AD9102: help with generator random waveform
The user is having trouble setting up the AD9102 to output a random waveform from SRAM. The final answer clarifies that SRAM addresses are 16-bit, with the 12-bit Start_ADDR and Stop_ADDR occupying the lower 12 bits. The solution includes a C code example and a register values file for generating a Gaussian waveform from SRAM. The accompanying answers provide additional configuration steps and a reference to the AD9106 EVB schematic for further guidance.
Hi all;
I'm having difficulty setting up the AD9102 to output random waveform from the SRAM (it does not work at all!, And we have already generator SIN_WAVE and SAW_WAVE). Here are several question during datasheet;
1.About Start_ADDR & Stop_ADDR in generator random waveform;
   As we known, the ADDR of SRAM is 16bit(0x6000~0x6fff) but Start_ADDR with only 12-bit available,so does it means Start_ADDR occupy 12LSB of the SRAM ADDR;(i've gotten that the DAC_output occupy 12MSB of SRAM_ADDR);
2. Here are the C code from the AD9102: help with /TRIGGER programming
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60001000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60010000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60022000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60030000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60043000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60050000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60064000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60070000);
what surprising me most is how can it generator random waveform! From date sheet, we were known[15:12]is reserved!!
3.Is there any different  in Configuring the some  basic SFR (like SPI_configure) between the generator SIN_WAV and random  waveform .
4. Our MCU is the basic 8051(TTL-level instead of 3.3V). We wonder it will bring any side_effect to ad9102?
I find the documentation very confusing, so thanks for any input you might have on this.
Thanks!
Mayer
  • Hi -
    I've attached the register values file and an SRAM vector for an example that generates a Gaussian waveform from SRAM. SRAM addresses are justified as shown below. A new rev A datasheet is in process that makes this update.
    Thanks
    0x6000 to 0x6FFF
    SRAM_DATA
    [15:8]
    SRAM_DATA[15:8]
    N/A
    RW
    [7:0]
    SRAM_DATA[7:4]
    RESERVED
    attachments.zip
  • Hi
    My schematic is below :
    But my DAC (AD9102) not work.
    Please Help me.
    My code is in attache.
      0x00000000); /* SPICONFIG */
      0x000101C7); /* POWERCONFIG */
      0x00020000); /* CLOCKCONFIG */
      0x00030000); /* REFADJ */
      0x00070000); /* DACAGAIN */
      0x00080000); /* DACRANGE */
      0x000C000A); /* DACRSET */
      0x001E0000); /* PAT_STATUS - STOP */
      0x001D0001); /* RAMUPDATE */
      0x001F0001); /* PAT_TYPE - finite */
      0x00200000); /* PATTERN_DLY */
      0x00258000); /* DACDOF - max negative */
      0x00270000); /* WAV_CONFIG - SRAM values */
      0x00280111); /* PAT_TIMEBASE */
      0x0029000A); /* PAT_PERIOD */
      0x002B0001); /* DAC_PAT - 1 time */
      0x002C0001); /* DOUT_START */
      0x002D0010); /* DOUT_CONFIG */
      0x00318000); /* DAC_CST */
      0x00354000); /* DAC_DGAIN 0x400=1x */
      0x00370007); /* SAW_CONFIG */
      0x003E0100); /* DDS_TW32 */
      0x003F0000); /* DDS_TW1 */
      0x00430000); /* DDS_PW */
      0x00440002); /* TRIG_TW_SEL */
      0x00450003); /* DDS_CONFIG */
      0x00470000); /* TW_RAM_CONFIG */
      0x005C0000); /* START_DELAY */
      0x005D0000); /* START_ADDR («4) */
      0x005E0070); /* STOP_ADDR («4) */
      0x005F0001); /* DDS_CYC */
      0x001E0004); /* PAT_STATUS - MEM_ACCESS ON */
     ,0x60001000);
     ,0x60010000);
     ,0x60022000);
     ,0x60030000);
     ,0x60043000);
     ,0x60050000);
     ,0x60064000);
     ,0x60070000);
      0x001E0000); /* PAT_STATUS - MEM_ACCESS OFF */
      0x001E0001); /* PAT_STATUS - RUN */
