AD9122 : Output power
On my board, I have two AD9122 components.
I program the component with the below registers:
0x0D = 0xD6
0x0A = 0xF8
0x08 = 0xFF
0x1C = 0x04
0x1D = 0x24
0x1E = 0x12
All the others registers are the default value.
The ouput power is different on each AD9122 components. And if I use another baord, I have other ouput power.
Thanks for your help
Best Regards
Nicolas Delabie
Parents
  • Hi Biao Huang,
    You can find below my test process on AD9122 component. On my board, I have two AD9122 components.
    1/ AD9122 components are connected to Xilinx FPGA (xc5vsx95t).
    All the data pins are always level high.
    FRAMEP = ‘0’ and FRAMEN = ‘1’
    RESET = ‘1’
    DCIP and DCIN differential clock = 130MHz
    REFCLKP and REFCLKN differential clock = 130MHz
    DACCLKP and DACCLKN differential clock = 1040MHz
    2/ I program the registers with the below values
    0x0D = 0xD6
    0x0A = 0xF8
    0x08 = 0xFF
    0x1C = 0x04
    0x1D = 0x24
    0x1E = 0x12
    All the others registers have the default values.
    3/ I measure the frequency and the output power on IOUT1P output pin. The frequency is equal to 130MHz. However, the output power changes when I measure the signal on the others components or others boards.
    1st board – 1st AD9122 – Power = - 43 dBm
    1st board – 2nd AD9122 – Power = - 17 dBm
    2nd board – 1st AD9122 – Power = - 15 dBm
    2nd board – 2nd AD9122 – Power = - 8 dBm
    My question is why the output power changes strongly and it is not the same.
    Thanks for your support.
    Nicolas Delabie
Reply
  • Hi Biao Huang,
    RESET = ‘1’
    0x0D = 0xD6
    0x0A = 0xF8
    0x08 = 0xFF
    0x1C = 0x04
    0x1D = 0x24
    0x1E = 0x12
    Nicolas Delabie
Children
No Data
