That's what i thought!
