AD9102 - Trouble with DDS mode and reading from SRAM??
The user is experiencing issues with the AD9102 DAC where only constant value and sawtooth modes work on their proto-layout board, while DDS and SRAM modes do not. The final answer suggests checking the power supply and ensuring the RESET pin is clean, and provides the correct register settings for reading and writing SRAM. The user also noted that the WAV_CONFIG register (0x27) does not retain the correct value when programmed in a sequence, and asks about the impact of noise on the power supply and the behavior of the RAMUPDATE bit.
I have the AD9102 EVboard and I can get all modes to work: constant value, Sawtooth, DDS, and reading from SRAM.  However, on my proto-layout board, I program the Ad9102 SPI directly and I can only get the constant value and Sawtooth mode to work.  The DDS and read from SRAM do not give any output.  I am taking the regval and default sequence from the EVboard software and and programming into AD9102 SPI directly.  So inputting example4 settings gives me the pulsed triangle wave for the sawtooth mode which is working, but the sine wave of example6 is not working.  The registers and SRAM are able to read and write properly. Is this a common problem or am I missing something obvious?  Any help would be appreciated, thanks.
  • Can you get continuous sine wave in DDS mode?
  • No, I can't get the sine wave in DDS mode.  The only mode I can get to work is sawtooth mode.  DDS mode and reading from SRAM do not work for me.  Do you know if there's a special sequence of SPI registers to program in order to use DDS mode?
  • What's the sinewave frequency you set? any bandwidth limitation on your DAC output path? what's the value of register 0x27? Can you post your register configuration sequence? I can try your sequence in our lab. thanks.
  • So I was just trying to get my protoboard to run example6 from EVboard which has sine wave at something like 2.3MHz.  I take the register settings from example6 sequence as shown below.  On the tester yesterday, I am able to get my protoboard to output a sine wave for a few cycles, but then shuts off.  The EVboard runs example6 sine wave continuously.  I try to match the timing of SPI commands exactly like EVboard, which is doing 822kHz clock, but ~150uS delays between address and data, and between each individual register.  I do make all the register programs while trigger pin is high, then bring trigger low about 150uS after CSB gone high. Is this possibly too short a delay?  Also, is there a specific way to program in order to get the continuous mode to stick in the registers?
    So for my application, being in DDS mode and reading the pattern directly from SRAM is what I really need, which is really similar to example2.  I am able to get EVboard to do exactly what I want, but my protoboard doesn't seem to load up example2 at all.  I am using the exact sequence from the example2 of EVboard as well.
    Whatever help you can give on the sine wave or the SRAM reading would be great.  Thanks!
    Dan
    example6 seq:
    0000h 00h
    0001h E00h
    0002h 00h
    0003h 00h
    0004h 4000h
    0005h 4000h
    0006h 4000h
    0007h 4000h
    0008h 00h
    0009h 1F00h
    000Ah 1F00h
    000Bh 1F00h
    000Ch 1F00h
    000Dh 00h
    000Eh 00h
    000Fh 00h
    0010h 00h
    0011h 00h
    0012h 00h
    0013h 00h
    0014h 00h
    0015h 00h
    0016h 00h
    0017h 00h
    0018h 00h
    0019h 00h
    001Ah 00h
    001Bh 00h
    001Ch 00h
    001Fh 00h
    0020h 0Eh
    0021h 00h
    0022h 00h
    0023h 00h
    0024h 00h
    0025h 00h
    0026h 1212h
    0027h 1232h
    0028h 111h
    0029h FFFFh
    002Ah 101h
    002Bh 101h
    002Ch 03h
    002Dh 00h
    002Eh 00h
    002Fh 00h
    0030h 00h
    0031h 00h
    0032h 4000h
    0033h 4000h
    0034h 4000h
    0035h 4000h
    0036h 01h
    0037h 7E00h
    0038h 00h
    0039h 00h
    003Ah 00h
    003Bh 00h
    003Ch 00h
    003Dh 00h
    003Eh 750h
    003Fh 7500h
    0040h 00h
    0041h 00h
    0042h 00h
    0043h 00h
    0044h 02h
    0045h 00h
    0046h 00h
    0047h 00h
    0048h 00h
    0049h 00h
    004Ah 00h
    004Bh 00h
    004Ch 00h
    004Dh 00h
    004Eh 00h
    004Fh 00h
    0050h 2710h
    0051h 00h
    0052h 00h
    0053h 01h
    0054h 00h
    0055h 00h
    0056h 00h
    0057h 01h
    0058h 1770h
    0059h 00h
    005Ah 00h
    005Bh 01h
    005Ch FA0h
    005Dh 00h
    005Eh 00h
    005Fh 7FFFh
    001Eh 01h
    001Dh 01h
  • can you try to set reg0x27=0x1231 to see if you can get continuous sinewave?
    And writing 0x1230 to reg0x27 is reading data from RAM.
  • Hi Biao,
    I have tried many times to use 0x1231 and 0x1230, but still having trouble getting AD9102 output to read from SRAM.  I don't get the continuous sine wave like the EVboard, but I care more about reading from SRAM.  So the interesting part today was that I made some patterns to match the SPI reg writes for the EVboard's DAC1 tab and Pattern Config tab.  What I am seeing is the 0x0027 register bits do not stick whenever I send in example2, example5, or my own reg settings for DDS mode off SRAM. Reading back 0x0027 always seems to be 0x0101.  Example4 does work and reads back 0x3212 on 0x0027 reg.
    Writing DAC1 tab settings first, then Pattern config tab settings second causes 0x0101 to be in 0x0027 reg.  If I do Pattern Config tab settings first, then DAC1 tab settings, then 0x0027 reg goes to 0x3030.  This is telling me that there seems to be a special sequence to get all the reg settings to stick, or that the internal switches for DDS mode are damaged and can't be turned on.  Do you have any common info on AD9102 and whether it needs special SPI sequences?   I attach my SPI address sequence from my scoping the EVboard SPI.
    Dan
    DAC1 tab setting address sequence:
    0x0045
    0x005D
    0x005E
    0x005C
    0x005E
    0x0027
    0x001F
    0x002B
    0x0035
    0x0025
    0x003E
    0x003F
    0x0043
    0x0031
    0x0037
    0x0047
    0x005F
    0x001D
    Pattern Config tab setting sequence:
    0x0029
    0x0028
    0x0044
    0x0060
    0x002C
    0x002D
    0x0020
    0x001D
  • Hi Dan,
        Can you try the example 1 sequence in the quick start guide? that uses SRAM data only to DAC. the results are shown below.
        if it still cannot work with example 1 sequence, please check if all the registers are configured correctly.
        if all the registers are written correctly, you may need to check the schematic to see all the connections are correct.
    Power supply is also critical. making sure the power supply is clean enough.
    the sequence as below.
    0000h  0000h
    0001h  0e00h
    0002h  0000h
    0003h  0000h
    0004h  4000h
    0005h  4000h
    0006h  4000h
    0007h  4000h
    0008h  0000h
    0009h  1f00h
    000ah  1f00h
    000bh  1f00h
    000ch  1f00h
    000dh  0000h
    000eh  0000h
    000fh  0000h
    0010h  0000h
    0011h  0000h
    0012h  0000h
    0013h  0000h
    0014h  0000h
    0015h  0000h
    0016h  0000h
    0017h  0000h
    0018h  0000h
    0019h  0000h
    001ah  0000h
    001bh  0000h
    001ch  0000h
    001dh  0000h
    001eh  0000h
    001fh  0000h
    0020h  000Eh
    0021h  000Eh
    0022h  0000h
    0023h  0000h
    0024h  0000h
    0025h  0000h
    0026h  3030h
    0027h  3030h
    0028h  0111h
    0029h  ffffh
    002ah  0101h
    002bh  0101h
    002ch  0003h
    002dh  0000h
    002eh  0000h
    002fh  0000h
    0030h  0000h
    0031h  0000h
    0032h  4000h
    0033h  2000h
    0034h  2000h
    0035h  4000h
    0036h  0001h
    0037h  0200h
    0038h  0000h
    0039h  0000h
    003ah  0000h
    003bh  0000h
    003ch  0000h
    003dh  0000h
    003eh  0000h
    003fh  0000h
    0040h  0000h
    0041h  0000h
    0042h  0000h
    0043h  0000h
    0044h  0000h
    0045h  0000h
    0046h  0000h
    0047h  0000h
    0048h  0000h
    0049h  0000h
    004ah  0000h
    004bh  0000h
    004ch  0000h
    004dh  0000h
    004eh  0000h
    004fh  0000h
    0050h  07d0h
    0051h  0000h
    0052h  fff0h
    0053h  0100h
    0054h  03e8h
    0055h  0000h
    0056h  fff0h
    0057h  0100h
    0058h  0bb8h
    0059h  0000h
    005ah  fff0h
    005bh  0100h
    005ch  0fa0h
    005dh  0000h
    005eh  fff0h
    005fh  0100h
    0060h  0000h
    0061h  0000h
    0062h  0000h
    0063h  0000h
    0064h  0000h
    0065h  0000h
    0066h  0000h
    0067h  0000h
    0068h  0000h
    0069h  0000h
    006ah  0000h
    006bh  0000h
    006ch  0000h
    006dh  0000h
    006eh  0000h
    006fh  0000h
    0070h  0000h
    0071h  0000h
    0072h  0000h
    0073h  0000h
    0074h  0000h
    0075h  0000h
    0076h  0000h
    0077h  0000h
    0078h  0000h
    0079h  0000h
    007ah  0000h
    007bh  0000h
    007ch  0000h
    007dh  0000h
    007eh  0000h
    007fh  0000h
    the SRAM data as below.
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    4
    4
    4
    4
    4
    4
    4
    4
    4
    4
    4
    5
    5
    5
    5
    5
    5
    5
    5
    5
    6
    6
    6
    6
    6
    6
    6
    6
    7
    7
    7
    7
    7
    7
    7
    8
    8
    8
    8
    8
    9
    9
    9
    9
    9
    9
    10
    10
    10
    10
    10
    11
    11
    11
    11
    12
    12
    12
    12
    13
    13
    13
    13
    14
    14
    14
    15
    15
    15
    16
    16
    16
    17
    17
    17
    18
    18
    18
    19
    19
    20
    20
    20
    21
    21
    22
    22
    23
    23
    23
    24
    24
    25
    25
    26
    27
    27
    28
    28
    29
    29
    30
    31
    31
    32
    33
    33
    34
    35
    35
    36
    37
    37
    38
    39
    40
    41
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    60
    61
    62
    63
    65
    66
    67
    69
    70
    72
    73
    75
    76
    78
    79
    81
    82
    84
    86
    88
    89
    91
    93
    95
    97
    99
    101
    103
    105
    107
    109
    111
    114
    116
    118
    121
    123
    126
    128
    131
    133
    136
    139
    142
    145
    148
    151
    154
    157
    160
    163
    166
    170
    173
    177
    180
    184
    188
    192
    195
    199
    203
    207
    212
    216
    220
    225
    229
    234
    239
    244
    249
    254
    259
    264
    269
    275
    280
    286
    292
    298
    304
    310
    316
    322
    329
    336
    342
    349
    356
    364
    371
    378
    386
    394
    402
    410
    418
    427
    435
    444
    453
    462
    472
    481
    491
    501
    511
    521
    532
    543
    554
    565
    576
    588
    600
    612
    624
    637
    650
    663
    676
    690
    704
    718
    733
    748
    763
    778
    794
    810
    826
    843
    860
    877
    895
    913
    932
    951
    970
    989
    1009
    1030
    1051
    1072
    1093
    1116
    1138
    1161
    1185
    1208
    1233
    1258
    1283
    1309
    1336
    1363
    1390
    1418
    1447
    1476
    1506
    1536
    1567
    1599
    1631
    1664
    1698
    1732
    1767
    1803
    1840
    1877
    1915
    1953
    1993
    2033
    2074
    2116
    2159
    2202
    2247
    2292
    2339
    2386
    2434
    2483
    2533
    2585
    2637
    2690
    2744
    2800
    2856
    2914
    2973
    3033
    3094
    3157
    3221
    3286
    3352
    3420
    3489
    3560
    3631
    3705
    3780
    3856
    3934
    4013
    4095
    4013
    3934
    3856
    3780
    3705
    3631
    3560
    3489
    3420
    3352
    3286
    3221
    3157
    3094
    3033
    2973
    2914
    2856
    2800
    2744
    2690
    2637
    2585
    2533
    2483
    2434
    2386
    2339
    2292
    2247
    2202
    2159
    2116
    2074
    2033
    1993
    1953
    1915
    1877
    1840
    1803
    1767
    1732
    1698
    1664
    1631
    1599
    1567
    1536
    1506
    1476
    1447
    1418
    1390
    1363
    1336
    1309
    1283
    1258
    1233
    1208
    1185
    1161
    1138
    1116
    1093
    1072
    1051
    1030
    1009
    989
    970
    951
    932
    913
    895
    877
    860
    843
    826
    810
    794
    778
    763
    748
    733
    718
    704
    690
    676
    663
    650
    637
    624
    612
    600
    588
    576
    565
    554
    543
    532
    521
    511
    501
    491
    481
    472
    462
    453
    444
    435
    427
    418
    410
    402
    394
    386
    378
    371
    364
    356
    349
    342
    336
    329
    322
    316
    310
    304
    298
    292
    286
    280
    275
    269
    264
    259
    254
    249
    244
    239
    234
    229
    225
    220
    216
    212
    207
    203
    199
    195
    192
    188
    184
    180
    177
    173
    170
    166
    163
    160
    157
    154
    151
    148
    145
    142
    139
    136
    133
    131
    128
    126
    123
    121
    118
    116
    114
    111
    109
    107
    105
    103
    101
    99
    97
    95
    93
    91
    89
    88
    86
    84
    82
    81
    79
    78
    76
    75
    73
    72
    70
    69
    67
    66
    65
    63
    62
    61
    60
    58
    57
    56
    55
    54
    53
    52
    51
    50
    49
    48
    47
    46
    45
    44
    43
    42
    41
    41
    40
    39
    38
    37
    37
    36
    35
    35
    34
    33
    33
    32
    31
    31
    30
    29
    29
    28
    28
    27
    27
    26
    25
    25
    24
    24
    23
    23
    23
    22
    22
    21
    21
    20
    20
    20
    19
    19
    18
    18
    18
    17
    17
    17
    16
    16
    16
    15
    15
    15
    14
    14
    14
    13
    13
    13
    13
    12
    12
    12
    12
    11
    11
    11
    11
    10
    10
    10
    10
    10
    9
    9
    9
    9
    9
    9
    8
    8
    8
    8
    8
    7
    7
    7
    7
    7
    7
    7
    6
    6
    6
    6
    6
    6
    6
    6
    5
    5
    5
    5
    5
    5
    5
    5
    5
    4
    4
    4
    4
    4
    4
    4
    4
    4
    4
    4
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    3
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    2
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    1
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
    0
  • Hi Biao,
    I didn't get to create the example1 patterns, but I did have example2 patterns already.  I believe ex2 does use only the SRAM addresses out to DAC.  I do see that the WAV_CONFIG reg reads back as 0x0001 instead of 0x3030.  If i try to program WAV_CONFIG alone, it will read back correctly, but i don't understand why it would get pushed out when i program a string of the registers together. Note that example4 fires up no problem on my protoboard, just not the SRAM modes.
    So I put a 3.3V regulator for each of the power supply pins, using ferrite bead inductor to 2 caps, and I also put 100pF and 0.1uF up close to the AD9102 pin.  All grounds are to ground plane.
    -What would be the result of noise feeding to the supplies? could that cause registers to lose value?
    -I read that writing the RAMUPDATE bit pushes the buffered register settings to the active register settings.  How many times can you do a RAMUPDATE before active register goes to 0x0 or default value?
    -Does RAMUPDATE clear any registers that were not written into the buffer registers?
    -Do you know of any specific sequence order of registers that need to be programmed?  I note the reg sequence for the DAC1 tab programming from EVboard below.
    Thanks again for the help.
    Dan
    DAC1 tab write:
    0x45
    0x5D
    0x5E
    0x5C
    0x27
    0x1F
    0x2B
    0x35
    0x25
    0x3E
    0x3F
    0x43
    0x31
    0x37
    0x47
    0x5F
    0x1D
  • Hi Dan,
         AD9120 power operation range can be from 1.8V to 3.3V. that's much more flexible, but you still may need to check if there has the big voltage drop or ripple/spur on each power rail. If you can send me the schematic, that will be helpful for understanding the issue deeply. You are using LDO or DC-DC regulator?
        Also the RESET pin connection needs to be looked into carefully. making sure it's clean.
        Example 1 or 2 configuration sequence is correct. RAMUPDATE can't reset all the registers to default values.
        Read or write SRAM shall follow the configuration mentioned in datasheet. Also Start_ADDR/STOP_ADDR should be configured correctly.
         To write to any SRAM address, set up the PAT_STATUS register (Register 0x1E) as follows:
     BUF_READ = 0 
         MEM_ACCESS = 1 
         RUN = 0
    To read data from any SRAM address, set up the PAT_STATUS as follows: 
         BUF_READ = 1 
         MEM_ACCESS = 1 
         RUN = 0
    please make sure all the registers and SRAM can be written or read correctly.
  • Hi Dan,
    Could you please share the register configuration to get Sawtooth output?
    I set the same sequence in example4 but get something wrong.
    My all hardware connections are true and I can get sinusoidal output by using example6 but I don't get how I can't get a triangular output by using the example4 configuration.
    Best Regards,
    Dogukan
