Problem with PLL Locked Option in ACE Software for AD9122.
         thank you for your last help regarding ACE software, that solved my connection issue. But now there is problem with PLL Locked option in ACE software.
Inline image 2
it should have glow after the successful connection made. but it didn't.
i have given input to boards as below:
1)  Power Supply P5(+5V), P6(GND)
2) Signal Source J1(CLOCK IN), Set source to 500MHz, 2dBm output
3) PC  USB  Cable XP2
4) DSO at   J3 (DAC1_P) or J8 (DAC2_P)
5) Data Bits D0-D15 , Frame signal and DAC_CLK_IN from FPGA.
the software setting that i have done is given below:
Inline image 3
Inline image 4
please help me with it.
Thanks and Regards
Imran
    on Nov 28, 2017 8:49 PM
    Apologies for the delay - still needing some time to look this over and respond - hoping to do that this week.
  • Hello MicheleV
                          Its good to hear from you. you can take time but please try to complete as early as possible.
    on Dec 2, 2017 1:18 AM
    A few more questions/comments/debug suggestions:
    • For DAC PLL OFF case (checkbox unchecked):
      • Can you please probe R26 (near the DAC) to see that the DACCLKP/N pins are getting the 500MHz clock for the DAC rate properly. If they are getting the right clock there shouldn't be an issue getting anything out of the DAC as long as it's also getting a DCI clock (probe A2 or B2 on the P1 connector - underside of the board the pins stick out and can be probed, make sure it's 125MHz).
    • I noticed from your picture that the jumpers are set to send the DAC output to the back of the board (JP4/JP5 and JP6/JP17) which then goes through a filter and send to the ADL5372 modulator on this board. Are you sending an LO for the modulator to J9? The RF out of the modulator is J6. If you wish to just look at the DAC outputs, please change the JP4/JP5 and JP6/JP17 jumpers to be the outer pads (see image in the quick start guide under the 'Selecting the DAC Outputs' section: AD9122 Evaluation Board Quick Start Guide [Analog Devices Wiki] ). Once the jumpers are changed you can view the DAC output out of J3 and J8.
    • If you finally are able to get an output but it does not look like a sine wave check:
      • Are you generating the raw data as unsigned binary or two's complement? Set the appropriate setting in the wizard according to how you're generating the data.
      • If the data still doesn't look right, instead send DC data to the part by sending a value of 0x0000 to the Q DAC and 0x7FFF to the I DAC (two's complement setting in the wizard please). Then you can program the on-chip NCO to modulate the DC data to generate a single-tone and you should be able to get an output and it shouldn't require a correct DCI clock. Click on the NCO block and set it up as shown below, then hit 'Close' and 'Apply'. You will see a tone out at ~25MHz out of the DAC output due to where the NCO is located in the digital datapath.
  • Hello MicheleV
    Thanks
    This time  I got some output but it is not look like sinewave. I also tried to generate raw data using binary and two's complement.
     I don't understand this statement "If the data still doesn't look right, instead send DC data to the part by sending a value of 0x0000 to the Q DAC and 0x7FFF to the I DAC (two's complement setting in the wizard please)." please clarify.
    I changed the jumpers JP4/JP5 and JP6/JP17 jumpers to be the outer pads.
    1) without giving input to DAC i got sine wave
    2)with giving sinewave in binary i got this
    DCI frequency at probe A2 or B2 on the P1 connector is 125MHz
    and at R26 near the DAC i got 500MHz
    at 500MHz DAC clk , 1) what should be the data rate for DAC input?
                                         2) how to configure ACE software?
    Thanks and Regards
    Imran
  • Hello MicheleV
    I configured the DAC correctly. as shown below it gives me output of sinewave of 1GHz
    without giving any input to DAC.
    but I am unable to get the clear sine wave when i feed the data points with 15 MHz
    I got disturbed wave with ~15MHz.
    Please help me with it i didn't know whats happening?
    Thanks and Regards
    Imran Sheikh
