If, instead of using high temperature to solder the component, I use a low temperature conductive epoxy (55C) to bond it. Do I still need to bake the component at 150C for 24 hours?
\Lego
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
AD5346
Production
The AD5346 / AD5347 / AD5348 are octal 8-, 10-, and 12- bit DACs, operating from a 2.5 V to 5.5 V supply. These devices incorporate an on-chip output buffer...
Datasheet
AD5346 on Analog.com
\Lego
If you are not heat up the part (>150c), you dont need to bake it before.
