Can the AD9106 be used as a high speed/low PRF pulse generator? i.e. 30nS PW @ 4kHz PRF. It seems like it would be feasible but I believe I would have use the RAM. Is there a way to do this without using the RAM?
AD9106
Production
The AD9106 TxDAC® and waveform generator is a high performance, quad digital-to-analog converter (DAC) integrating on-chip pattern memory for complex waveform...
Datasheet
AD9106 on Analog.com
No. You must load the RAM and then the part plays the pattern from RAM to the DACs.
