AD9144 revision
I have build a system using AD9144 JESD DAC.
The version populated on my PCB is rev 0x02. (Read from register adress 0x06 field DEV_REVISION).
So far, I have been using datasheet rev 0, which also confirms that value.
I recently downloaded an updated datasheet which revision is now rev A
DEV_REVISION value is now 0x06 is this document.
I already noticed some difference in the recommended startup sequence: Required Device Configuration (table 85 or 88) are different.
So which datasheet shall I use?
Rev 0 or Rev A?
Pierre
