AD9106 SRAM read/write
The user was unable to load wave data points into the SRAM, despite setting the PAT_STATUS register and performing ram_update. The issue was resolved by addressing each data value individually due to a mistake in the datasheet regarding the reserved bits in SRAM, which are actually [3:0] instead of [15:12]. The user also confirmed that the CS line must be toggled for each address to properly increment the address pointer.
I'm trying to load wave data points into the SRAM.  I can set the shadow registers, ram_update, and read back the values that were entered.  I cannot seem to load values into the SRAM.
I'm updating the PAT_STATUS reg to allow write according to pg27 of Rev. A of the datasheet and perform the ram_update.  I "attempt" to write the data to the SRAM addresses.  I set PAT_STATUS reg to allow read and perform the ram_update.  When reading the SRAM addresses they all return 00.  The CS pin is toggled appropriately between commands.
Is there something else that I've missed in the datasheet?
