I just started designing function generator with AD9102. What clock source do you recommend?
Michał Gąska
AD9102
Production
The AD9102 TxDAC and waveform generator is a high performance digital-to-analog converter (DAC) integrating on-chip pattern memory for complex waveform...
Datasheet
AD9102 on Analog.com
Michał Gąska
Hi -
Our Evaluation board uses the AD9514 to interface the clock to AD9102 CLKP and CLKN. Figures 36, 37 and 38 of the data sheet show three recommended clock driver choices.
Thanks
Thank you for answer. I saw these figures in documentation. But still I need to have clock source. Can I use Si510 as a clock source? What standard of signal is acceptable for AD9102 clock input? LVDS, LVPECL or CMOS?
The figures in the data sheet show you how to connect up LVDS, PECL or CMOS. Thay all work well.
Thanks
